  • 2630阅读
  • 7回复
Icom sm-20 [复制链接]
离线bl7ic
只看楼主 倒序阅读 0楼 发表于: 2006-09-28
icom sm-20 是动圈咪还是电容咪,谢谢.
离线BD9DM
只看该作者 1楼 发表于: 2006-09-28
ic要买吗?应该是动圈的哦
离线bl7ia
只看该作者 2楼 发表于: 2006-09-28
网上说是电申容咪
the icom sm-20 is a unidirectional, electret microphone designed for base station operation with many icom transceivers. (it cannot be used with non-icom transceivers since the power is supplied from the connected transceiver). the sm-20 features up-down tuning (on compatible icom transceivers). there is a switch for ptt (push to talk) and also a lock feature.
on the bottom of the mic base there is a gain adjustment and a low cut switch. this mic is powered from the icom transceiver. the mic cables terminate to a standard icom 8 pin mic plug. this mic works with the 718, 746, 746pro, 756, 756 pro, 756proii, 756proiii, 775, 781, 820, 821, 910h and 920.
the sm-20 can also be used with the 706 series with the addition of the optional opc-589 mic adapter cable.
离线bl7ic
只看该作者 3楼 发表于: 2006-09-28
谢老大ia和9dm,看icom文件没有说清楚是电容还是动圈,但好多人都说是电容咪机会大点的
离线BD7YK
只看该作者 4楼 发表于: 2006-09-28
sm-20是驻极体的,不是电容话筒.此话筒灵敏度较高!
离线BD9DM
只看该作者 5楼 发表于: 2006-09-28
驻机的,卖的还那么贵,好象比md100贵很多,
离线bd8uk
只看该作者 6楼 发表于: 2006-09-28
驻极体话筒也属于电容话筒......
呵呵,如果按振膜类型来分的话,应算到超小振膜而已.
离线BD9DM
只看该作者 7楼 发表于: 2006-09-28
是不是要用到48v幻象供电的?
