  • 4231阅读
  • 11回复
有多少人接觸過tentec短波設備~ [好貼] [复制链接]
离线bd7oi
只看楼主 倒序阅读 0楼 发表于: 2006-09-13
离线bd7oi
只看该作者 1楼 发表于: 2006-09-13
离线bd7oi
只看该作者 2楼 发表于: 2006-09-13
orion ii hf dsp transceiver
the best in amateur radio is now even better with orion ii. featuring a color screen, all-new suite of roofing filters, new control processor and more. click the picture to be taken to the information page.
orion ii: highest performance hf transceiver, analog + if-dsp. dual 32-bit adi sharc processors. optimized amateur bands transceiver plus general coverage sub-receiver.
离线bd7oi
只看该作者 3楼 发表于: 2006-09-13
model 516
if-dsp qrp transceiver
an if-dsp software-defined radio for qrp!
another innovative software-defined radio from ten-tec. argonaut v has the benefits and features of if-dsp, in a modern 20 watt hf transceiver. our philosophy is that "low power" need not be synonymous with "incomplete". some low power rigs offer pieces as options. dsp as an option? not with ten-tec. some offer limited performance and features. with the new argonaut v, we offer solid hf radio performance in a user-friendly format, competitively priced.
20 watts output power, all modes. ssb, cw, digital modes, and fm. front panel adjustable from 1-20 watts output. am operation at 5 watts carrier power (20 watts pep). metering measures forward or reflected power in switchable 2 or 20 watt scales.
a true general coverage all-mode hf transceiver. receive .5 to 30 mhz continuous in user-selectable tuning rates of 10 hz or 1 khz. transmit on all 9 hf ham bands 10-160 meters.
35 if-dsp receive filters are built-in. no extra filtering to buy to operate any available mode!
filters are 200 hz to 1000 hz in 50 hz steps, 1000 to 2800 hz in 100 hz steps; 4 khz and 6 khz in am. an additional 15 khz filter is provided for fm mode operation. shape factors all 1.5:1 or better.
this little rig is a psk31 dream. no accessory boxes necessary. simply connect audio cables from the audio in and audio out jacks to your pc sound card and you're on the air. that's right, no interface, no dropping resistors in the tx line - plug it into the sound card and get on the air. ready for digital mode operation with tcxo standard equipment to assure frequency stability.
like other recent ten-tec hf transceivers, the argonaut v is a software-defined radio. all functions and features of the rig are stored in flash rom. to add new features, simply visit our website, download the latest, and it's as if your rig rolled off the production line a few minutes earlier.
selectable metering functions. in receive, s-units. in transmit, selectable among 25 watt / 5 watt forward power scales, 25 watt reflected power scale, 1.0:1 to 2.5:1 swr or collector current draw.
band scan and memory scan. memory scan has lockout feature for skipping constantly busy
frequencies. band scan can be set to scan between two user-defined frequencies of any margin.
the operator can even program and scan memories for different modes.
heavy-duty cast zinc main tuning knob.
variable cw transmit offset with tracking sidetone, adjustable 400-1000 hz. like all ten-tec rigs, argonaut v is equipped with full qsk operation in cw mode. built-in cw keyer with variable speed control, 10-50 wpm.
argonaut v is equipped with a ptt hand microphone as standard equipment.
updated 10/17/05: the argonaut v now uses a single piece heat sink with the cooling fan as standard equipment - no accessory to add.
updated 01/20/06: the tcxo is no longer optional. all argonaut v's are now equipped with the high stability tcxo as standard equipment.
optional equipment:
model 307b external speaker. texture painted black to match argonaut v cabinet. large. 4 ohm, 5 watt. $ 98
model 308 fan kit. accessory cooling fan slides onto rear panel heat sink. for original production models with black rear heat sink. $ 15.
model 308a fan kit. accessory cooling fan slides onto rear panel heat sink. order this fan kit for use with any argonaut v with gold color rear heat sink that was not supplied with a fan as standard equipment. $ 15.
argonaut v presently available for sale now includes the fan the on heat sink as standard equipment. effective october 17, 2005. do not order a fan with a new radio!
model 309 mobile bracket $ 19.95
model 708 desk microphone for ptt or vox operation. $ 99.
model 937 13.8 vdc 11 amp external power supply. $ 89.
general specifications:
frequency range: 500 khz-30 mhz rx; 1.8-2.0, 3.5-4.0, 7.0-7.3, 10.1-10.15, 14.0-14.35, 18.068-18.168, 21.0-21.45, 24.89-24.99, 28.0-29.7 tx
tuning steps: selectable 10 hz or 1 khz ssb, cw; 100 hz or 5 khz am; 2.5 or 5 khz fm
frequency stability: ? 3 ppm, tcxo standard
frequency accuracy: ? 50 hz at 25? c (tcxo option available for improved accuracy)
modes: usb, lsb, afsk, am, fm, cw
ifs: if1=45 mhz, if2=450 khz, if3=14.5 khz
display: 7-segment led
vfos: dual with split capability
memories: 100
antenna: 50 ohms, so-239
construction: epoxy/glass pc boards, molded front panel, aluminum chassis, steel cabinet
supply voltage: 13.8 vdc
operating temp. range: 0-50 ?c
dimensions: 2.75" x 8.5" x 9.7" (7 x 21.6 x 24.6 cm). includes rear panel heat sink.
weight: 5 lbs. (2.2 kg)
receiver:
sensitivity: ssb, cw, 0.35 ?v typ., 0.5 ?v max. for 10 db sinad at 2.4 khz bw
am, 1.0 ?v typ., 1.2 ?v max. for 10 db sinad at 6 khz bw, 60% modulation
fm, 1.0 ?v typ., 1.2 ?v max. for 12 db sinad at 15 khz bw, 3 khz deviation
selectivity: 35 built-in filters from 200-3000 hz, ssb, cw; 400-6000 hz am, 15 khz fm
ip3: +4 dbm typ. (20-khz spacing, arrl method)
ip2: +66 dbm typ. (arrl method)
image rejection: 70 db typ.
if rejection: 70 db typ.
current drain: 950 ma, no signal, typ.
rit range: ? 10 khz
pbt range: ? 2.5 khz
audio: internal speaker, 2 watts into 4 ohms <5% thd. line out, 600 ohms, 2 v p-p (0 dbm).
s-meter: s-9 = 50 ?v
transmitter:
power output: adjustable 1-20 w, alc controlled
duty cycle: 100% w/ 308 fan kit option
current drain: 7 a max., 20 w cw.
harmonics and spurious suppression: -43 dbc max., 20 w; -33 dbc max., <5 w.
carrier and opposite sideband suppression: >50 db
microphone input: 10 kohms, 5 mv for full power output; dc present at input for electrets
meter: forward power 25w/5w, reflected power 25w, swr 1.0:1 to 2.5:1, collector current 0-9a.
离线bd7oi
只看该作者 4楼 发表于: 2006-09-13
the 1999 release of the (now discontinued) pc-controlled pegasus was a technology breakthrough that revolutionized price versus performance for hf transceivers. the original pegasus has proved to be extremely popular ? but we realize dedicated pc control was not for everyone. the jupiter uses the identical dsp based design packaged with a stylish front panel for conventional "hands-on" use. jupiter is no ordinary hf transceiver. the ten-tec team of active hams focused on one major design objective. organize all the outstanding pegasus features on a front panel that is simple and logical to use without the instruction manual tied to your wrist. so many modern hf rigs fail miserably by this measure. all of the major features are at your fingertips with a dedicated control or from a clearly marked "shift" function.
take a look at what the jupiter brings to your shack:
39 if-dsp receive filters. 25 choices from 1050-8000 hz for voice modes and 14 more from 150 to 900 hz for digital and cw modes. of course, all receive filters are selectable independent of mode.
18 different dsp-generated transmit bandwidths from 900-3900 hz are available for ssb to give your transmit audio a well-rounded sound tailored to your voice characteristics.
software is the heart of jupiter and its all stored in flash rom! this may be the last hf rig you ever need to buy. you simply visit the www.rfsquared.com website, download the latest firmware and its as if your rig rolled off the production line a few minutes earlier.
spectrum sweep gives you a snapshot of the entire band in seconds! find the pileups or scout for a clear spot automatically without touching the tuning knob.
large, multi-function, lcd graphics panel displays it all. its almost like having a pc monitor built into your rig. you see more on the screen than could ever be possible with earlier alpha-numeric designs.
heavy duty internal automatic antenna tuner available as optional equipment. unlike our competitors' transceivers, the internal tuner in the jupiter is rated to match up to a 10:1 swr.
jupiter covers all 10 hf amateur bands, including the new 60 meter band, plus is general coverage on receive. look at this lineup of standard features: dual vfo?s with split mode, passband tuning, adjustable agc, variable cw offset with auto-tracking sidetone, rit/xit, 100% duty cycle final so rugged it doesn?t require swr foldback, and ten-tec?s legendary silky-smooth qsk for cw and fast-switching digital modes.
the power of if-dsp makes jupiter the best value today in an hf transceiver.
the jupiter features an easy-to-read led-lit main panel display. all features and functions of the transceiver are displayed on the main panel.
above the main frequency display are eight annunciators. annunciators selected appear in reverse highlighted text (as nr and vox are in this picture). to the immediate left of the main frequency readout are indicators for agc, mode, and vfo status (rxtx). when operating split mode with the other vfo, the tx status indicator drops down next opposite vfo frequency display to indicate transmit frequency is on the opposite vfo. opposite vfo mode is also shown to the left of the smaller frequency display.
immediately below the mode indicator for the main vfo is the numeral "2850" - readout for receive filtering bandwidth. the knob marked bandwidth just to the left of the display panel controls selection. there are 39 built-in receive filters ranging from 1500 to 8000 hz. all filtering is selectable independent of mode.
to the right of the "2850" display is "pbt +0150". this is readout of tuning range from center for the passband tuning (pbt) control.
to the far right of the display is the "10 hz" indicator. this is step size for the main tuning knob. there are seven selectable main tuning rates that can be selected by pushing the step button on the front panel.
just below the step size indicator is the multi-function meter. in receive, the meter provides both bar graph and digital readout of incoming signal strength (note the "s2" on the meter). in transmit, the meter is selectable for digital readout of either forward power or swr.
near the bottom of the screen is the band sweep scope. the sweep scope is activated by pressing the sweep button at the top of the radio. the radio will sweep across a given range of frequencies, showing you where activity is present (or not present!). the band sweep scope has eight user-selectable ranges from 240 hz to 2.4 mhz to show activity. there is a cursor bar (shown as vertical dashed lines) on the sweep scope as well. this is main tuning knob position. if you see a signal on the scope, you can turn the knob to move the cursor to where the band activity is.
directly under the band sweep scope is the multi function display indicator. the series of buttons directly under the main display panel provide a variety of functions that are controlled by the multi knob on the front panel. both slide rule and digital indicators are provided. select the appropriate button and then rotate the multi knob to adjust.
this is a display shot of the one internal menu the jupiter incorporates for selection of a variety of transceiver values. please note that all often-used functions of the radio are not part of the menu system. controls in the menu system are ones that either need to only be adjusted occasionally or are of the "set-and-forget" variety. the menu is brought onto the screen by selecting mnu on the front panel. turn the main tuning knob to highlight a desired selection in reverse text, then turn the multi knob to adjust the parameter. easy!
tx meter: metering switchable in transmit between swr and forward power
transmitter: transmitter can be disabled for rx-only use.
tx filter b/w: 18 selectable dsp transmit bandwidths for ssb from 900-3900 hz
keying loop: full qsk keying loop for keying true qsk linear amplifiers
audio source: selectable to accept audio from mic jack or rear panel acc jack.
ext t/r delay: adjustable delay for keying of non-qsk linear amplifiers.
sidetone freq: cw sidetone frequency adjustable 0-1270 hz in 10 hz steps. cw offset automatically tracks sidetone setting for easy zero beating.
spot volume: for zero-beating; adjustable independent of main or sidetone volume controls.
cw qsk delay: adjustable for just the "right" amount of qsk action. cw weighting: adjustable dit:dah weighting ratio.
cw keyer: turns internal keyer on or off and allows acceptance of mono or stereo cw key connection through key jack plus selectable curtis a/curtis b keying.
auto sweep: automatically re-activates the band sweep feature for a new "look" at the band when the main tuning knob is moved out of range of the original sweep.
sweep range: 8 selectable ranges from 240 hz - 2.4 mhz allow small or large portions of the band to be "seen" using the sweep feature.
jupiter is priced at $ 1395 factory-direct plus shipping.
with optional internal automatic tuner, $ 1695.
see below for information about our get on hf now with jupiter complete station package.
accessory equipment:
model 701, hand microphone with cable and 4 pin connector $ 28.00.
model 708, communications desk microphone with cable and 4 pin connector $ 99.00.
model 709, communications microphone with cable and 4 pin connector $ 69.00.
model 711, table stand for model 709 $ 15.00.
model 302j remote/encoder keypad. allows armchair control of your jupiter with a handheld main tuning knob, direct frequency entry keypad, and three function buttons that allow control of various transceiver functions. $ 139.00.
model 307c. color-matched external speaker. $ 98.00. click here for 307c info page.
model 310 external cooling fan. attaches to rear heat sink. $ 39.95.
model 963 13.8 vdc 25 amp switching power supply. $ 169.00.
ten-tec now has a demo video available for the jupiter and orion hf transceivers.
the video consists of three segments. the first is a tour of the ten-tec factory, approximately 8 minutes long, hosted by w4pa. the second segment is 44 minutes long and is a video demnstration of the orion, hosted by w4pa. the third segment is 20 minutes long and is a video demonstration of the jupiter video hosted by wa4hwn.
the video is available in vhs (ntsc) and dvd formats. priced at us postage paid in the usa and canada. the purchase price is refundable with a future purchase of a new jupiter or orion hf rig. (no expiration date on the offer - a new jupiter or orion purchase at any time after the purchase of the video). we also make the video available on loan to clubs and organizations for viewing, please contact us at (800) 833-7373 or via sales@tentec.com
get on hf now with jupiter complete station package:
new to hf operation? or just getting back on the air? starting over with a new shack and new equipment? with the jupiter "get on hf now" package, everything you need to get on hf is included. we supply the jupiter hf transceiver with internal automatic antenna tuner, model 963 power supply, model 708 desk microphone, the dvd or vhs instructional/informational video, a 102' g5rv multi-band wire antenna, and 100 feet of rg8x coax with pl-259 connectors installed for a package price of only $ 1995, with shipping costs via ups ground included in the continental 48 states.
sorry, no substitutions permitted on this offer.
specifications, model 538 jupiter
modes: lsb, usb, cw, rtty (afsk), fm, am.
frequency range: receive - 100 khz to 30 mhz. transmit - all ham bands 160-10 meters. modifiable for mars use with proof of licensed authority.
display: lcd
dual vfos with split mode.
offset tuning: +/- 10 khz receive and transmit
memories: 100
frequency accuracy: +/-90 hz at 25 degrees c at 30 mhz for 1 yr
antenna: 50 ohms unbalanced.
power required: 1.5a receive, 20a transmit @ 12-14 vdc
construction: 8 epoxy glass pc boards, molded front panel, aluminum chassis, texture painted steel cover.
dimensions: hxwxd 5"x12.125"x13" (12.7x30.8x33 cm). depth measurement includes rear panel heat sink.
weight: 11.5 lbs. (5.23 kg.)
transmitter
rf output: 5-100 watts, alc stabilized.
dc input: maximum 250 watts @ 14 vdc. 100% duty cycle for up to 20 minutes. continuous duty with customer supplied air cooling of rear panel heat sink.
microphone input: 200 to 50k ohms. 4 pin, front panel connector accepts microphones with 5 mv (-67 db) output. polarizing voltage provided for electrets.
t/r switching: ptt or vox on ssb, fast or slow qsk on cw.
cw offset: programmable 400 to 900 hz, dsp generated. sidetone automatically matches offset, volume adjustable independent of af gain control.
fm deviation: +/- 5 khz.
metering: switchable to forward power, reflected power or swr.
ssb generation: dsp generated
carrier suppression: > 50 db
unwanted sideband suppression: > 60 db at 1.5 khz tone
third order intermod: 25 db below two tone @ 100 watts pep
spurious output: better than 40 db below peak power output.
receiver
sensitivity: .35uv typical for 10 db s+n/n @ 3 khz bandwidth, ssb mode.
selectivity: 34 filters built-in; 300 hz, 330 hz, 375-750 hz in 75 hz increments, 900-3000 hz in 150 hz increments, 3.3-6.0 khz in 300 hz increments, 8.0 khz. all 1.5:1 shape factor or better.
dynamic range: 90 db @ 3 khz bandwidth at 50 khz spacing.
third order intercept: +10 dbm
noise floor: -126 dbm @ 3 khz bandwidth.
s-meter: calibrated to 50 uv at s9.
attenuator: -20 db
passband tuning: +/- 2 khz
i-f frequencies: 1st i-f 45 mhz, 2nd i-f 455 khz, 3rd i-f 12 khz
i-f rejection: > 60 db typical
image rejection: > 60 db typical
receive recovery time: less than 20ms, including split mode.
audio: speaker = 1 watt @ 4 ohms, line out = 1 v p-p into 600 ohms.
all specifications subject to change without notice
last updated june 7, 2006
离线vr2uip
只看该作者 5楼 发表于: 2006-09-13
好东西啊! 聽說這个品牌連机箱也是自家生產.   oi 兄己收藏了嗎?
离线bg7klq
只看该作者 6楼 发表于: 2006-09-14
antenna tuners
model 238b
2000 watt roller inductor antenna tuner
oi是否想做代理呢?
离线huashao128
只看该作者 7楼 发表于: 2006-09-14
刚才看了看,好像他们已经广泛运用if-dsp技术。看那个接收机rx-340,很是喜欢,但是里面好像没有什么东西。。。。
离线ON6WFO
只看该作者 8楼 发表于: 2006-09-14
jupitar,orion对于ssb用户没有什么太大帮助。
离线bd7oi
只看该作者 9楼 发表于: 2006-09-14
antenna tuners
model 238b
oi是否想做代理呢?
我見到他的網站可以支持網上購物的,我無想過做代理吖~ 哈哈哈
离线BG9ACQ
只看该作者 10楼 发表于: 2006-09-17
哈哈.好东西
离线key
只看该作者 11楼 发表于: 2006-09-17
对什么用户有大的帮助?
