  • 2746阅读
  • 4回复
哪位老师告诉我上周末全欧洲SSB的记录发到哪里? [复制链接]
离线BD1LKK
只看楼主 倒序阅读 0楼 发表于: 2006-09-13
邮箱地址!谢谢大家,<业余无线电通信>上的地址我发过去2次提示我已经不能收信了!
不知道哪里有更新的e-mail地址?请告诉我!
离线BG7LKJ
只看该作者 1楼 发表于: 2006-09-13
离线BD1LKK
只看该作者 2楼 发表于: 2006-09-13
please e-mail your contest log to following address: waedc@dxhf.darc.de.
put your callsign, mode and category into the subject line of the message like "dl6rai cw m/s".
please attach all files to a single mail message. do not split your logs over several messages.
please do not send logs from different stations in a single message. send one e-mail per callsign and mode.
within 48 hours you should receive a confirmation message from our log robot indicating that your log has arrived. please keep this confirmation for later reference. it is like a receipt in your hand.
if you receive no confirmation within 48 hours, we have not received your log and you should re-send it.
if your logs bounces or you receive no confirmation message, or if you have comments or suggestions please mail to: waedc-info@dxhf.darc.de.
by the way, it is not necessary to sign your electronic log. by submitting your log, you automatically declare that you are accepting the contest rules.
paper logs
if you logged by hand, we will certainly accept your entry. we respect amateurs who do not wish to use a computer for their contesting activities. bear in mind, however, that we will retype all your qsos and qtcs, which is a tedious task. please follow the rules on hand written logs in section 10 of the current rules and write clearly and orderly.
here are a few sample files for your to look at:
hand-written log from a european station: ua3qg.pdf
hand-written log from a non-european station: zl2az.pdf
please, if you logged on a computer, do not send us a computer printout. send us a disk or an e-mail with your data. if you are not certain, if you can send the correct files, send us what you have - including an ascii readable summary sheet and stating what type of software (if any) was used to compile the log.
the mailing address for hand written paper logs or logs on disk is:
waedc contest committee
p.o. box 2141
d-64532 moerfelden-walldorf
germany
离线BD1LKK
只看该作者 3楼 发表于: 2006-09-13
waedc@dxhf.darc.de
http://www.darc.de/referate/dx/fedcw.htm
非常感谢您的帮助,我的记录已经提交,希望在频率上见到您,送您美好的73!
我的照片以上传到wae相册: http://www.dxhf.darc.de/~waedc/pix2006/
离线BG7LKJ
只看该作者 4楼 发表于: 2006-09-14
不用客气,我也就懂这一点
