  • 2719阅读
  • 2回复
RSGBIOTA也有搞错的时候哦? [复制链接]
离线BG1DRJ
只看楼主 倒序阅读 0楼 发表于: 2006-08-09
http://www.rsgbiota.org/s_activate.php4?getcall=bg1drj/4
今天去iota网站看了看,突然发现as146里面有两个bg1drj/4,把5/1~5/2日的as160也算到as146里面了,不知道怎么搞得。
前一段时间在as146里面还只有一个bg1drj/4。as160里面始终没有我的纪录......roger 来信已经表示确认bg1drj/4 as160了,时间已经很长了,看来只要是人总有犯错误的时候:d
5月14日邮件:
hello helei
many thanks for the three emails with all the information and the
pictures and dv. this helps a lot.
everything is now fine and i am happy to confirm that we will accept
your bg1drj/4 operation from as-160. a note to this effect will be
placed on my website below as well as on the rsgb iota one.
we will also be accepting your as-146 operation - we do not need
validation for that one.
congratulations on both operations. as you probably know, there has been
only one previous operation from as-160 and only two from as-146. so
both iota groups are rare and in much need.
glad to hear that you may revisit as-160. as for as-094, this one has
been activated several times but not in the last 4 years, so a lot of
guys will need it.
best wishes
roger
roger balister, g3kma
rsgb iota manager
e-mail: g3kma@dsl.pipex.com
www: http://www.g3kma.dsl.pipex.com
我该给他再写封信?e文太差,头疼.....
离线BA4DW
只看该作者 1楼 发表于: 2006-08-10
最重要的是iota manager的g3kma已经确认你给他的证明材料ok.
rsgb iota网站上的问题不大,无关"痛痒",写一封简单的信请网站管理员改过来就可以了.
离线BG1DRJ
只看该作者 2楼 发表于: 2006-08-16
acceptable validation material submitted
acceptable validation material has been submitted by the following operations, so checkpoints may award credit for them. ye6p (oc-270), bg1drj/4 (as-160)
submitted by: automatic
呵呵,http://www.rsgbiota.org/index.php4?countthis=1 今天终于看到认可了as160真不容易。查找as160还没有呢......慢慢等吧:)
