  • 5908阅读
  • 7回复
ISS上的SSTV [复制链接]
离线bd5rv
只看楼主 倒序阅读 0楼 发表于: 2006-07-30
国际空间站上的sstv系统已经安装完毕,现在已经在144.49mhz下传图片。大家快把天线对着iss啊
http://www.arrl.org/?artid=6627
sstv tests planned from iss, school contacts set for german astronaut (jul 26, 2006 [revised jul 28, 2006 10:20 et]) -- the amateur radio on the international space station (ariss) program reports that iss expedition 13 commander pavel vinogradov, rv3bs, has set up a camera to use for slow-scan television (sstv) from the iss. vinogradov plans to soon test the system over moscow on 144.49 mhz -- perhaps as early as this weekend -- and radio amateurs within range are encouraged to receive the sstv images. for now, the sstv system will only be used to transmit. due to various issues with 144.49 mhz in europe, the european and us ariss teams will be recommending frequencies for use over other countries. responding to a request from the european space agency (esa), ariss has scheduled school group contacts at three esa-organized events for new expedition 13 astronaut thomas reiter, df4tr (photo). the greek minister of education asked for a qso with reiter during the esa space camp in greece july 29. this is expected to be a major event, with the minister asking an interview question, and greek national tv covering the occasion. a qso with visitors at the museum of the swiss air force is set for september 22, while a contact with visitors to germany's mannheim museum has been rescheduled for november 20, during expedition 14. reiter, the first german astronaut to be a part of an iss crew, likely will use the space station's german call sign, dp0iss.
离线bd5rv
只看该作者 1楼 发表于: 2006-07-30
最新接收的sstv图片,从天上来的哦
离线BD6AHP
只看该作者 2楼 发表于: 2006-07-30
看到这个消息了,不过到目前为止还没有收到信号,继续追踪中……
离线BD6AHP
只看该作者 3楼 发表于: 2006-07-30
刚才又一次过顶,仍然nothing heard
在线bd8te
只看该作者 4楼 发表于: 2006-07-30
12:12还有一次
离线bd5rv
只看该作者 5楼 发表于: 2006-07-30
iss上的电台将在packet和sstv状态之间相互切换。具体判断方法在以下的公报里有。现在sstv还处于测试状态,并非正式开放。
iss amateur radio status:
july 29, 2006
spacecam1 slow scan tv project for iss, update
by miles mann wf1f,
marexmg news manned amateur radio experiment
on friday july 28, 2006 the crew of the international
space station activated the amateur radio project slow
scan tv for the first time. iss expedition 13
commander pavel vinogradov, activated the sstv system
and manually sent a few test images from iss to
earth. images were received in russia and south
america. the sstv system was then switched off and
the packet system reactivated.
as time permits the iss crew may reactivate the sstv
system for more testing. eventually when the testing
is completed the spacecam1 software can be left
running in automatic “slide show” mode. while in
slide show mode, the spacecam1 software will
automatically send up to 400 images per day from iss
to earth.
at the present time we do not have a time schedule for
when slide show mode will be activated.
this testing may be very limited. it is not known when
the project will be officially opened to the world
wide public. the tentative down link for sstv will be
on 144.490 fm. the uplink will not be published until
testing has been completed.
when to listen:
for the rest of this week, listen to both 145.800 mhz
and 144.490 mhz fm. if you hear packet on 145.800,
then you know sstv will not be active. if you do not
hear packet, then monitor 144.490 mhz and be ready to
decode your images.
do not try to send images up to iss at this time. the
iss crew is awake from 0600 to 2200 utc time. try to
monitor every pass the crew is awake.
then end images to marexmg@comcast.net
please pass the word on to swl organizations.
spacecam1:
the marexmg / ariss spacecam1 sstv system is an
entry-level pc based slow scan television system
designed to be used on board the international space
station. this system will support multiple common sstv
transmission modes. spacecam1 has been specifically
designed to be accessible to as many amateur radio
stations as possible around the world. the original
proof-of-concept system was built by the marex team
and successfully flown on the russian space station
mir (december 1998 until august 1999). the
proof-of-concept system has proven the ability of the
hardware design and it has taught us how to make
additional improvements for the next generation sstv
system for iss.
http://www.marexmg.org/marexmirweb/fileshtml/galleryimagepage1.htm
in january 2001 the spacecam1 the ariss program
accepted project at one of the future amateur radio
projects for the international space station.
http://www.marexmg.org/ the spacecam1 software has
been under development since 1999 and is being created
by the siliconpixels team managed by jim barber
(n7cxi). http://www.barberdsp.com/spmain.htm the ariss
hardware manager lou mcfadin (w5did) was assigned the
task of building an audio interface box for the
spacecam1 project. the audio interface box will allow
the audio from a standard laptop pc to be plugged into
the existing amateur radio station on iss. when will
spacecam1 fly? in october 2005 the last component
needed for spacecam1 arrived on iss. all of the
required hardware and software is currently on iss.
the initial big problem was locating a computer on iss
to use for this project. all of the existing laptops
on iss were considered mission critical computers.
recently a computer was released to amateur radio
usage, and the software packages have been loaded. we
are now just waiting for the iss crew to be giving
permission to start testing the sstv applications.
spacecam1 faq:
http://www.marexmg.org/spacecam/spacecam.html will i
be able to receive images from spacecam1? yes!
spacecam1 will transmit and receive images on amateur
radio frequencies, using standard sstv formats.
although spacecam1 is capable of operating in several
modes, the standard format will be robot 36. this
format offers the best standard compromise between
image quality and transmission time. in addition to
two-way "interactive" operation,
spacecam1 provides the following fully automatic
functions:
• transmission from a live camera or disk at specified
intervals • “slide show" operation from a set of
images stored on the system
• sstv repeater
what equipment will i need to receive the images?
radio receiver with an outdoor antenna. the radio
receive will need to be able to receive fm signals in
the amateur radio satellite band (itu 144.000 –
146.000 mhz) a pc with sstv software or a dedicated
sstv scan converter.
http://www.marexmg.org/fileshtml/sstvlinkpage.html
tracking software (optional, although it helps a lot!)
take care all and good luck and please be courteous.
73 miles wf1f marex-na www.marexmg.org until we meet
again dosvidaniya miles wf1f
离线BD2JR
只看该作者 6楼 发表于: 2006-09-10
用orbitron怎么跟踪?
离线8EE
只看该作者 7楼 发表于: 2006-09-10
没戏了,我在井底,连gps都无法定位……
