  • 2687阅读
  • 6回复
石英晶体振荡器 [复制链接]
离线yake10
只看楼主 倒序阅读 0楼 发表于: 2006-07-03
觉得挺好就转过来了,不过看不懂
piezo electric effect
in their investigations, the brothers pierre & jacques curie found that electrical charges were produced by mechanical stresses applied to various naturally occuring crystals. this phenomenon is called the "piezo electric effect", being derived from the greek word "to press"
conversely it was found that the crystal was deformed by the application of an electrical charge, later the application of an alternating alectrical field introduced mechanical vibrations.
the quartz crystal behaves as an electrical resonance circuit with very low attenuation
quartz
quartz was found to be one of the naturally occuring crystaline substance that exhibited the "piezo - electric effect " and being very stable, both chemically and mechanically, it became of great interest to the early electronic experimenters. the chemical description of quartz is silicon dioxide sio2.
although approximately 14% of the earth's crust consists of sio2, it occurs relatively infrequently in usable crystaline form with the necessary purity and without physical defects, cracks etc. raw quartz of quality suitable for the production of quartz crystal units is found brazil and madagascar.
for this reason continuous attempts have been made to produce quartz synthetically ; that is to grow by recrystalisation on to quartz seed plates. these processes are now commercially successful.
quartz chippings are dissolved in an alkaline solution in steel autoclaves at approximately 400 and pressure of 10,000n/cm2, the desired direction of growth is ensured by the careful preorientation of the quartz seed plates.
the growth rate is normally approximately 1mm/day. slow growth rates result in a more homogeneous material since fewer foreign atoms are being incorporated into the crystal lattice.
synthetic quartz is now grown in suitable length and cross sections to enable the subsequent processing steps to be carried out in the most efficient way, with minimum cutting losses. grades available today are of very high purity and mechanical quality, do that synthetic quartz is used almost exclusively for the production of quartz crystal units.
generalizer formulas
离线yake10
只看该作者 1楼 发表于: 2006-07-03
equivalent circuit & parameter define
the electrical properties of the oscillator crystal as a function of the frequency can be depicted in the vicinity of the resonance frequency by an equivalent circuit circuit diagram.
the oscillating mass is symbolized by the dynamic inductance l1, whereas the elasticity is represented by the dynamic capacitance c1.
overtone resonance, as well as spurious resonances can be depicted by additional, parallel connected series resonance circuits.
离线yake10
只看该作者 2楼 发表于: 2006-07-03
frequency vs. temperature curve graph of at-cut crystal units
离线yake10
只看该作者 3楼 发表于: 2006-07-03
basic crystal oscillator circuit
离线yake10
只看该作者 4楼 发表于: 2006-07-03
AT cut
at cut
the commercial designation for a specifically oriented resonator plate, having desirable and repeatable operating characteristics. a plate cut from a crystal of quartz such that the plate contains the x-axis and makes an angle of about 35 degrees with the optic or z-axis. the at-cut crystal is the most popular thickness-shear crystal unit manufactured today. it has excellent temperature and frequency characteristics. this design provides 70 to 80% of all crystal requirements. the frequency vs. temperature curve is a sine with the inflection temperature at ~ +25"c. preferred for high frequency oscillator control over a wide temperature range for tcxo, vcxo, and ovenized oscillators. frequency range is from 500 khz to 200mhz. also used for filters.
离线yake10
只看该作者 5楼 发表于: 2006-07-03
colpitts oscillator
an oscillator in which a parallel-tuned tank circuit has two voltage-dividing capacitors in series, with their common connection going to the cathode in the electron-tube version and the emitter circuit in the transistor version
离线BG9ADQ
只看该作者 6楼 发表于: 2006-07-04
hao dd!
