  • 9871阅读
  • 36回复
DXCC rule change--西沙群岛会成为新的DXCC? [复制链接]
离线BA4DW
只看楼主 倒序阅读 0楼 发表于: 2006-06-16
2006年6月15日起dxcc规则中有一条发生变化。由着这个新变化,我国的西沙群岛和澳大利亚的ashmore and cartier islands将有条件成为新的dxcc。我正向arrl确认中
arrl news release
225 main street
newington ct usa 06111
telephone: 860-594-0291
fax: 860-594-0346
email: n7ng@arrl.org
june 14, 2006
for further information contact: wayne mills, n7ng
dxcc rule change
upon request of the programs and services committee (psc), the dxac has studied the impact of a change to the dxcc rules. the dxac, the awards committee and the psc have concurred in this rule change, which will become effective june 15, 2006 at 0001z. new text replaces the previously removed dxcc rule, section ii, 1. political entities, paragraph c). the new text shall read:
c) the entity contains a permanent population, is administered by a local government, and is located at least 800 km from its parent. to satisfy the "permanent population" and "administered by a local government" criteria of this sub-section, an entity must be listed on either (a) the u.s. department of state's list of "dependencies and areas of special sovereignty" as having a local "administrative center," or (b) the united nationslist of "non-self-governing territories."
rule 1c) is intended to recognize entities that are sufficiently separate from their parent for dxcc purposes but do not qualify under rule 1a) or 1b). the new rule will cause a change to point 1 status for certain entities. this in turn will reduce the mileage for a first separation for these entities from 800 km to 350 km.
the lists referenced in the text of the rule can be viewed at the following web sites: the dos list of dependencies and areas of special sovereignty at http://www.state.gov/s/inr/rls/10543.htm, and the u.n. list of non-self-governing territories at http://www.un.org/depts/dpi/decolonization/trust3.htm.
qsos with any new entity resulting from this rule change will count for credit for the new entity only if the qsos are made on or after the start date for the entity. in no case will qsos made prior to the date of this notice be considered for credit for any new entity created under this rule. applications for dxcc award credits resulting from this change will be accepted on or after october 1, 2006.
离线BG1DRJ
只看该作者 1楼 发表于: 2006-06-16
准备去吗?什么时候?
离线BG1DRJ
只看该作者 2楼 发表于: 2006-06-16
还有南沙群岛呢?一定要抓紧!b字头!
离线BA4DW
只看该作者 3楼 发表于: 2006-06-16
350公里的概念要看是从大陆(广东)算起,还是从海南算起,这个和西沙有否条件成为新的dxcc很有关系。
去啊,asap。
离线BA5CW
只看该作者 4楼 发表于: 2006-06-16
到海南距离不够
离线BA5CW
只看该作者 5楼 发表于: 2006-06-16
刚才量错了,没有到岛边,实际是315公里
离线BA4DW
只看该作者 6楼 发表于: 2006-06-17
4alc量得很精确了。昨天下午搜索时,网上的数据是距海南岛约330公里(180海里)。
不过西沙群岛的范围挺大,或许除了群岛的主岛永兴岛之外,群岛中有别的小岛能再
远上20-30公里(西沙群岛,从东北向西南伸展,在长250 公里,宽约150公里的海域
里,由45座岛、洲、礁、沙滩组成。)
425dxn也在昨天晚间发布了这一消息,但没有就世界上哪个地方能够根据这个新规则
能成为新的dxcc做出分析。很多dxer都在分头自己做分析吧。
离线BA4DW
只看该作者 7楼 发表于: 2006-06-17
西沙群岛中的东岛(英文名 lincoin island),中建岛(英文名 triton island),请
alc再帮忙给量量。
一旦距离得以确认,可以组织远征队啦。去年我在北京时,有见到过去过西沙这些
小岛的朋友,可以请教一下他们的经验,当然还有尽快办妥执照及相关手续。
drj,从今天开始我连续7天在外,有消息打我电话。 :)
离线BG1DRJ
只看该作者 8楼 发表于: 2006-06-17
现在到明年一月是南海的热带气旋﹐很难上去。我去了解手续﹐毕竟特殊。
离线BA5CW
只看该作者 9楼 发表于: 2006-06-17
到浪花礁373km,不过这个是没有永久居民的,到东岛328km,图片显示的是东岛
离线BG6IQD
只看该作者 10楼 发表于: 2006-06-17
关注!
离线BA4DW
只看该作者 11楼 发表于: 2006-06-18
alc,中建岛到海南的准确直线距离是多少?这条直线上没有其他岛礁阻隔吧?
中建岛上有我军守备部队。
离线bv2ac
只看该作者 12楼 发表于: 2006-06-18
應該計算海南島(by 母體最南端) 至 by 申請 dxcc 子體(西沙)最接近母體的島, 如圖上所述, 即使你在中建島設台, 距離應該算海南到趙述島, 或珊瑚島, 北礁如果符合島的定義(漲潮時陸地幅員直線100 公尺), 就要算到北礁..
离线BA4DW
只看该作者 13楼 发表于: 2006-06-18
谢谢2ac的解释。n7ng给我的第一封e-mail也说到了距离不够。
呵呵,350公里概念啊,如此,若不能把中建岛单列,而是做为西沙群岛整体,
便不能成为一个新的dxcc了。
拭目以待,看看究竟世界上哪块“角落”会因为这个新生效的规则而成为新的
dxcc呢?据偶的估计,这个规则的改变,应该有新的dxcc出现,问题只是
她在哪里(swain island, kh8, oc-200)? :)
离线BA4DW
只看该作者 14楼 发表于: 2006-06-18
还有南沙群岛呢?一定要抓紧!b字头!
2ac,太平岛。 :)
离线bv2ac
只看该作者 15楼 发表于: 2006-06-18
2ac,太平岛。 :)
會員都興趣缺缺....
我們交涉過, 國防部會排所有交通, 但是必須搭載一個月一次的運補船期, 沒人能這般久不上班.
另外我理解的 dxcc 的執委消息是, 南沙地區不能做為各國都有的 dxcc 國度處理, 所有的國家必須分享此一 dxcc, 也就是說, 作了馬來西亞的 9m0s, 與台灣的 bq9s, 或是大陸的 bs7s, 都只能算同一個. 所以搶通的誘因又少了, 或許只有 iota 才對新增島嶼呼號有興趣...
离线BA4DW
只看该作者 16楼 发表于: 2006-06-19
是啊,dxcc和iota都将南沙群岛做为一个整体。
南沙应该还是很稀有啊,强烈期待太平岛在空中出现哟,若是某一时段有一星期或10天半月中有
两次补给船航程就好啊。
对了,bq9p今年不出现吗,我可等着160米的通讯机会哟。
离线BA7IA
只看该作者 17楼 发表于: 2006-06-19
會員都興趣缺缺....
如果能成行的话,我愿放下工作去一个多月,想想能在南沙的一个海岛上玩一个月的dx,是多么美妙的人生享受啊! :d
离线BG1DRJ
只看该作者 18楼 发表于: 2006-06-19
如果能成行的话,我愿放下工作去一个多月,想想能在南沙的一个海岛上玩一个月的dx,是多么美妙的人生享受啊! [表情] [表情] [表情] :d [表情] [表情]
是很美妙!
不过回来就不美妙了,失业了
离线BA7IO
只看该作者 19楼 发表于: 2006-06-19
同感..........辞职也值....
