  • 10186阅读
  • 2回复
10m Beacons for QSL [复制链接]
离线bd2bhh
只看楼主 倒序阅读 0楼 发表于: 2006-04-05
worldwide list of hf beacons
一下是10m段世界内的部分信标台列表
latest update 28 march 2006
最后更新日期2006.03.28
频率   呼号   城市   网格位置 输入功率 天线     方向、工作模式
freq   call     town       loc   erpw   ant   direct mode status
28174   9h1ia   mosta, malta   jm75fv   7.5   vertical   omni a1 planned
28175   ve3ten ottawa on     fn25   10   gp       omni a1   24
28176.9 hp1rcp cerro jefe   fj09hd   5   slope dip     a1   24
28180.3 i1m   bordighera   jn33ut 5/20   2x5/8 vert omni a1 30/60min
28182.4 sv3aqr amalias     km07qs   4   gp       omni a1   24
28185   va3src burlington on         5   dipole       a1   pt
28185   i8emg   cozzo cervello jm89bj                     24
28188   je7ynq fukushima     qm07   50   stack dip omni a1   24
28189   xe1srf cuernavaca   ek09la   20   5/8 4.2db omni a1   24
28189.6 a47rb   oman       ll93fo   50   ar-10     omni a1 nonop
28190   lu1dz   ba province         10   4-el yagi n   a1 irreg
28190   5t5sn   nouakchott         10   horiz dip     a1   24
28190.2 lu4xs   tierra/d/fuego fd65pa   5   inv vee   omni a1 irreg
28190.5 va3ror orillia on   fn04eq   5   vertical   omni a1   24
28191   gb3ral nr didcot     io91in   10   vertical   omni a1 2 mn cycle
28192   lu2ffv santa fe prov.       5   gp       omni a1   irreg
28192.9 ve4arm austin mb   em09hw   5   gp       omni a1   24
28194   ik8vrq naples       jn70cu   2   1/4 vert   omni a1 weekend
28195.1 iy4m   bologna     jn54qk   20   5/8 gp   omni a1   h>h+30m
28196.0 va2mgl la malbaie pq fn47uq   2   turnstile omni a1   qrt
28196.0 lu6dts la plata ba   gf15ac   5   gp       omni a1 irreg
28197   lu7ww   chubut prov.   fe77lf   5   6-el         a1 vyirreg
28197.0 ve7mty vancouver bc cn89     5   vertical   omni a1   24
28197   ep4hr   shiraz       ll69go   5   gp       omni a1   24
28198.0 hb9afz bellinzona   jn46me   10   3-el         a1 tnonop
28200.0 4u1un   un new york   fn30as 100-0.1 vertical   omni a1 ibp cycle
28200.0 ve8at   eureka,nunavut eq79ax 100-0.1 vertical   omni a1 ibp cycle
28200.0 w6wx   mt umunhum ca cm97bd 100-0.1 vertical   omni a1 ibp cycle
28200.0 kh6wo   laie, oahu hi bl11ap 100-0.1 vertical   omni a1 ibp cycle
28200.0 zl6b   nr masterton   re78tw 100-0.1 vertical   omni a1 ibp cycle
28200.0 vk6rbp 28k se perth   of87av 100-0.1 vertical   omni a1 ibp cycle
28200.0 ja2igy mt asama     pm84jk 100-0.1 vertical   omni a1 ibp cycle
28200.0 rr9o   novosibirsk   no14kx 100-0.1 vertical   omni a1 ibp cycle
28200.0 vr2b   hong kong     ol72cq 100-0.1 vertical   omni a1 ibp nonop
28200.0 4s7b   colombo     nj06cc 100-0.1 vertical   omni a1 ibp cycle
28200.0 zs6dn   pretoria     kg44dc 100-0.1 vertical   omni a1 ibp cycle
28200.0 5z4b   kiambu       ki88mx 100-0.1 vertical   omni a1 ibp cycle
28200.0 4x6tu   tel aviv     km72jb 100-0.1 vertical   omni a1 ibp cycle
28200.0 oh2b   lohja       kp20   100-0.1 vertical   omni a1 ibp cycle
28200.0 cs3b   santo da serra im12or 100-0.1 vertical   omni a1 ibp cycle
28200.0 oa4b   lima       fh17mw 100-0.1 vertical   omni a1 ibp cycle
28200.0 yv5b   caracas     fk60nk 100-0.1 vertical   omni a1 ibp cycle
28201.5 sk3gk   gdvle       jp80np   4   1/4gp@50m omni a1   24
28202.3 zs1j   napier             5   1/2 vert   omni a1   24
28203   sr4ten suchacz     jo94rg   3           omni a1   24
28203.9 n0wy   plattsmouth ne en21ba   3   vertical   omni a1   24
28203.5 k6lll   laguna beach ca                     a1   24
28203.9 n3nia   nr ridgway pa fn01pk   4   dipole       a1   24
+ spurious outputs
28205.0 dl0igi hohenpeissenb'gjn57mt 150   1/4 vert   omni a1   24
28206   kb0lnb princeton mn   en35     5   vertical   omni a1   24
28206.6 w8nga   grove city oh em89kv   5   ringo     omni a1   24
28207.5 s55zrs mt kum       jn76mc   10   1/4 gp   omni a1 nonop
28208.1 jr0yan nr toyama     pm86jw   25   hor.loop       a1   24+++
28208.5 ak2f   mt drive nj   fn20     4   vert dip   omni a1   24
28208.6 ei0ten cobh, co. cork io51uu   50   dipole   nw/se a1   24
28209   w4je   hayesville nc em85eb   7   horiz. dip n-s   a1   24*
28209   kh6ap   kikei maui hi bl10ss   20   3/8 vert   omni a1 tnonop
28210v n9ydz   brighton il                         a1   24
28210   k4dpc   wilmington nc fm14     3   a99 u'ground ?   a1   24
28210.5 ve4ten winnipeg mb   en19     3   1/2 vert   omni a1   24
28211.1 la4ten sotra i.     jp20lg 250   vertical   omni a1 nonop
28211.5 kk7pg   buckeye az                         a1   24
28213.2 dm0ing ingelheim     jn49ax   10   gp       omni a1   24                                   uc
28213.5 vk3rsx dunolly vic   qf13lr   10   5/8 gp   omni a1   24
28214   lu7dqp lanos buenosba gf05th                 a1   int
28214   n4lem   cocoa beach fl       5               a1 test
28215   gb3ral nr didcot     io91in   25   horizdip   omni f1   24
28215   n3mvf   nr pittsburgpa fn00                   a1   int
28217   iq1sp             jn44vc   3               a1   24
28217   ab7rg   cottonwood az dm44aq   5   ar10@50'   omni a1   24
28217   wb0ftl alden mn     en33fp   5   ar10@25'   omni a1   24
28218.5 ka0pse duluth     mn en36vt   4   inv v @35' omni a1   24
28218.7 k2kl   monsey ny     fn21wc   3   horiz dip omni a1   24
28219.9 kb9dja mooresville in em69ro   35   gp       omni a1   24
28220   5b4cy   zygi       km64pr   26   gp       omni f1   24
28220   k6ba   vista ca                           a1   24
28220.3 er1aaz chisinau           4   gp           a1   28221   we4s   mcdonough ga   em73tm                 a1   24
28222.5 cx5bw   40kn montevideo gf25ae 10   gp           a1   int
28223.2 kc6ufe chico ca     cm99bs   20   vertdip@30' omni a1 tnonop
28224   f5sn   dole       jn27rb   5   3-el yagi 240 multi 24
28224.8 kw7y   marysville wa cn88sd   4   vertical   omni a1   24
28225   kg0rp   louisville co dm79kx   10   vert@15'   omni a1   24
28226v py3ibz porto alegre   gf49kw   20   vertical   omni a1   24
28226.6 kc6wgn las vegas nv         10           omni a1   24
28227.5 iw3fzq monselice pd   jn55vf   5   1/2 gp   omni a1   24
28228   zl3ten rolliston     re66   20   1/2 vert   omni a1   24
28228   k5dze   huntsville al em64     5   2-elyagi v up   a1 temp
28230   wh6p   kanohe bay hi bl11ck   10   r7 vert   omni a1   int
28230.4 py3arl port alegre   gf49jw   5   gp@287m   omni a1   24
28231.4 hp1ac   cerro azul   fj09hd   4   slope dip     a1 tnonop
28233   kd4ec   jupiter fl   el96ww   5   vertical   omni a1 tnonop
28234.1 n9ret   broadside il   en61     7   a99 vert   omni a1   24
28234.5 w1fvb   whitefield nh fn44ej   3   vertical   omni a1 04-2200
28235.2 ve1cbz fredericton nb fn65     3   vertical   omni a1   24
28236.5 w0kiz   nr denver co   dm79     5   vertical   omni a1   24
28237.6 la5ten nr oslo     jo59jp   15   1/2 vert   omni a1   24
28237.8 n4es   clearwater fl el83pa 20/2/.2/02 vert   omni a1   24
28238.6 k5uny   farmersbranchtxem12nw   4   ar10 vert omni a1   24
28240   w1nra   phenix city al em72ll   5   vert@20'   omni a1   24
28240.6 yo2x   timisoara     kn05ps   3   gp       omni a1 10-18z
28241.0 ve3sec southgillieson en58     5   vert@30'   omni a1   24
28242   w2ik   san antonio tx el09   10   1/2 vert   omni a1   24
28243   kh2ru/kp4                 5   vertical   omni a1   24
28243.3 f5tmj   nr toulouse   jn03sm   5   horiz loop omni a1   24
28244.0 wa6apq long beach ca dm13   30   vertical   omni a1   24
28244.8 it9dtv messina     jm78sd   8   gp       omni a1   24
28246.0 kg2gl   nutley nj     fn20     5   r5 vert   omni a1   24
28247.9 n1me   bangor me     fn54ps   5               a1   24
28248.5 n7lt   bozeman mt   dn45lq 4/.4/.04 1/2 gp   omni a1   24
28249.3 py5nd   curittba pr   gg54in                 a1 irreg
28250   n4ess/n4es/w4so           20/2/.2.02           a1 synch
28250.1 z21anb bulawayo     kg47     8   gp       omni f1   24
28253   vk3rmv wannon vic   qf12   20                 nonop
28253   kg4yuv crandall ga   em74ow   4   a99     omni a1   24
28254.7 w4stt   hastings fl   el99gq   20   vertical   omni a1 12-2400
28255   ki4pj   palm bay fl         5   4-band vert omni a1   8/24
28256   c30p   andorra     jn02sm   10   r5 vert@2m omni a1   24
28256.5 vk3rmh 25knemelbourne qf22oh 20/2   1/2 vert   omni a1   24
28257.5 dk0ten konstanz     jn57np   40   gp       omni f1   24
28257.8 wy5i   jupiter fl   el96     5   7db coll. omni a1 07-2200lt
28258   nv4b   russelville al em64dm   5   vertical   omni a1 test
28258.8 wa8rc   battle creekmi en72     5   vertical   omni a1   24
28259   w5rtx   rockwall tx         5   1/2 square ne/se a1   24
28259   f5kmd   valenciennes59 jo10si   5   3dbi vert omni a1   24
28259.8 ka1nsv/4green bay va   fm07   25   vert.dip. omni a1   24
28260   aa9l   s milwaukee wi en62bv       a90@60ft   omni a1 test
28261.0 n7lf   corbett or   cn85vi                 a1   24
28261   kp3ft   ponce pr           4   vertical       a1 tnonop
28261   kf4oti north templeme                       a1 irreg
28261.8 vk2rsy sydney       qf56mh   25   1/2 vert   omni a1   24
28263.3 ea4dat cuenca       in80vb   5   5/8 vert   omni a1   test
28263.5 w4jpl   liberty nc   fm05     4               a1   ?
28264.0 ab8z   parma oh     en91dj   5   5/8 vert   omni a1   24
28264   vk6rwa carine wa     of78wb   20   5/8 vert   omni a1   24
28264.1 n8wlc   lexington oh   en80rq   5   180' dip   e-w   a1 tnonop
28265   df0ann moritzberg hill jn59pl   5   dipole   e-w   a1   24
28265   n7scq   sacramento ca         3               a1   24
28266.5 ka1eks millinocket me fn55oo   4   a99 gp   omni a1   24
28267   ae5x   west harrisonnyfn31db   4   1/4 vert   omni a1   24
28267.6 oh9ten pirttikoski   kp36oi   20   1/2 gp   omni a1   24
28268.3 vk8vf   darwin       ph57kp   25   1/4 vert   omni a1   24
28268.9 aa1tt   claremont nh   fn33     5               a1   24
28269.1 w2rtb   nr victor ny   fn13   10   gp       omni a1   24
28269.5 w3hh   nr ocala fl           6   hamstick   omni a1   24
28270   w8bep   sault s mariemien76   10   windom       a1   int
28270   vk4rtl townsville   qh30js   5   vertical       f1   24
28270.2 k4ais   waleska   ga                       a1   24
28271   ve1/w1bkr henry i.   fn95     3   gp       omni a1   int
28271.7 w4tiy   dallas ga           4   1/4over5/8 omni a1   24
28273   n4hlf   apopka fl           15   a99 vert   omni a1   24
28274.7 n0ud   halliday nd   dn87sh                 a1   24
28275   np2sh   st john us vi                       a1   24
28275   kg4gvv summerville sc em93       vertical   omni a1   24
28275.7 xe1akm colima                 + spurii       a1   24
28276   k4ukb   danville ky   em77np   10   5/8 vert   omni a1   24
28277   wb7rbn benton city wa dn06ig                 a1   24
28277.3 kd4mzm sarasota fl   el87rg   5   vertical   omni a1   24
28277.6 df0aab kiel       jo54gh   10   gp       omni f1   24
28278   ac3a   leawood ks   em28qv   5   attic dip ne/sw a1   24
28280.0 k5ab   goldthwaite tx em10dh   20   5/8 gp@45' omni a1   24
28281   w8eh   middletown oh em79tl   7.5   vert@40'   omni a1   24
28282   la6ten kirkenes     kp49xq 10/1/.1         omni a1   24
28282.5 w0ere   highlandvillemoem36iw   5   vertical   omni a1   24
28282.6 ok0eg   hradec kralove jo70we   10   gp       omni f1   24
28285.0 vp8ade adelaide i.   fc52wk   8   horiz dip eu/ja a1   24
28286   n5aqm   chandler az   dm43ah   2   vertical   omni a1   24
28286.5 nq2rp   brockport ny   fn02     2   2-el yagi 230   a1 tnonop
28287   k7fff   hillsboro or   cn85mm   2   dipole   sse/nnwa1   op?
28288.0 wa7lnw hurricane ut   dm37id   5   fwave loopeu/pac a1   24
28288   sm0ncl/3tasjo       jp83   50   gp       omni a1   24
28289.0 wj5o   cor. christi txel17     2   yagi     ne   a1   24
28289.8 vr2ten hong kong     ol72     5   1/4 gp   omni a1   24
28290.4 sk5ae   strangnas     jo89kk   50   gp       omni a1   24
28290.3 wb4wor randleman nc   fm06bt   3   vertical   omni a1   24
28292.0 va3va   windsor on   en82     5   horiz dip     a1   24
28292.5 sk0ct   sollentuna   jo89xk   10   gp       omni a1   24
28293.4 nd4z   gilbert sc   em94     3   gp@70'   omni a1   24
28295   kd1zx   centralfallsri fn41hv   4   vertical   omni a1   24
28295.1 sk2ten kristineberg   jp95hb   5   vertical   omni a1   tnonop
28295.8 w3vd   laurel md     fm19ne   10   hor.dipole ne/sw a1   24
28296   ka7bgr centralpointor cn82                   a1   24
28297.1 ns9rc   winnetka il   en62dc   8   1/2 vert   omni a1   24
28297.5 sk7ten lonneberga   jo77um   15   gp       omni a1   24
28298.0 v73ten roi namur i   rj39rj       horiz oa50 omni     24
28298.6 k4jdr   raleigh nc   fm05   10   vertical   omni a1   24
28300   vk2rs   bathurst nsw   qf46sn   5   3/4 vert   omni     test
28321   dl5kz   numbrecht     jo30su   5   a99     omni     exp
28702   da5mmb nr mainz     jn49cx   5   gp       omni multi 24
我经常使用的是日本的28.188   je7ynq ,50w功率比较适中。适合国内爱好者监听,如果能听见的话,全国范围内通联无问题,我从不在29.495、 29.600守听、钓鱼。不过近来也很难听到了。100w的信标可以看出来,功率是在0.1-100w间变化的。
另外以前hongkong的信标也很好,但是也听不到了,可能出问题了。
离线bg9ep
只看该作者 1楼 发表于: 2006-04-05
喜欢~~~~~~~~~~~~~~~
离线3mb4
只看该作者 2楼 发表于: 2011-09-29
挖坟。。。。。。。。。。。。。。。
