  • 2017阅读
  • 1回复
摩托罗拉无线电综合测试仪R2600C [复制链接]
离线chengy
只看楼主 倒序阅读 0楼 发表于: 2006-03-11
全新原包装摩托罗拉无线电综合测试仪r2600c 频率范围:400khz-1ghz 附件齐全   没有说明书
价格:16000元
r-2600无线通信设备综合测试仪
还有更详细的指标,需要的朋友邮件寄出.
sweep generator
range;
400 khz - 1 ghz
resolution:
100 hz
output:
-130 dbm to 0 dbm
sweep width:
selectable up to ±5 mhz of center freq.
scope coupling:
synchronized scope trace to the sweep signal
accuracy:
same as signal generator
duplex generator
range:
400 khz - 1 ghz
resolution:
100 hz
output:
-130 dbm to 0 dbm
frequency offset:
0 mhz to ±55 mhz in 5 khz steps
accuracy:
离线bd1es
只看该作者 1楼 发表于: 2006-03-13
唉,哪里有信号源卖的,8647a 8648b之类,最好是8648b,:(:(...
