  • 3869阅读
  • 1回复
Alinco DX 70TH [复制链接]
离线BG7IBQ
只看楼主 倒序阅读 0楼 发表于: 2002-10-16
this transceiver is just as small as other compact hf rigs but is loaded with features. the dx70th features a main and sub-dial for simplified operation. the main dial is dedicated to vfo operation while the sub-dial is used for fast change, band selection, and/or memory selection. if shift, and narrow filters for am, ssb, and cw operation are included to reduce qrm. cw reception is also enhanced by upper or lower side of carrier selection. the quick offset function allows you to work pileups with great ease. simply hold the split key and tun the dial. the lcd display shows you the split in mhz/khz without having to make any calculations! the built-in speech compressor adds punch to your signal. wide range general coverage receive from 150 khz to 30 mhz is included. 100 memories are standard and are divided into 10 groups. each group can be scanned separately. the dx70 also features a completely detachable front panel. (remote mount kit available.) full 100w output on hf and 6m.
http://www.durhamradio.com/dx70.htm
离线BA7EI
只看该作者 1楼 发表于: 2002-10-16
Re: Alinco DX 70TH
您准备diy这样的设备?
或者提示某地某人正在转让这种电台?
