  • 16450阅读
  • 77回复
复活的宇航人将在今天中午经过中国大陆! [复制链接]
离线BD4OS
只看楼主 倒序阅读 0楼 发表于: 2006-02-05
好消息!suitsat宇航人经各地报告现在已经复活!信号强度还有增加的趋势(相对而然,其实仍然很微弱)!
今天(2006/2/5)中午11:28从我国版图的西北方向(新疆)开始直到11:48从中国版图的东南方向脱离,意即中国大部分地区(除2地区的北部地区)在这个时间段有可能收到来自suitsat的信号!
接收频率145.990mhz,切记不要尝试发射!
离线汤圆
只看该作者 1楼 发表于: 2006-02-05
没有收到 一点都没有
离线bd4rs
只看该作者 2楼 发表于: 2006-02-05
复活的宇航人在说话!--WEAK MALE VOICE
received by time heard (utc) signal mission time temperature voltage comments
kb7lmt 20060204222209 1     heard brief male voice at 0216 central time this morning.wasn't sure
kg4dmb 20060204220605 2     weak male voice
n8kam 20060204215928 3     full carrier with poss sstv. slight pause then followed by faint male voice
9h1jl 20060204215105 3     heard two short bursts of audio...not sure what language
ke4pwe 20060204214817 1     heard a maginal carrier on audio d 2sec shift of 5 nothing else
kc8wgn 20060204214259 1     squelch open and in the static sounded like voltage 8.6 very weak signal
kb0xa 20060204213825 1     145.990 heard very faint cw with tiny bursts of full quieting carrier
5r8ew 20060204210832 1     sqlch open tones cw and data bursts briefly.ic-pcr1000+13el.yag.+pre-ampl.
vu2roe 20060204210647 1     carriecr detected intermittently on maximum elevation, faint male voice about 1sec duration but unintelligible
usrob01 20060204205845 1     heard a quiet fwoom, fwoom, fwoom, fwoom
zs6tw 20060204205139 1     copy at nighttime and daytime - some parts of audio. little deviation on signal. measured 81 seconds between start of tx
nbx909 20060204204341 1     weak i heard some inaudiable but in a female voice from the static using a handheld aircaft radio scanner
cx1th 20060204204007 1     only carrier
n6pse 20060204201508 2     weak bursts of packet type noise on 145.990
wa6fxt 20060204200948 5     carrier only
kg6wxc 20060204200946 2     seeing/hearing carrier on 145.990, no voice, possible data tho
今天你还听宇航员讲话了......
离线老汉
只看该作者 3楼 发表于: 2006-02-05
接收频率145.990mhz,切记不要尝试发射??????????????
为什么?
离线bd4rs
只看该作者 4楼 发表于: 2006-02-05
[quote=老汉]接收频率145.990mhz,切记不要尝试发射??????????????
为什么?[/quote]
盖台是怎么回事.
离线BG4IGX
只看该作者 5楼 发表于: 2006-02-05
我用th48a,阳台外面的室外车载天线,没有收到.
离线bd4rs
只看该作者 6楼 发表于: 2006-02-05
听SuitSat说话的一次绝佳机会
在13个小时之后,将有一次绝佳听复活的宇航人讲话的机会.
打开你的短波,qq,msn,电话,设置好145.990我们一同来听听,看她都和我们说什么悄悄话.
从南京上空出现是2月6日的0206(bjt)开始持续5分44秒.
离线BD7TBP
只看该作者 7楼 发表于: 2006-02-05
请问用什么模式?
离线robotcat
只看该作者 8楼 发表于: 2006-02-05
是ssb吗?
离线汤圆
只看该作者 9楼 发表于: 2006-02-05
fm----------------------------
离线bd4rs
只看该作者 10楼 发表于: 2006-02-06
从南京上空出现是2月6日的02[表情]06(bjt)开始持续5分44秒.
0226开始的5分钟里没有听到信号.难道深夜又冻住了.得让明天的太阳晒晒.电池不知能用多久.
2月6日上午10:30还有一次过顶的机会.
离线bv2ac
只看该作者 11楼 发表于: 2006-02-06
哪一國做的電池 ? 再不出聲就把你扔進大氣層, 燒個精光....
离线BD6AHP
只看该作者 12楼 发表于: 2006-02-06
已经有消息称iss启动了repeater,现在上下行频率为145.990/437.800,也就是说开始中转suitsat的信号了,大家可以注意437.800(加多普勒修正)的信号.
祝大家好运!
注意:千万不要试图在145.990发射任何信号,您的发射会触发iss的repeater,从而盖住suitsat微弱的信号!
离线调频无限
只看该作者 13楼 发表于: 2006-02-06
听到啦!听到啦! 语音清晰!信号强烈!!
守听了一早上,全是的士佬的信号,tnnd!!!
离线bd4rs
只看该作者 14楼 发表于: 2006-02-06
还继续活着!
hp2bwj 20060206002919 1     se copio baja señal en panama
nevf 20060205225250 1     reporting a weak pale voice, received as scrambled and a loud amplified voice
n9sge 20060205220811     faint cw static voice. great experiment w/ my children! thanks!
wa2sms 20060205220552 1     a faint female voice in the static
nevfsat 20060205215632 1     heard a weak voice for about 3 seconds before losing full signal
zs6gc 20060205211413 1     signal on 145.985.3 usb. freq changes due to doppler fast.
pp8da 20060205205456 1     heavy qsb no data copied possible sstv transmission
ae6ts 20060205203302 2     brief cw burst
ke6ets 20060205201034 1     2 short bursts
g3zun 20060205200726 1     at 06.04.48 on 04.02.06 weak carrier signal heard for 4mins
k7xq 20060205191824     nothing heard fm mode, used eme array antenna
ve6bld 20060205191542   13 7.0 i have sent reordings of audio including telemetry to http://www.aj3u.com/blog/.
wd8krv 20060205190454 1     light voice believed heard just above squelch level on 5db gain vertical
n6rvc 20060205185404 1     weak doppler shifting carrier
ad7bk 20060205185218 2     i heard bursts of tones, and a voice but it was weak
ja7nmb 20060205175138 1     437.80mhz, weak beep and voice on mobile sets,japan,jst 02:01
py3vhq 20060205174839 1     weak signal, carrier no audio
py3vhq 20060205174726 1     weak signal, carrier no audio
kc5wjg 20060205173212 1     signal to week to understand it
kb5zcs 20060205173209 1     very weak,heard voices
yv5kxe 20060205173050 1     very weak intermitent carrier tone
wb5zkp 20060205173003 1     1 quick tone and a 2 sec voice bit about a minute later
xe3iss 20060205172818 1     very weak carrier
af2c 20060205172721 3     17:23 data 2 bursts, 1715 utc data, 1700 utc voice - hrd 437.8 mhz
xe2muo 20060205172457 1     very low beacon heard mixed with noise, lasted just 2 seconds
kc0rwz 20060205172210 3     437.975 male voice in what i believed to be russian, relatively strong through xband repeater but cut out and secs later appeared again briefly
berendo 20060205172151 1     short (<2 second) data burst faintly heard underneath static
kd7suu 20060205172051 0     faint cw in usb mode. some chattery sounding clicks.
rob 20060205172038 1     very weak, intermittent unintellagable voice, carrier on and off
w4tej 20060205171933 2     3 bursts of carrier, twice. hope it wasn't local tuner! (no data)
barkes 20060205171907 2     iss 437.8 mhz. sstv (1sec bursts) x 7 for 1 min. on handheld scanner
离线BG4UVR
只看该作者 15楼 发表于: 2006-02-06
ISS刚刚过顶,听iss在437.800转发的信号,干扰严重,听不清
离线BD6AHP
只看该作者 16楼 发表于: 2006-02-06
iss和suitsat刚过顶,最大角85°的完美过顶。
高兴的是在接近仰角40°时有一个明显的载波持续了2秒,并且是145.990/437.800同时发送的(145.990的有s3左右,437.800的要强得多),可以确定是suitsat的信号!
遗憾的是最不愿意听到的还是发生了:在过顶后的远离期间在437.800上一直有一个语音信号,而且是中文的“频率上……”、“没打开……”
就这样一个完美的过顶被耽误了,两天之内再也没有超过40°的过顶了……
强烈谴责这(数)位ham朋友,您的随意举动破坏了整个东亚和南亚的suitsat接收试验!
离线BD6AHP
只看该作者 17楼 发表于: 2006-02-06
对了,我的设备:tm241a+9el beam yagi(2m),ft60r+10 el yagi(0.7m)。
离线bd4rs
只看该作者 18楼 发表于: 2006-02-06
刚也听到437.800上有信号.并都录了下来.但我不确定是什么.
开始5秒之内肯定是一个声音,好象是英语.
之后的信号,我怀疑是有其他无关的信号上传到iss打下来的.
你们帮着听一下我上传的录音看是什么.
附件: iss-suitsat-0602061034-1.zip (0 K) 下载次数:1316
附件: iss-suitsat-5.zip (0 K) 下载次数:250
离线BG4UVR
只看该作者 19楼 发表于: 2006-02-06
你们帮着听一下我上传的录音看是什么.
和我听到的情况一模一样
