  • 6325阅读
  • 29回复
八重州VL-1000半导体龟 [复制链接]
离线BG4IHT
只看楼主 倒序阅读 0楼 发表于: 2005-12-09
那位在用vl-1000.好用吗
离线BA0BZ
只看该作者 1楼 发表于: 2005-12-10
官方宣传
http://www.yaesu.com/indexvs.cfm?cmd=displayproducts&prodcatid=102&encprodid=47zay%2bq1xfe%3d&divisionid=65&isarchived=0
ultra-conservative design
the vl-1000 is crafted with reliability as the #1 objective. extensive monitoring of heat, current, input drive, and other parameters allows the microprocessor to control the protection circuitry with lightning-fast response time. and the extensive heat sink design provides a huge margin of safety for the cooling of the pa and other components.
quad push-pull design
utilizing eight rugged mrf-150 mos fet power transistors in a four-module push-pull configuration, the yaesu design team has conquered the difficult challenge of providing high power output along with low spurious emission, along with high reliability.
automatic band change
when operating with most modern yaesu transceivers, band data information is transferred between the transceiver and the vl-1000, allowing automatic band change on the amplifier when you change bands on the transcevier. the vl-1000 also provides automatic band changing via a frequency-sensing circuit, when used with other exciters; just a press of the "f-set" key is required to detect the frequency and switch bands.
two input and four output jacks
ensuring easy integration into your multi-rig yaesu station, the vl-1000 includes two input jacks, along with four output (antenna) jacks. the microprocessor automatically selects the correct combination of connectors, according to your original setup, so you never have to be throwing switches when you change bands!
automatic antenna tuner
the built-in automatic antenna tuner is designed to smooth out minor impedance variations in your antenna system, ensuring full power output without placing the amplifier circuitry in danger due to excessive rf voltage. and unlike some solid state amplifiers, if you forget to turn the auto-tuner on but the amplifier encounters an swr somewhat over 2:1, the vl-1000 doesn't turn itself off! instead, it switches to low power (500 w) first, to let you try to make the contact. further power reduction will occur, of course, if a serious swr anomaly exists.
离线BA7KW
只看该作者 2楼 发表于: 2005-12-10
我的hk朋友在用
据说用起来还不错,就是对他的50mhz500w不是太喜欢
使用mrf150 8个,4对管,功放电路没什么特别。自己做不是很难,就是天调部分较难仿造。
离线BA0BZ
只看该作者 3楼 发表于: 2005-12-10
pa模块比较有特色的是使用4孔磁环,其实是当成两个独立的双孔磁环用,和其他pa的12.5:50双孔磁环输出变压器没有什么区别。
离线BD3RJ
只看该作者 4楼 发表于: 2005-12-10
老哥介绍一下天调部分吧.
离线BA0BZ
只看该作者 5楼 发表于: 2005-12-11
1. top view: power amplifier stage and low-pass filters
2. bottom view: heatsink and autotuner
3. controller board with 16-bit processor
4. the vp-1000 power supply, top view
离线关则勇
只看该作者 6楼 发表于: 2005-12-11
这台东西要3万几元哦,一个电源加功放,iht尽发些毒物上来毒人.打pp
离线BD3RJ
只看该作者 7楼 发表于: 2005-12-11
[quote=关则勇]这台东西要3万几元哦,一个电源加功放,iht尽发些毒物上来毒人.打pp[/quote]
为何比电子管的还贵???
离线BG4IHT
只看该作者 8楼 发表于: 2005-12-11
电子管的对天线驻波要求没有vl-1000那么高,听说1000超1.5就保护,tl-922和fl-2000俺有了,想搞个vl-1000,但不了解性能.望了解此鸡的朋友说说优缺点.
只看该作者 9楼 发表于: 2005-12-11
i家的pw1评价比较y家的vl1000要好点。
离线BG4IHT
只看该作者 10楼 发表于: 2005-12-11
听说jrc的3000很好,不知和pw1比怎样.
离线BA7NQ
只看该作者 11楼 发表于: 2005-12-11
摸过一下,机器比较娇气:
1)对供电、天线要求高,否则功率自己压下去
2)故障率高,往往要返厂修理
我还是喜欢电子管的,简单一些,也耐用。
离线BG4IHT
只看该作者 12楼 发表于: 2005-12-11
玩龟的高手评一下,让大家多多了解,谢谢!
离线vr2sa
只看该作者 13楼 发表于: 2007-06-28
hello kw,
sorry to tell you that 500w is applied to 110v ac version only, for 220v ac - export version, 1kw for hf and 6m both
i have one set and using for about 3 to 4 years already
quite quiet, a lot of sensivite protection - the antenna tunning unit tune at about 50ms step during your tx - that means if your yagi is down during the tx, the vl-1000 will still have swr protection and also tunning the minimum swr during your yagi in moving in the high wind etc
have one time tx for more than 2 to 3 hrs for ssb dx, the cooling fan kick in in different speed due to the pa ambient temp, it will stop or slow down if the pa temp is down again. more quite than ic-pw1
some minor issues, quite a lot of cables connection and you need to read the manual carefuly before you operate the vl-1000, once you did everything all ok, this is nice 1kw amplifier.
it can also work for non-yaesu transceiver- by f-key as it senses the tx frequency by internal frequency counter.
my overall marking is about 8 out of 10, as vl-1000 can not allow any over-drive and i have killed one power power - vp-1000 during excessive input of over 150w during the testing of the vl-1000 one hk ham qth.
vl-1000 is sensivite and dedicate amplifierand you need to take great care of it. once you getting use to that minor issues, vl-1000 is good 1kw amplifier
alfred kwok vr2sa
离线bd5ham
只看该作者 14楼 发表于: 2007-06-29
关注, iht 弄台来玩玩吧
离线BG4IHT
只看该作者 15楼 发表于: 2007-06-30
想玩pw1.
离线BA7KW
只看该作者 16楼 发表于: 2007-07-04
不要买石龟
想玩pw1.
我现在想买alpha-87,觉得那龟特别有味道。
离线BD3RJ
只看该作者 17楼 发表于: 2007-07-04
什么味??
离线BA0BZ
只看该作者 18楼 发表于: 2007-07-04
eimac味道
离线bg4dgj
只看该作者 19楼 发表于: 2008-05-11
昨天看见这家伙了
