  • 3677阅读
  • 1回复
这个呢? [复制链接]
离线BG2QAX
只看楼主 倒序阅读 0楼 发表于: 2002-10-14
离线BG2QAX
只看该作者 1楼 发表于: 2002-10-14
frequency range: 10-160 m + warc/6 m
voltage: +48 vdc, +12 vdc and -12 vdc from separate psu
current drain: 48 a @ +48v
2,8 a @ +12v
0.1 a @ -12v
drive power: max 80 w
maximum output power: 1 kw/500 w
dimensions (w*h*d): 410*135*439 mm
psu: 410*135*369 mm
weight: 21 kg
psu: 14.6 kg
manufactured: 19xx-200x
other: 8 x mrf150 mos-fets. built-in auto-at
related documents:
