  • 3418阅读
  • 5回复
如何寄比赛日记? [复制链接]
离线BA4VE
只看楼主 倒序阅读 0楼 发表于: 2005-11-19
如何寄比赛日记? 寄了几次都是出错 自动回复的内容为
(this is an automatic reply.)
your log submission to ssb@cqww.com could not be processed
because it did not contain a callsign in the subject line. please
resubmit your log to ssb@cqww.com and include the following
information in the subject line of your message:
     o the callsign you used in the contest
your subject line should read something like: tg9/n5ko low power
if you believe you have received this message in error or if you are
submitting a log for a special callsign (such as a 1x1 call like m6t),
please contact me at questions@cqww.com to make alternate arrangements.
thanks for your cooperation.
73,
bob, k3est
cq ww director
se tiver alguma diculdade em perceber esta mensagem por favor
contacte: ct1boh@sapo.pt
si vous ne saisissez pas le sens de ce message, contactez:
f6bee@aol.com
se questo messaggio non ti e' chiaro, contattami a questo indirizzo:
i2uiy@cqww.com
wenn sie probleme haben, diese nachricht zu verstehen, kontaktieren
sie bitte dl6rai@cqww.com
para cualquier duda sobre el contenido de este mensaje, por favor
contacta con: ea3du@cqww.com
v primeru, da imate kakrsnekoli tezave pri posiljanju dnevnikov
oziroma ne razumete sporocila robota, kontaktirajte: s50a@cqww.com
u slucaju, da imate problema sa slanjem dnevnika ili ne razumete
poruke robota, kontaktirajte: s50a@cqww.com
jos et ymmarra tata viestia, ota yhteys jormaan, oh2ki@cqww.com
mosi,korerano era- ni kansuru houkokuni,donoyouni taiousuruka fumeinabaai ha,
ja no kontesutoiin dearu je1cka<je1cka@cqww.com> made, kono era- messe-zi to
tomoni otoiawasekudasai
离线BG7KFY
只看该作者 1楼 发表于: 2005-11-19
用呼号做email主题,附件是呼号名的log就无问题。
离线BG7KFY
只看该作者 2楼 发表于: 2005-11-19
我第一次打回头是 all low 后面多了一个字,删了就没事,信中有说我模式不合理。
离线BA4VE
只看该作者 3楼 发表于: 2005-11-19
谢谢你的回复 找到原因了   我用126。com发就有错 但我换了yahoo。com。cn
发就不出错了   可能是邮箱的问题
离线BG1DRJ
只看该作者 4楼 发表于: 2005-11-19
恭喜恭喜!
邮箱害死人哦,呵呵
离线BA4VE
只看该作者 5楼 发表于: 2005-11-19
是呀   呵呵 脑子太笨了 没早想起换邮箱
