  • 3964阅读
  • 9回复
HF To 6M DX CALLING FREQUENCIES [复制链接]
离线ba2at
只看楼主 倒序阅读 0楼 发表于: 2005-10-30
calling frequencies
, dxpedition, ssb, cw, am, fm, rtty, sstv
这是hf至50兆各种模式的dx呼叫频率或者称为dx window,如果我们仔细研究一下,可以看出,不同的操作模式dx 呼叫频率都有一定的规定,并不是我们随意使用的。因为crsa并没有给出我们详尽的频段划分,因此喜爱做dx的朋友,一定要熟悉这些频率使用规定,对于做dx非常有价值,另一方面熟悉了这些约定俗成的规定,就不会无意识地干扰了他人的正常工作。由于文字很简洁,大家都能看懂,因此没有翻译。有条件的可以存到电台上,方便使用。
note: by tradition, 20m and up is upper sideband, 40m and below is lower sideband. an exception is the new 60m ham band -- use usb. this protocol came about as a matter of convenience in early ssb transceiver design and has remained to this day. and yes - you can operate either sideband legally where phone is allowed. and yes you can operate cw on the phone bands -- but best stay with the protocols. see url:
considerate operator freq guide
and url:
usa amateur radio band plans
160 meters
1.810 qrp calling frequency
1828.5 -- dxpeditions cw operations are frequently here
1.830-1.840 cw, rtty and other narrowband modes, intercontinental qsos only
1.840-1.850 cw, ssb, sstv and other wideband modes, intercontinental qsos only
psk31
80/75 meters
3.500-3.510 cw dx window
3.505 dxpeditions cw are frequently here
3.560 qrp calling frequency
3.590 rtty dx
3.790-3.800 ssb dx window
3.71 qrp novice/tech cw calling freq
3.845 sstv
3.885 am calling frequency
3.799 dxpeditions ssb are frequently here
3.985 qrp ssb calling frequency
psk31
60 meters -- see arrl website
40 meters
7.000 - 7.010 cw dx window
7037 pactor calling frequency
7.040 rtty dx
7.050 xtal controlled rigs
7.290 am
7.065 dxpedition ssb usa split to 7.150 and above
7.005 dxpeditions cw are frequently here
7.110 qrp novice/tech cw calling frequency
7.171 sstv
7.285 qrp calling frequency
7.290 am calling frequency
psk31
30 meters
10.106 qrp cw calling frequency
10.110 -- dxpeditions cw are frequently here
psk31
20 meters
14.025 dxpedition cw freq -- usually split
14.060 qrp calling frequency
14.080 dxpedition rtty freq
14.080 to 14.100 primary range for rtty
14.100 ncdxf beacons (stay off of this frequency) many hams rely on these beacons for propagation determination. for details - see ncdxf/iaru international beacon network
14.195 rare dx & dxpeditions frequently operate ssb here -- generally listening up-split
14.230, 14233, 14236 sstv
14.285 qrp calling frequency
14.286 am calling frequency
14.336 mhz county hunters when ever 20 is open and mobiles are around
psk31
17 meters
18.075 dxpeditions cw are frequently here -- usually split
18.110 ncdxf beacons (stay off of this frequency) many hams rely on these beacons for propagation determination. for details - see ncdxf/iaru international beacon network
18.145 dxpeditions ssb are frequently here -- usually split
psk31
15 meters
21.025 rare dx & dxpeditions frequently operate cw here - generally listening up-split
21.060 qrp cw calling frequency
21.080 to 21.100 rtty primary range
21.080 rtty dxpeditions are frequently here
21.150 ncdxf/iaru beacons (stay off of this frequency) many hams rely on these beacons for propagation determination. for details - see ncdxf/iaru international beacon network
21.295 rare dx & dxpeditions frequently operate ssb here -- generally listening up-split
21.340, 21430 sstv
21.385 qrp ssb calling frequency
psk31
12 meters
24.895 rare dx & dxpeditions frequently operate cw here -- generally listening up-split
24.930 ncdxf beacons (stay off of this frequency) many hams rely on these beacons for propagation determination. for details - see ncdxf/iaru international beacon network
24.945 rare dx & dxpeditions frequently operate ssb here -- generally listening up-split
psk31
10 meters
28.025 cw rare dx & dxpeditions frequently operate here ?split
28.060 qrp cw calling frequency
28.080 rtty rare dx & dxpeditions frequently operate here -- split
28.080 to 28.100 primary range for rtty
28.1010 10/10 intl cw calling frequency
28.120-28.300 beacons
28.200 ncdxf/iaru beacons (stay off of this frequency) many hams rely on these beacons for propagation determination. for details - see ncdxf/iaru international beacon network
28.380 10/10 ssb intl calling frequency
28.385 qrp ssb calling frequency
28.425 10/10 ssb intl calling frequency ?another is 28.400
28.495 ssb rare dx & dxpeditions frequently operate here -- split
28.600 old general callin frequency - still used by old timers
28.675~28.685 sstv operating frequency -- iaru region 1
28.680 sstv operations usa/canada
28.825 10-10 backskatter net - paper chasers net
28.885 6m dx liaison frequency -- listen here for 6 meter dx opening announcements and discussions.
28.945 fax operating frequency
29.000-29.200 am operations
29.300-29.510 satellite downlinks
29.520-29.580 repeater inputs
29.600 fm simplex - calling frequency
29.620-29.680 repeater outputs
psk31
six meter frequencies
50.06-50.09 beacons
50.0-50.1 cw
50.090 cw calling freq
50.7 rtty calling frequency
50.100 to 50.130 dx window (usb)
50.110 dx calling frequency (usb) usually non-usa stations call here.
50.115 dxpeditions frequently operate cw and ssb here
50.125 usa national ssb simplex frequency (usb) lots of usa hams call here for local and across country
50.1-50.6 weak signal, am
50.300 fm simplex calling frequency (west coast)
50.385 usb psk31
50.4 national am simplex frequency
51.910 fm internet linking
52.525 national fm simplex calling frequency
6 meter simplex frequencies --51.500 51.520 51.540 51.560 51.580 51.600 52.490 52.510 52.525* 52.540   52.550 52.570 52.590
离线BG4IJL
只看该作者 1楼 发表于: 2005-10-30
..........约定俗成的规定........
请教:上述约定俗成的usb规定是不是仅限美国本土的模式?谢谢,73!
离线BG4IJL
只看该作者 2楼 发表于: 2005-12-04
最近留心观察了leg5的6米段dx通联日志,发现(美国等)喜欢通联dx的火腿有意让出了50。110的频率给我们使用。能用语音(cw mode除外)通联欧洲?哈哈,真象是在做梦的感觉。on air ,73!
离线BG4IJL
只看该作者 3楼 发表于: 2005-12-04
补充:
美国最新的6米dx:50.125mhz。73!
离线BA5UA
只看该作者 4楼 发表于: 2005-12-04
50mhz作为共用频段,我常在50.125左右作dx通信已经很久了。
离线BA5UA
只看该作者 5楼 发表于: 2005-12-04
在此,我送上两份93年的cq ham radio的频普表,供大家参考使用。
离线BG4IJL
只看该作者 6楼 发表于: 2005-12-05
6米波段我很有兴趣,介绍一下您的天线和设备的情况,能上传关于dx(季节)资料供我们参考吗?谢谢,73!
离线BA5UA
只看该作者 7楼 发表于: 2005-12-19
sorry,我比较少上来,所以没能及时回。
ok, 谢谢关注,我所用的机器是非常老旧的yaesu ft-620的50兆单波段机器,插晶体的。输出功率最大只有15w,可以工作在ssb和cw模式,虽然是很老的机器,但很好用。所用的天线是hb9cv的三波段缩短天线,架在约18米高的铁塔上带旋转器。
在我这一般通联较好的时间是从每年的春夏交接的季节开始就会有传播了,早的时候春季就偶尔会有,这样一直延续到夏秋季才慢慢结束,冬季我是从来没在六米波上做过qso的。
到时注意50.015左右会有个日本的信标台在这上面工作,发出一连串的包含ja1台标在内的cw信号,我想山东那边应该能收到的。但还是要看es活跃电离层的活动情况,如果es层开通的话,通联效果是非常好的,有时可以和本地区的2米、0.7米波的通联情况相比美。祝你成功!!!!
离线huashao128
只看该作者 8楼 发表于: 2005-12-19
现在6米连个信号都没有,倒是45-49有很强的信号--------无绳电话。^_^
离线BA5UA
只看该作者 9楼 发表于: 2005-12-20
呵呵 ,这个时候,,,,,,,应该不会有6米的传播呀,至少在我这。。。。
