  • 5148阅读
  • 10回复
bd3nc请进!先创145接驳器和GM300怎么对接? [复制链接]
离线世纪
只看楼主 倒序阅读 0楼 发表于: 2005-10-21
应该有的我都有了,就是没研究出怎么接他 哈哈!
我搞个图您帮我连接一下!
每组接头我都写在上面了
http://www.hellocq.net/forum/attachment.php?attachmentid=89951&stc=1
8信道GM300接口:
8 channel units
pin 1 = int spkr megative (not gnd)
pin 2 = mic audio, 80mv for 60%dev
pin 3 = mic ptt
pin 4 = not used
pin 5 = flat tx audio, 150mv for 60%dev
pin 6 = not used
pin 7 = gnd
pin 8 = cor active low ruindicator follows tone if used.
pin 9 = not used
pin 10 = ign control
pin 11 = disc audio, 600mv controlled by ju551
pin 12 = not used
pin 13 = sw a+ 1/2 amp max!
pin 14 = remote hook sw
pin 15 = int spkr pos
pin 16 = ext spkr pos
16信道GM300接口:
same as above except:
pin 4 = programmable output defaults to external alarm.
pins 6,8,9,12,14 = programmable i/o (the options can be viewed with the rss)
中继连线:
based on the above information this is how the cross-connection between the radios should go!
radio1 radio2
pin 3 ptt ___________________ pin 8 cor
pin 8 cor ___________________ pin 3 ptt
pin 5 tx audio ___________________ pin 11 disc audio
pin 11 disc audio ___________________ pin 5 tx audio
pin 7 gnd ___________________ pin 7 gnd
**** caution **** check to see the programable outputs of the 16 pin connector prior to hooking up. also, the 5 pin radios will not do this because you can't get cos and ptt outputs.
以上资料表明,16信道与8信道GM300的接口是有区别的,就是有些引脚功能是可以通过编程定义的,这些脚中,与中继有关的只有8脚。所以请检查是否8脚被定义为别的功能了。
另外,我记忆中,GM300做中继使用,似乎需要短接话筒接口的2脚与6脚。
下图左侧为16信道的GM300接口图,右侧为8信道的GM300接口图。
http://www.hellocq.net/forum/attachment.php?attachmentid=122696&stc=1
gm300 16信道
引脚序号 英文 中文
1 external speaker negative
2 microphone audio 80mv rms @60% deviation 外部话筒音频输入 80mv 60%调制度
3 microphone ptt 外部话筒ptt控制
4 programmable output 可编程的功能输出口
5 flat transmit audio 150mv rms @60% deviation 末级发射音频输入 150mv
6 programmable input 可编程的功能输入口
7 ground 接地
8 programmable output/input 可编程的功能输入口和输出口
9 programmable input 可编程的功能输入口
10 ignition control input 点火控制输入
11 discriminator audio output 600mv rms @60% deviation 检频输出 600mv(机器内部选择)
12 programmable output/input 可编程的功能输入口和输出口
13 switch a+ sense 0.5amps max 经过开关控制的电源输出(最大0.5a)
14 programmable output/input 挂机开关输入
15 internal speaker positive
16 external speaker positive
离线bd3nc
只看该作者 1楼 发表于: 2005-10-21
145只可以单向中转,把原来接收机和接收机的接线全部截断,按图中的提示接线即可~但是要按说明书中的说明调试才可以很好的使用。ptt应当按发射机的控制方式选接。
离线世纪
只看该作者 2楼 发表于: 2005-10-22
按你的方法接的,有信号时145的carrier灯亮但是不转发!
直接把7和10接接在一起不通过145控制时转发出的是断续的声音不是语音信号!
离线bd3nc
只看该作者 3楼 发表于: 2005-10-22
你还要检查一下145的设置,看他的上线方式是哪一种,根据不同的上线方式要发射一个不同的双音频信号,比如*+ain   1+ain 2+ain 等等等等
离线世纪
只看该作者 4楼 发表于: 2005-10-22
问题是我现在不会设置145! 那个zcom的软件看不明白,我用超级终端进去可以看的里面的东西!
离线bd3nc
只看该作者 5楼 发表于: 2005-10-22
[quote=世纪]问题是我现在不会设置145! 那个zcom的软件看不明白,我用超级终端进去可以看的里面的东西![/quote]
你用这个试试~~
附件: 145.rar (0 K) 下载次数:326
附件: 145.doc (0 K) 下载次数:543
离线bd3nc
只看该作者 6楼 发表于: 2005-10-22
其实,那个东西并不复杂~你可以对照中文一步一步地~或者干脆你把你的要求告诉我(比如有几个用户各个用户的权限,还有上线方式等)我替你设置一下然后把设置的文件*.coo发给你,你直接导入到145中就可以~~那个doc文档是我按照阿甘的那个编程手册编写的,可能有一些错误但大致可以给你一些帮助。
离线世纪
只看该作者 7楼 发表于: 2005-10-22
coo文件怎么写到145里? 我只需要象普通中继一样正常转发! 我自己可以控制rpt开关,可以用dtmf 上线打出电话! 有电话的时候不提示,我需要接听才可以通话!
离线世纪
只看该作者 8楼 发表于: 2005-10-22
没办法! 复位了全部东西现在还是只有carrier灯亮但是不转发!
离线世纪
只看该作者 9楼 发表于: 2005-10-22
现在进测试,tx有声音出来了! 可能还是设置的问题
离线bd3nc
只看该作者 10楼 发表于: 2005-10-24
嘿嘿~有些不好意思,~~最近一直在准备考试~~没有经常到这里来~所以就没有及时回你的帖子~~
如果你恢复了设置它的默认上线模式是先创1模式~你可以参考我的那份说明使用
