  • 5128阅读
  • 5回复
求健伍 TM-733A 车台资料! [复制链接]
离线神秘色彩
只看楼主 倒序阅读 0楼 发表于: 2005-10-06
刚刚从helloco.com论坛(http://www.hellocq.com/cgi-bin/topic.cgi?forum=18&topic=50497&start=0&show=0) 花近2400大洋(加上换了一个s-av17模块)购入健伍 tm-733a,由于是第一次接触该机(心仪很久了所以不计成本)一些功能不会用,所以请朋友们积极贡献健伍 733a 的资料、使用心得,以便大家学习、交流。
谢谢
离线神秘色彩
只看该作者 1楼 发表于: 2005-10-07
在网上找到 e 文的,不懂。
kenwood "tm-733a"   (quick reference guide )zp5fgs4-sep-2001
[key] = press and release key
[key1]+[key2] = press and hold key1 down, then press key2.
[key1], [key2] = press key1 momentarily, release it, then press key2.
[key]+[pwron] = press and hold key , then turn transceiver on pressing pwr.
[key1]+[key2]+[pwron] = press and hold both, key1 and key2 , then turn transceiver on pressing pwr.
[f] (1s) = press and hold the function key until the "f" indicator on the display begins blinking.
[key] (1s) = press and hold key until the function begins.
[f], [key] (1s) = press [f] momentarily, release it, then press and hold key for 1 second.
it.   operation procedure & other information
1squelch (noise)operated with the concentric rings.
2squelch (automatic)[mhz]+pwron(toggles aut.squelch on or off) >   [f]+[dim] to set threshold.
3squelch (smeter)[f](1s),[s.sql](toggles smetersquelch on or off)
4squelch (sm-hang time)[f]+[dim](current hang time appears)
5vhf / uhf channel ratio[f]+[mr]+pwron >tune > [mr] to store
6vhf / vhf operationselect uhf band, press [vfo],[mr] > press [f],[contsel]
7uhf / uhf operationselect vhf band, press [vfo],[mr] > press [f],[contsel]
8blanking band display[f](1s),[bandsel] (toggles each band on or off)
9am / fm mode[mhz] (1s)(toggles between am or fm, a "spade"appears in am mode)
10mute[mute] (toggles this function on or off) ,   "mute" is displayed.
11tx power select[low] repeatedly to select: "high" >(50/35w,no indicator) - "m">10w - "l" > 5w
12frequency step[f],[step]     size appears: " 5, 10, 15, 20, 12.5, 25 " > select with up/dwn or tune.
13mhz step[mhz]   (tune the mhz display)
1410mhz step[mhz]+[mhz]   (tune the 10 mhz display)
15memory storing[f] > select channel nr. > [mr]
16memory sto (split)tune rxfreq, > [f] >select memnr.>[mr](1s) > "+ -" appears, tunetxfreq > [mr]
17memory to vfo[f], [vfo]   (previously select any memory or call channel to tranfer to vfo)
18call channel sto[f], [c.in]   (previously select band, freq. and other data)
19call ch. split stotune rxfreq, > [f], [c.in] (1s)   >"+ -" appears,tunetxfreq > [call]
20channel display[rev]+pwron (toggles channel display function on or off)
21prog.memory sto.rig in vfo mode > [f], [pm] > press buttons [1] to [6] in which to store data.
22prog.memory recall[pm] > press buttons [1] to [6] from which to recall data.
23prog.memory erase[f], [pm] > select(tune)to move the brackets to the pm (1 to 6) to erase >
24cont. ---->   press button of bracketed number to erase > "ok?ok-mr key" appears > [mr].
25prog.memory reset[f]+[pm]+pwron > "ok?ok-mr key" appears > press [mr].
26band limits (affects vfo)[f]+[c.in] "l" appears, > tune lower limit > [mr] to store (then store upper limit same way)
27scan limits (lower/upper)[f]+[vfo] "l" appears, > tune lower limit > [mr] to store (then store upper limit same way)
  - - - - - - -   cont. - - - -> (use [mhz] to change in mhz steps).]
28scan limits (confirm)[f]+[vfo] >the lower limit appears > [mr] the upper limit appears (exit:[f] or [ptt].
29memory scan[mr](1s) >(the 1 mhz decimal and the contsel led blink) (up or dwn to reverse scan direction)
30band scan[vfo] (1s) >(the 1 mhz decimal and the contsel led blink) (up or dwn to reverse scan direction)
31band scan (programmable)[vfo] (1s) > same as band scan, but must tune start between scan limits.
32mhz scanwhile bandscan or prog.bandscan, press [mhz] (scans the mhz lap of the current freq.).
33call/vfo - scan[call] (1s), in vfo mode (to cancel press [ptt] or [bandsel] for the band being scanned).
34call/memory - scan[call] (1s), in mr mode (to cancel press [ptt] or [bandsel] for the band being scanned).
35aut.power off[f](1s), [mhz](toggles a.p.o. on or off)(to restore power after time out, press [pwr] twice).
36time out timer[f](1s),[tot]select from "off to 3, 5, 10, 20, 30" minutes
37adv. intercept point[f]+ [a.b.c.](toggles a.i.p. on or off)(the 10 khz decimal ponit appears with a.i.p.)
38aut. simplex checker[rev] (1s)     (to cancel press [rev] )
39aut. band change[f], [a.b.c.](toggles a.b.c. on or off)(pressing [bandsel] cancels a.b.c.
40dimmer select[f], [dim]> tune (or up/dwn) to select from "off" to "d1"
41aut. dimmer change[f]+[low]+pwron   (toggles the function on or off).
42beep control[f](1s), [beep]> tune (or up/dwn) to select from "off" to "b7"
43show - off mode !![call]+pwron (to toggle this function on or off).
44tone select[f](1s), [t.sel]
45tone alert[f], [t.alt] (toggles this function on or off).(a "h" appears). [ptt] or [mhz] to exit.
46aut.tone freq. id[tone] (1s) (toggles function on or off). ([tone] cancels function and adopts identified tone freq.).
47alarm tone change[f]+[shift]+pwron   > tune (or up/dwn) to select from "bel 1" to "bel 3"
48ctcsspress [tone] until "ct" appears.(tsu-8 must be installed).
49transmit band lock[f],[bandsel](100khz decimal point appears) ( [pf] and [bandsel] only change control band).
50transceiver lock[f],[mhz] (toggles between on and off) ,   "lock" appears when on.
51all lock[f],[mhz] ("lock" appears), > [pwr] (to switch off), > [mhz]+[pwron] ("a.lock" appears).
52partial reset (single band)[vfo]+[bandsel]+[pwron] (selected band resets to default settings).
53partial reset (both bands)[vfo]+[pwron] (hold [vfo] until a beep is heard > resets all settings except memory, call, pm.).
54full reset exc. prg.mem.[mr]+{pwron] ("ok?ok-mr key"), >[f] (pm nr. dissapear), > [mr] (beeps and reset).
55full reset incl. prg.mem.[mr]+{pwron] ("ok?ok-mr key"), > [mr] (beeps and reset). (any button except [f] to cancel).
离线BG7IMJ
只看该作者 2楼 发表于: 2005-10-07
kenwood
离线神秘色彩
只看该作者 3楼 发表于: 2005-10-11
离线BG7IMJ
只看该作者 4楼 发表于: 2005-10-11
暈死!!!! 點擊3樓就有啦。 :d
离线神秘色彩
只看该作者 5楼 发表于: 2005-10-13
暈死!!!! [表情] [表情] 點擊3樓就有啦。 :d [表情] [表情] [表情]
