  • 6355阅读
  • 7回复
[求助] MOTOROLA Radius P50 的写频问题?? [复制链接]
离线BG7QBK
只看楼主 倒序阅读 0楼 发表于: 2005-10-01
我有一台moto的对讲机,型号: motorola radius p50
请问他的写频接口是在什么地方??用什么样的写频器可以写它?
离线BG7QBK
只看该作者 1楼 发表于: 2005-10-01
the p50 is not a synthesized radio and therefore is not programmable. use these charts to set the pl or dpl frequency.
the p50+ programmer should be the same pinout as the p100. just put the data line to the contact on the pl/dtmf board and the ground to the -battery clip. this is only a programming interface to the accessory board and programs pl,dpl,dtmf info. no channels can be changed as it is not synthesized either.
another note on the p50+ is that "full-line" motorola dealers sold a version known as the ht-10 which uses the same programming adapter but uses its own unique software and has a tan case.
我找到了以上这些资料,不知是什么意思~~~~~~~~
来源: http://216.232.87.119/p50plus.html
离线BG7QBK
只看该作者 2楼 发表于: 2005-10-02
呵呵,我已经找到资料了,贴出来和大家分享!~~~~~~
the formulae for calculating the crystal frequencies are as follows:
uhf
  receive
      fc = 8fo - 21.4mhz (403-430mhz)
      fc = 8fo + 21.4mhz (440-512mhz)
      where fc = desired carrier frequency
          fo = first oscillator (crystal) frequency
  transmit
      fo = fc / 27
      where fo = crystal frequency
vhf
  receive
      fc = 3fo + 17.9mhz (136-174mhz)
          fo = first oscillator frequency
  transmit
      fo = fc / 9
离线蓝梦祥
只看该作者 3楼 发表于: 2005-10-04
翻译一下。!!!!!!!!!!!!!!1
离线BG2ISM
只看该作者 4楼 发表于: 2011-12-22
还是不知道如何写频
离线bg8wp
只看该作者 5楼 发表于: 2011-12-30
晶体置频的
离线BG6QAM
只看该作者 6楼 发表于: 2012-03-06
P50微调频率怎么做到?
的p50是不是合成的电台,因此是不可编程的。使用这些图表设置的pl或dpl频率 的p50 +程序员应该作为p100的相同的引脚。只要把数据线的pl / dtmf板和地面接触的电池夹。这仅仅是一个编程接口附件板和方案的pl,在dpl,dtmf信息。没有通道可以被改变为它是不是合成或者。 另一个在p50的+的注意,“全线”摩托罗拉经销商出售被称为的羟色胺-10它采用了相同的编程适配器,但使用其自己独特的软件1版本,并有一个黄褐色
bg7qbk      2005-10-02 21:44
呵呵,我已经找到别名了,贴出来和大家1 album更多〜〜〜〜〜〜! 晶体频率计算公式如下: uhf 接收 fc = 8fo - 21.4mhz(403-430mhz的) fc = 8fo + 21.4mhz (440-512mhz) fc =所需的载波频率 fo =第一振荡器(晶体)频率 发送 fo = fc / 27 fo =晶体频率 fc =所需的载波频率 vhf 接收 fc = 3fo 17.9mhz(136-174mhz), 其中fc =所需的载波频率 fo =第一振荡器频率 发送 fo = fc / 9 fc =所需的载波频率 fo =晶体频率
http://wenku.baidu.com/view/0c47d2c74028915f804dc286.html
离线BG6QAM
只看该作者 7楼 发表于: 2012-03-08
motorola p50 p10置频
在u段
用晶体置频,收发各有一个晶体 如410.000,分别标注410.000t,410.000r
虽然标注频率fc一样,但实际晶体基频f0不同。
接收晶体 如果在u低端 加21.4中频 除以8倍 410.000-21.4   /8=54.25
在u高端同样晶体频率就是   乘以8倍加21.4中频     54.25*8+21.4=455.4
(需要调整选频回路功放回路要不要调整就不清楚,因为不知pa电路是否是整个u段的)
发射晶体 就是27倍频需要除以27   410.000/27=15.185185
由于收发电路不同,同标注为410.000t,410.000r的基频也不同
接收晶体基频为54.25,发射基频为15.185185
收发晶体不能互换
频率微调则调整晶体附近的电容,频率隔得太远就得换晶体。
这样高稳定的晶体定做很贵
