  • 4170阅读
  • 6回复
旁路电容选择与应用(转自qrp-l) [复制链接]
离线BD6CR
只看楼主 倒序阅读 0楼 发表于: 2002-10-10
subject: bypass capacitors choice and applications
date: wed oct 09 2002 - 1922 edt
next message: mark fields: "ot: laptop computer problem"
previous message: kd5nwa: "re: serial cw sender kit - new, improved & shipping!"
good question richard,
here is what my elmers have said over the years. also, like you, i have
learned by observation of what was successfully used in various circuits.
now the general rule of thumb in picking coupling capacitor values is to
pick it large enough to pass the frequency of interest with a capacitor
reactance acting on the signal voltage at a value of 1/10 the circuit
impedance, thus passing the signal with minimal attenuation. you can get by
with larger reactance in some cases.
larger capacitance passes lower frequencies better, and so on. the formula
for capacitive reactance will show you this by inserting some trial numbers
for frequency. the reactance charts in older arrl handbooks or other
references such as the itt radio engineers handbook easily show the effect
of varying the capacitor value.
the same consideration is used for bypass capacitors. you either want to
pass all or most of the frequency to ground or common, or at least have that
path be only 1/10 the impedance of the circuit you are taming by the use of
the bypass. in other words, you want enough capacitance to short out the
frequencies of interest. for example, you want an rf path around a cathode
resistor, or an emitter resistor, so as to not attenuate the rf signal.
however, for bypass as well as coupling, the type of capacitor comes into
play for frequency considerations, as you touch upon. you do not want the
capacitor to resonate at the frequencies present.
thus, a rolled foil cap, such as the plastic tubulars might not be the
choice for rf circuits, where the rolled foil looks inductive. ceramic
capacitors are parallel plates, with dielectric layers, and thus are
preferred in rf circuit bypassing. the wide range of bypass values
developed from the use of smaller amounts of capacitance, such as 0.001 or
0.005 mf in tube circuit days when impedances were higher, or in high
impedance fet circuits.
audio and ac /dc power supplies are bypassed with electrolytic capacitors.
the "filter" capacitors in typical rectifier output filters are bypasses for
the ac ripple at 120 hz and 180 hz or whatever is left after the ac line is
rectified.
the values like 0.01 and 0.1 microfarad or even 10 mf are found in lower
impedance circuits typical of transistors. combined 0.01 and 0.1 are an
attempt (in parallel) to provide a low impedance bypass over a wider
frequency range than that of one capacitor alone. as stated above, old tube
circuits will bypass rf with 0.001 and 0.005 microfarad capacitors. in more
recent times use of the term nano farad has become popular, but with correct
movement of the decimal point, you can see the same capacitor noted as so
many (fraction of) microfarads in older literature.
that pretty much is it. you pick capacitors from manufacturers catalogs
that have low esr (equivalent series resistance) and low ohms of reactance
when you want bypasses. esr comes into play for audio and power supply
applications. capacitive reactance is a component of rf circuit impedance
and must be considered to find the capacitance suited to the rf bypass job
at hand.
reactance charts, (when you know or can guess closely the circuit
impedances) are a quick way of picking a capacitor value to pass a
frequency. knowledge of the preferred frequency ranges of certain types of
capacitor construction completes the knowledge base you need to pick
effective bypass capacitors.
finally, don't forget to consider the circuit dc voltage and the impressed
ac (rf) voltage when picking the voltage rating of the selected capacitance
value. in most transistor circuits today, anything over the dc power supply
voltage should be adequate until you get to high power rf stages, where you
might consider if the rf voltage is being raised by doubling, or by
modulation, in the case of am amplifiers.
72, stuart k5kvh
离线BG7IBQ
只看该作者 1楼 发表于: 2002-10-11
有没有中文的?
离线列兵
只看该作者 2楼 发表于: 2002-10-13
Re: 旁路电容选择与应用(转自qrp-l)
[quote]原作者 bd6cr
机器翻译的结果如下:
旁路电容选择与应用 ( 转自qrp - l)
主题: 支路电容器选择和应用
从: 斯图尔特 rohre ( rohre@arlut.utexas.edu)
日期: 星期三2002-19:56:22 年10月09 日美国东部夏令时间
下一条消息: 马克领域: "ot: 膝上电脑问题"
以前的消息: kd5nwa: "重新: 连续的cw 发送人工具 - 新,改进,装运! "
好问题理查德,
这是我的elmers 已经说多年的。 此外,喜欢你,我从观察被成功在各种各样的电路内使用的中学习。
现在那些一般经验法则在挑选耦合电容器价值对挑大得足以用一个电容器通过所关心的频率的它在1/10 的价值按照信号电压行动的电抗这条电路阻抗,因此用最小的衰减通过信号。 你能通过由于更大的电抗有时候。
更大的电容量更好地通过更低的频率,等等。 公式对于容性电抗来说将通过插入一些审讯数目让你看这针对频率。 在或者其他更旧的arrl 手册里的电抗图表参考,例如itt 收音机工程师手册,容易显示影响改变电容器价值。
相同的考虑用于支路电容器。 或者你想要递给全部或者频率中大多数给或者普通的场地,或者至少有那道路1/10 你使用鞣的电路的阻抗只支路。 换句话说,你想要足够的电容量短路所关心的频率。 例如,你在阴极周围想要一条rf 道路电阻器或者一台发射极电阻器,以便不衰减rf 信号。
但是,适合支路和连合,这类电容器进入为频率考虑玩,因为你接触在上。 你不想要要在在场的频率使产生共鸣的电容器。
因此,例如那些塑料tubulars,滚箔的帽子可能没rf 电路的选择,滚的箔看起来感应。 陶器有介质层,电容器平行镀,因此用rf 电路更喜欢为设旁路。 多种支路价值从少量电容量的使用中发展,例如0.001 或者0.005 mf 在管周阻抗更高的日子,或者在高里阻抗fet 电路。
声频和ac / 直流电源被电解的电容器绕过。
那些" 过滤器",以致于电容器在典型改正者产量过滤器内支路岁为以120 赫兹和180 赫兹的ac 涟漪或者无论被留下什么,在交流线路是之后纠正。
象0.01 和0.1 微法或者甚至10 mf 一样的价值被在更低里发现典型晶体管的阻抗电路。 结合的0.01 和0.1 是a( 并联) 试图提供低阻抗支路越过一宽频率范围比单单的一个电容器那。 如上所述,旧的管电路将有0.001 和0.005 个微法电容器为rf 设旁路。 在更多里新近的时代使用时期nano 法已经变得受欢迎,但是用正确小数点的运动,你能看见相同的电容器被那么如此注意到在更老的文学方面的很多( 小部分) 微法。
那漂亮的非常是它。 你从制造商目录那里挑电容器那有电抗的低的esr( 相等的系列电阻) 和低的欧姆当你想要支路时。 esr 为声频和电源开始活动应用。 容性电抗是一个rf 电路阻抗的组成部分并且必须被认为发现电容量适合rf 支路工作在附近。
电抗图表,( 当你知道或者能仔细猜测这条电路时阻抗) 一迅速抠一电容器价值通过a 的路频率。 某些类型的被更喜欢的频率范围的知识电容器建设完成你需要挑的知识库有效的支路电容器。
最后,不要忘记考虑电路直流电压和给留下印象当挑选被选择的电容量的电压等级时, ac( rf) 电压估价。 今天在大多数晶体管电路内,在直流电源上方的任何事情电压应该是足够的,直到你到达高功率rf 阶段,在哪里你考虑可能那些rf 电压被通过使被引起加倍,或者由于就调幅放大器而论,调制。
72,斯图尔特 k5kvh
_ _ _ _ _ _ _ _ _ _ _ _ _ _
离线hocool
只看该作者 3楼 发表于: 2006-10-30
定1234534535
离线BG5HRG
只看该作者 4楼 发表于: 2006-10-30
机器翻译果然还是很有问题的,like you变成了喜欢你
离线bellstudio
只看该作者 5楼 发表于: 2006-10-30
这机器翻译的。。。。。
离线SunDK
只看该作者 6楼 发表于: 2006-10-31
可否告诉是用什么软件翻译的?
