  • 8659阅读
  • 47回复
这周末有参加全亚洲竞赛的吗? [复制链接]
离线child@BY1QH
只看楼主 倒序阅读 0楼 发表于: 2005-09-02
日本举办的,参加不参加呢?
不过这些日子,日本台很少回答我的cq,对dx倒是好事。
离线BD6AHP
只看该作者 1楼 发表于: 2005-09-02
the 46th all asian dx contest - 2005
01. contest period:
(1) cw: from 00:00 utc the third saturday of june to 24:00 utc the next day <48 hours> (june 18-19, 2005)
(2) phone: from 00:00 utc the first saturday of sept. to 24:00 utc the next day <48 hours> (sept. 3-4, 2005)
02. bands:
amateur bands 160m(cw only), 80m, 40m, 20m, 15m, 10m
03. entry categories:
(1) single operator single band
a: asian stations.................high power, low power
b: non-asian stations.........high power only
(2) single operator multi band
a: japanese(ja) stations........high power, low power, junior, silver
b: asian stations.......................high power, low power
c: non-asian stations...............high power only
(3) multi-operator single transmitter(all bands only)
(4) multi-operator multi transmitter(all bands only)
note1: single operator stations means that one person performs all concerned operations during contest period. use of packetcluster is permitted.
2: low power stations are limited 100w output or less. no limitation on high power stations.
3: junior stations' operator age must be 20 years old or younger, and silvers operators must be 70 years old or older.
4: 10 minutes rule(cq ww method) is applied to single transmitter stations. the 10 minutes rule means that only one transmitter and one band are permitted during any 10 minutes period, defined as starting with the first logged qso on a band. however, one-and only one other band may be used during any 10 minutes period if and only if the station worked is a new multiplier. this rule is spplied to not only running stations, but multi-stations respectively.
04. power, type of emission and frequencies:
within the limits of own station license.
05. contest call:
(1) cw ........... "cq aa"
(2) phone......... "cq aa contest"
06. exchange:
(1) for om stations: rs(t) report plus operators' age
for example (if operator is 25 years old): phone........5925, cw..........59925
(2) for yl stations: rs(t) report plus operators' age, but if the operator does not want to send her age, rs(t) report plus "00" (zero zero) can be sent.for example (the operator is 25 years old): phone........5925, cw..........59925
07. restrictions on the contest:
(1) no cross band contacts.
(2) no change of operating site.
(3) for single operator nad multi-operator single transmitter entry:
transmitting two signals or more at the same time, including cases of different bands, is not permitted. (except transmitting two signals to get new multiplier under the 10 minutes rules)
(4) for multi-operator's entry: transmitting two signals or more at the same time within the same band is not permitted.
(5) no operation from two sites or more for multi-operator's entry.
(6) no contact made through repeaters.
08. points and multipliers:
(1) for asian stations:
a: points........perfect contact will be scored as follows. contact among same entities will neither count as a point nor a multiplier. duplicate contact with the same station on same band will not count as a point.
160m band.......3 points per asian qso. 9 points per non-asian qso.
80m band.......2 points per asian qso. 6 points per non-asian qso.
10m band.......2 points per asian qso. 6 points per non-asian qso.
other bands........1 point per asian qso. 3 points per non-asian qso.
b: multipliers........the total number of different entities (according to the dxcc list) worked on each band.
(2) for non-asian stations:
a: points.......perfect contact with asian stations (excluding u.s. auxiliary military radio stations in the far east, japan) will be counted as follows:
160m band................3 points
80m band...............2 points
10m band...............2 points
other bands.................1 point
b: multipliers.......the total number of different asian prefixes(according to the wpx contest rules) worked on each band.
(3) jd1 stations.
a: jd1 stations on ogasawara (bonin and volcano) islands belong to asia.
b: jd1 stations on minami-tori shiama(marcus) islands belong to oceania.
(4) maritime mobile stations
for all maritime mobile stations at any location (no matter outside or inside asia), perfect contacts with only asian stations can be counted. the total score will be published in the contest results. but, they will not be ranked. contacts points with maritime mobile stations will be considered as same as contacts among asian stations. but, it will not count as multiplier.
09. scoring:
(the total of the contact points on each band) x (the total of the multipliers on each band)
10. instructions on the summary and log sheet:
it is recommended to use jarl a.a. contest log and summary sheet which are available from jarl hq for one irc and sae. (summary and log are available as "pdf files" from the jarl web site)
(1) each summary sheet must include your dxcc entity, callsign used, entry class, multipliers by band, points by band and total score. it should also include a signed declaration indicating that you have observed the rules and regulations of the contest.
(2) log sheet must contain band, date, time in utc, call of station worked, exchange sent, exchange received, multipliers and qso points. use a separate sheet for each band.(for single transmitter entry:in order of the time contacted). multipliers should be clearly marked by entities or asian prefixes, first time worked on each band.
(3) for japanese (ja) multi-operator's stations:log sheet must contain operator's name/hundle in each qso.
(4) e-mail submission
guidlines for the acceptable electronic file format are introduced in the "guidelines for e-mail submission of jarl contests"
11. awards:
(1) for both cw and phone, certificates will be awarded to those having the highest score in each entry in proportion to the number of participants from each entity and also those from us cq zone 3, 4, and 5 in the united states.
a: if the number of participants are under 10 there will be an award only to the highest scorer
b: from 11 to 20 ............ awards only to the runner-up
c: from 21 to 30 ............ awards to the top three
d: from 31 or more ........ awards to the top five
(2) the highest scorer among jarl members of category in each area of japan,under the condition having a ranking of half and more,will receive a certificate from jarl. however,this rule doesn't apply to those who received an above-mentioned certificate.
(3) the highest scorer on each continent of the single operator multi band entry will receive a medal from jarl and a certificate from the minister for internal affairs and communications, japan.
(4) the highest scorer of the multi-operator single transmitter and multi transmitter entry on each continent will receive a medal from jarl.
(5) all jarl members who submit a log and summary will receive a "entry certificate" from jarl through the qsl card bureau.
(6) special plaques will be awarded to the stations in the categories mentioned in a separate page.
(7) the contest award will be issued to whom fulfill the certain requirements during the contest period. the detailed information will be appeared in a separate page.
12. reporting:
(1) submit a summary sheet and logs of only one entry classification. e-mail submission will be welcomed.
(2) the log and summary should be postmarked by the following dates, addressed to:
jarl, all asian dx contest, 170-8073, japan
indicate cw or phone on the envelope.
e-mail submissions to:
a: cw...................aacw@jarl.or.jp
b: phone...............aaph@jarl.or.jp
deadlines for submissions:
a: cw...................july 31,2005
b: phone................october 31,2005
13. disqualifications:
(1) taking points for duplicate contact on the same band in excess of 2% of the total.
(2) false statements in the report.
(3) violations of the contest rules.
14. announcement of results:
results will be published in the march-april, 2006 issue of jarl news and also will be appeared on jarl's web site (http://www.jarl.or.jp).
for those wishing to receive contest results by post, please enclose one irc with your log.
离线BD6AHP
只看该作者 2楼 发表于: 2005-09-02
15. list of asian entities:
1s             spratly is.
3w,xv           vietnam
4j,4k           azerbaijan
4l             georgia
4p-4s           sri lanka
4x,4z           israel
5b             cyprus
7o             yemen
8q             maldives(*)
9k             kuwait
9m2,4           west malaysia
9n             nepal
9v             singapore
a4             oman
a5             bhutan
a6             u.a.e.
a7             qatar
a9             bahrain
ap-as           pakistan
bs7             scarborough reef
bv             taiwan
bv9             pratas is
by,bt           china
e4             palestine
ek             armenia
ep-eq           iran
ex             kyrgyzstan
ey             tajikistan
ez             turkmenistan
hl             south korea
hs             thailand
hz             saudi arabia
ja-js,7j-7n,8j     japan
jd1             ogasawara is.
jt-jv           mongolia
jy             jordan
od             lebanon
p5             north korea
s2             bangladesh
ta-tc(excluding ta1) turkey(*)
ua-ui8,9,0 ra-rz   asiatic russia
uj-um           uzbekistan
un-uq           kazakhstan
vr2             hong kong
vu             india
vu             andaman and nicobar is.
vu             laccadive is.
xu             cambodia
xw             laos
xx9             macao
xy-xz           myanmar
ya             afghanistan
yi             iraq
yk             syria
zc4             uk sov.base area on cyprus
(*) only asian area
total 55 entities as of march 1, 2005
离线BD7IHN
只看该作者 3楼 发表于: 2005-09-03
今天传播似乎不是很好啊。我一早起来听了个把小时,没收到几个台。今天的比赛可能只是鸡肋呀。
离线tno
只看该作者 4楼 发表于: 2005-09-03
真的没什么台出来,而且传播好象不怎么好,原来准备参加的,可一下发烧了,还是听听吧,听到了BA1RB在14上
离线BA7JC
只看该作者 5楼 发表于: 2005-09-03
听到bg7klo在cq contest
vr2xmt也在cq contest
离线BA1RB
只看该作者 6楼 发表于: 2005-09-03
呵呵,不知是传播不好还是玩的人太少,很少有形成pile up的时候,到下午四点半,频率上的台基本上都通过,收工了。
美国基本上没有开通,只通到w6,欧洲下午3点前有短暂的开通,通到g, ea, sm, ok, dl, sp, s5等常见的国家。
中间明显感觉有些电台是半路上来的,象t80a,他先试探性地叫了我一下,通完后就在旁边摆摊。俄罗斯的好几个电台也是这样。
15米基本上没有开通。7mhz基本上也不行。
离线BA7IO
只看该作者 7楼 发表于: 2005-09-03
打了一天的鬼子.............
少有几个欧洲台...亚洲台除了j台都很少.   美洲我这没通过,倒是南美与澳大利亚各点了个名.
现在连20米也不行,睡觉先.......
离线BA1RB
只看该作者 8楼 发表于: 2005-09-03
不错,有发展前途。
你通澳大利亚台的时候我在边上听着,你的yagi看起来不错,转向的时候我听你的信号变化很大。
另外,有一点,没听清楚年龄的时候不要问他how much,问他number或report就可以了。 :-)
离线BA7IO
只看该作者 9楼 发表于: 2005-09-03
不错,有发展前途。
谢谢指导,现在开始就改....我一直用59 how much,呵呵,可能是中式鸟语,想想也是不太礼貌.
再次感谢!
离线BA7IO
只看该作者 10楼 发表于: 2005-09-03
这比赛没法比了,中央六台的<<举起手来>>,老是搞得我报了一半或更少的呼叫,就忍不住笑起来........哈哈哈
离线初鸟
只看该作者 11楼 发表于: 2005-09-03
听到你在14mhz上叫你无反映!how much是什么意思??
离线BA7IO
只看该作者 12楼 发表于: 2005-09-03
[quote=初鸟]听到你在14mhz上叫你无反映!how much是什么意思??[/quote]
越距了,我听不到你....对不起啊!
当我问 59 how much时,意思是问他年龄数字是多少....呵呵!这样直接问是有些不礼貌,不过刚才发现说顺口了,有时还忘了改
离线xieyu
只看该作者 13楼 发表于: 2005-09-03
比赛的信号报告后面加上自己的年龄,女火腿用yl!
比如5928(如果操作人员的年龄是28岁!)
离线BG1FVL
只看该作者 14楼 发表于: 2005-09-04
7.048有台呼叫,不知如何回答
离线child@BY1QH
只看该作者 15楼 发表于: 2005-09-04
我的20米四单元八木罢工了,不参加了。争取这礼拜修好,参加欧洲的比赛。
离线BG1DRJ
只看该作者 16楼 发表于: 2005-09-04
[quote=child@by1qh]我的20米四单元八木罢工了,不参加了。争取这礼拜修好,参加欧洲的比赛。[/quote]
罢工!批准了吗?写申请了吗?无组织纪律!
离线BG1DRJ
只看该作者 17楼 发表于: 2005-09-04
昨天欧洲只在好像22:00bjt开通了不足10分钟就没有了,北美洲也只通了1个,23:00~1:00以后欧洲好像也没有开通。郁闷的睡觉了。
离线BD7IHN
只看该作者 18楼 发表于: 2005-09-04
7.048有台呼叫,不知如何回答
首先,你要听清楚该电台在呼叫什么。确认你可以回答的再回答,你如果不在他的呼叫范围内,最好就不要回答了。
如果听清楚对方是比赛电台,而且你确认自己了解这个比赛的规则,你就可以回答他了。
例如这个ssb的全亚洲竞赛,一般摆地摊主动呼叫的参赛台都会在间隔一定的时间就呼叫一下“cq aa contest”,而参赛台之间交换信号报告的时候会在rs(一般都是报59)后面加上操作者的年龄(一般是个两位数,还没听收过三位数或者一位数的,报00的说明操作者是位女士),这听起来就是一个四位数。
一般我会在旁边听清楚对方的呼号和年龄以后再呼叫他。这样,剩下的事情就是把自己的呼号和信号报告清楚地告诉对方。来了:
1、先断续地反复报自己的呼号,直到对方有反应,至少他会问qrz,否则就是他很忙或者根本收不到你的信号。
2、如果他可以一次抄收你的呼号,你会听到他重复你的呼号,甚至连着就给你信号报告,例如这样回答你“bg1fvl you are 5935 5935 qsl?”,有的时候他会特别强调一下他的年龄,说“bg1fvl you are 5935 5935 3 by 5 35 qsl?”。
3、如果你听他复述你的呼号不完全正确,你就不要急着和他交换信号报告。我遇到过一些急性子,一旦收到你的信号报告,就转去呼叫其他台了,其实他们根本没正确抄收呼号。而你这时候可能被其他台“淹没”了,根本不会有机会纠正他。
4、如果他复述你的呼号有部分不确定或者不正确,你可以重新再用字母解释法报给他。对于他已经能正确复述的部分,你最好用它所使用的字母解释单词,免得他把已经抄对的又搞错了。而对于他还不能正确复述的部分,你可以换着用不同的字母解释单词来复述,直到他能对其中某个单词做出正确的反应。如果他抄错的字母只是其中的某一个(出现在前缀或者后缀),那你只要给他反复报前缀或后缀,然后再整个报一次呼号就好了,免得他把已经抄对的又搞错了。
5、如果他复述你的呼号中的数字有误,那你可以做的就是给他数数,例如我是bd7ihn,就可以给他报“567、567、567、number 7”。当然,你会很不幸地发现自己居然是numbaer 1,也就是说你数数的空间十分有限,所以我也没有更好的建议给你。但我相信人们对“number 1”的反应应该比较快的,所以你会幸运地发现需要数数的机会比别人少。
6、当然,你可能会遇到对方复述你的呼号完全错误的情况,知道为什么吗?那是他在回答其他电台 这时候,你要做的就是在旁边等。
7、信号报告中的rs部分,大家基本都是报59的了。只有新火腿,才会根据s表的指示来报,这样做不能说是错,但可能会浪费大家的时间和增加出错的机会。想当年我也干过这样的事情,估计后背已经留下若干手指印。
8、报年龄的时候,男的就要如实报(整个比赛期间要一致,免得害死人,不知有没有比赛期间刚好过生日的,那也真的是搞事了),女的可以报00。对方哪个数字听不清楚,就还是给他数数。
9、礼节性的问候,我一般都是根据主叫台的情况来决定怎么做。如果对方正被很多台在呼叫,而且显得很匆,忙最快的做法是确认了呼号和信号报告就结束通联。如果对方问候我,基本上我会用同样的方式问候对方,至少说“thank you”、“73”、“byebye”等简单的。
离线BD7IHN
只看该作者 19楼 发表于: 2005-09-04
我在20米波段通了一个yo5oef,算是增加了一个波段分。
