  • 6422阅读
  • 14回复
美国最新天线设计 [复制链接]
离线mylcq
只看楼主 倒序阅读 0楼 发表于: 2005-08-16
美国最新天线设计可大幅缩小尺寸
最近美国海军军方完成的一项独立测试证实了一位天线发明者的研究。这位发明者声称,其skunk-works天线设计能缩小天线尺寸达70%,同时能够维持同等的灵敏度,并增加频宽。这种由四个元件组成的(four-part)的天线取消了传统天线设计中的常规感性负载,因此使能量辐射沿著其天线桿线性化,并让天线尺寸变小了。
发明这种天线的美国rhode island大学物理系的研究工程师rob vincent表示:「当2004年公佈我的较小型天线设计时,曾受到许多人的质疑。如今,美国海军的测试结果支持了我们的研究成果。」
vincent将其发明称為分佈式负载单极(distributed-load monopole,dlm)天线。这种新型设计採用螺旋状物及一个负载线圈,来缩小常规四分之一波的单极尺寸。据vincent表示,他的设计能缩小目前使用的每一种天线的尺寸,从手机内微小的gigahertz元件到大型的kilohertz am天线。
例如,3英吋长的gigahertz天线有可能缩小到一英吋,300英呎高的am频带天线可望减短至80英呎高。
离线robotcat
只看该作者 1楼 发表于: 2005-08-16
这不就是广大ham梦寐以求的东东嘛!
有没有相关的资料?
离线mylcq
只看该作者 2楼 发表于: 2005-08-16
我刚查了一下原文,与我设计的帆形天线差不多,只能到7mhz以上.
离线mylcq
只看该作者 3楼 发表于: 2005-08-16
uri physics employee invents new antenna technology
kingston, r.i. -- june 2, 2004 -- rob vincent, an employee in the university of rhode island's physics department, proves the adage that necessity is the mother of invention.
an amateur radio operator since he was 14, vincent has always lived in houses situated on small lots. because he couldn抰 erect a large antenna on a confined property, he has been continually challenged over the years to find a way to get better reception.
"i was always tinkering in the basement. thank goodness, my parents were tolerant. i can still remember my poor father driving up our driveway after a hard day抯 work to see wires wrapped around the house," vincent recalls.
"the holy grail of antenna technology is to create a small antenna with high efficiency and wide bandwidth," explains vincent. "according to current theory, you have to give up one of the three梥ize, efficiency, or bandwidth梩o achieve the other two."
after decades of experimentation, combined with a 30-year engineering career and yankee ingenuity, vincent has invented a revolutionary antenna technology. the distributed- load, monopole antennas are smaller, produce high efficiency, and retain good to excellent bandwidth. and they have multiple applications.
with this technology it will be possible to double, at minimum, the range of walkie-talkies used by police, fire, and other municipal personnel. naval ships, baby monitors, and portable antennas for military use are other applications. an antenna could be mounted on a chip in a cell phone and be applied to wireless local area networks. another application deals with radio frequency identification, which is expected someday to replace the barcode system.
"it could even make the dick tracy wrist radio with all the features, such as internet access, a possibility," vincent says.
the inventor pursued his quest to build a better antenna in earnest eight years ago when he and his significant other moved into a house situated on a 50-foot by 100-foot lot in warwick. there was nothing on the commercial market that could fit the lot that would provide the performance vincent needed to be heard in distant lands and that would be acceptable to his neighbors. all the small antennas being sold were inefficient and lacked bandwidth, which resulted in low performance and high frustration.
vincent looked at the techniques that were currently used to reduce antenna size and realized something was missing in the way everyone was approaching the problem.
he began to model various combinations into a computer program called mathcad. his first attempt produced a 21 mhz band antenna that was 18 inches high. normally, antennas for this band are 12 to 24 feet high.
vincent installed the antenna in his back yard. the legal limit that amateurs can operate is 1,000 watts with the norm being 100 watts. the amateur radio operator experimented with 5 to 10 watts. he reached a station in chile and made contacts in various european countries. meanwhile he kept adding power until it reached 100 watts. that抯 when things suddenly went bad. walking outside in the backyard, he understood why. the antenna had melted.
after examining the molten matter, vincent wasn抰 discouraged. this was only a small model and not designed to handle much power. the part of the antenna that failed proved to be the key to the design. after analyzing the failure, vincent realized that he was able to transform a lot of current along the antenna with even relatively low power.
"antennas radiate by setting up large amounts of current flow through various parts of their structure," he says. "the larger the current the more radiation and the better the output of the antenna."
vincent went back to the drawing board and continued to improve the technology. relying on his nearly 30 years at raytheon co. and at kvh industries in middletown r.i., which provided him with a diversified background in electronics and electronic systems, vincent overcame a myriad of problems and succeeded.
he established three test sites for various prototypes. antennas were placed in westport, mass. in a salt marsh, the best ground for transmission and reception. another set of antennas was placed on rocky ground in cumberland, r.i., the worst kind of site, and at a warwick site which is in between the two in terms of grounding. the antennas, which resemble flagpoles, worked well at all locations.
tests confirmed that vincent has created antennas at one third to one ninth of their full size counterparts. normally smaller antennas are only 8 to 15 percent efficient. vincent抯 antennas achieved 80 to 100 percent efficiency as compared to the larger antennas.
a patent is pending on vincent's technology. the inventor has made the university of rhode island and its physics department partners that will benefit from any revenue his invention earns. "the university and its physics department has been very supportive and given me time and space to work on this project," says vincent who was recently presented the 2004 outstanding intellectual property award by uri's research office. "i couldn't have done this without the university's support. it's only fair that it share in the profits."
离线BG7KIH
只看该作者 4楼 发表于: 2005-08-16
不太相信             .
离线BG4DCX
只看该作者 5楼 发表于: 2005-08-16
呵呵
这个天线能明用吗?
离线mylcq
只看该作者 6楼 发表于: 2005-08-17
我估计与这种天线差不多!
matching/phasing network for an 80m experimental cfa
several readers have questioned the way in which we fed our experimental cfa, previously described in words only, suggesting (perhaps) that if we used another circuit we would achieve improved performance. and, i myself have wondered, looking at the circuitry used by others, whether (in fact) the cylinder and disc would be fed in phase quadrature --- the point being that circuitry is designed that is supposed to feed the antenna elements in quadrature, but in general phase is not measured.
i show in the figure the matching/phasing network we used, which is in principle like that used by broadcast engineers when feeding multi-element antenna systems, viz. match the antenna elements, phase, and then combine.
the grounds shown are connections to the gp associated with (a part of) the cfa. the tuners are right underneath the gp (not shown). the wires connecting to the disc and the cylinder are very very short. these wires pass through small toroids, which have a secondary winding of 10-turns --- i.e. current transformers (the primary windings are the feed through wires). the secondary winding is terminated in a 50-ohm resistor (also not shown), one end connecting to the gp ground.
the coaxial cables used are rg-62au, 100 ohm coaxial cable. the tuners were designed to match the feed port impedances (estimated to be about 200 ohms resistive and capacitively reactive) to 100 ohms. the 90 degree phase shift (phase lag) is included in the feed to the disc. the 100 ohm coaxial cables are connected in parallel at the transmitter input end (hence the impedance should be 50 ohm).
clearly the phase can be anything we like by adding to, subtracting from, or removing entirely the quarter wave phasing coaxial section. the currents are measured in phase (actually phase difference) and relative amplitudes using a hf vector voltmeter 8405a.   transmitter power, current phase difference, and current amplitude ratio is all that is needed for our numerical modelling (we do not need absolute current amplitude).
but we have a problem, reference our experimental note, viz. what value should we ascribe to the transmitter power, since almost one half of the outgoing power (to the cylinder) comes back through the disc port. all of that return power may not be, probably is not, re-cycled. we have previous commented on the additional experiment inserting another pi-network between the bird wattmeter and the antenna input, to ensure that power is recycled, and the transmitter is matched --- but this resulted in a decrease in measured field strength.
in my view this is an important difficulty with the cfa. we have yet to learn whether this is a problem for other experimenters --- dr. kabbary himself makes no mention of a problem (reference his thesis, and published papers).
let me quote from the kabbary et. all 1999 nab paper: “a facinating feature of cfas is that the input impedance can always be adjusted to match any desired input impedance at the required broadcast frequency. using a hp network analyser attached to the input of the phasing unit ---- ” .
if one tunes and matches for a vswr = 1 (without the additional pi-tuner mentioned above) measured by the bird wattmeter, the antenna system is in our view not operating in the crossed field mode. power surging out-and-in is a characteristic of quadrature feed (experiment and simulation) --- not just the cylinder and disc arrangement --- two closely spaced dipole fed in quadrature exhibit the same characteristic. .
john s. (jack) belrose
ve2cv
7 june 2000
离线BD4EQ
只看该作者 7楼 发表于: 2005-08-17
离线bd7qay
只看该作者 8楼 发表于: 2005-08-17
这种新式天线已经使用,我国一些广播电台等单位就采用了上面图片的天线。
离线BG7KIH
只看该作者 9楼 发表于: 2005-08-18
希望有人能验证一下效果如何.
离线bg5eld
只看该作者 10楼 发表于: 2005-08-19
短波天线发展到今天,要想再有很大的突破(像小型高效多波段)依我看已经很难了,现代专业短波以自适应抗干扰为主要发展方向,及以之相配套的天线可能是今后专业通信的主要天线。
离线mylcq
只看该作者 11楼 发表于: 2005-08-25
小尺寸天线问世
罗德岛大学物理系的一名员工罗布.文森特证明了需要是发明之母这句老话。
文森特从14岁起就爱上了无线电,但他的家总是位于狭窄的地方。由于他没有办法在有限的空间里安装大型的天线,所以他一直想找到能够提高天线接受质量的方法。
经过几十年的试验,再加上30年的工作经验以及美国人特有的独创精神,文森特发明了一种新的天线技术。这种分布荷载单极天线尺寸更小,效率更高,频率带宽极佳,可以应用于很多领域。
8年前,文森特开始寻找提高天线质量的方法。他首先将各种参数整合到一个叫mathcad的计算机程序中。一开始,他制作出一个高18英寸的21m天线。一般来说,这个频率的天线高12-24英寸。文森特在他的后院里安装了这种天线。业余爱好者能够操作的功率上限是1000w。文森特从5到10瓦开始试验。他一边与智利的雷达站联系,一边持续增加功率,直到100瓦,突然信号中断。走出院子,文森特明白了,原来天线烧化了。
文森特没有丧失信心。这只是一个小模型,并不能处理很大的功率。天线被烧毁的部分后来证明恰好是设计的关键部位。文森特回到绘图板,继续改进技术。依靠他在雷神公司和kvh公司30年的工作经验,文森特战胜了无数的困难,取得了成功。
试验证明文森特设计的天线只有正常尺寸的三分之一到九分之一。一般来说,小的天线只能接收到8%-15%的信号,但文森特的天线能够达到大天线的80%-100%!
文森特的技术即将获得专利。
这真是令我感动的文章,中午在饭桌上看到《参考》的这个文章,想到其他版面展现混乱的世界,ham的这种传奇真是人类最美好的东西。
离线BD0AAI
只看该作者 12楼 发表于: 2005-08-25
原来天线烧化了。
100w的功率能把天线烧化? 不会是用漆包线做阵子吧?
离线mylcq
只看该作者 13楼 发表于: 2005-08-25
8010天线实例也许如此!
离线bg5djx
只看该作者 14楼 发表于: 2005-10-31
“革命尚未成功,同志仍须努力。”
