  • 4396阅读
  • 12回复
计划在中国推广IRLP,各地有兴趣的火腿和中继台负责人请进 [复制链接]
离线BH1DIY
只看楼主 倒序阅读 0楼 发表于: 2005-08-08
irlp(the internet radio linking project)简介
the aim of this project is to reliably and inexpensively link amateur radio systems without the use of rf links, leased lines, or satellites.
irlp的目的是建立稳定可*低成本的业余无线电系统连接,它不需要通过rf连接,租用线路或者卫星传输.
the irlp uses voice-over-ip (voip) custom software and hardware. coupled with the power of the internet, irlp will link your repeater site or simplex station to the world in a simple and cost effective way.
irlp使用定制的的软硬件,加上强大的互联网. irlp通过过简单和低成本的方式连接你的中继或着单个电台到世界各地.
irlp operates a worldwide network of dedicated servers and nodes offering very stable worldwide voice communications between hundreds of towns and cities. all this with unsurpassed uptimes and the full dynamic range of telephone quality audio.
irlp 运行在互连网上专门的服务器和站点,为成百上千个城镇的hams提供非常稳定的全球语音交流. 这一切没有时间限制,效果接近电话音质.
how does irlp actually work?
irlp如何工作
the irlp uses a voice-over-ip (voip) streaming software called speak freely. speak freely is very similar to other voip software packages (such as microsoft netmeeting and vocaltec iphone) with one difference... it runs under linux.
irlp使用voip的speak freely语音流软件, speak freely是类似于其他voip软件包(如微软的netmeeting 和 vocaltec的iphone),唯一不同的是,它运行在linux系统上.
linux is the operating system of choice for the irlp system as it allows the best in reliability, programmability, efficiency, and functionality. most irlp nodes use linux redhat 7.3 or redhat 9 as they are very stable releases and run very smooth on any p1 or better computer. effective december 2004 irlp started shipping the open sourced fedora project core3 version of linux. this release provides greatly improved operation with more support for audio cards.
irlp选用linux系统是因为它良好的稳定性、可编程性、高效率和功能强大。大多数的irlp工作站使用linux redhat7.3 或者redhat 9系统,都有非常稳定的版本平稳地运行在p-1或者更高配置的电脑上。2004年12月 irlp有效地开始引入开源的linux fedora project core3 版本 ,这个版本提供大大改进了更多的声卡的支持。
离线BH1DIY
只看该作者 1楼 发表于: 2005-08-08
有关irlp的信息,请访问:www.irlp.net
将业余无线电技术、计算机技术、网络技术三者结合起来,实现基于互联网的远程通联。许多国家的火腿都设计出自己的网上通联系统,但由于资金等原因,并没有实际应用。在西方,最著名的网上通联系统是irlp(互联网-电台连接方案),通过这个系统,南半球澳大利亚的火腿可以使用普通的手持电台,轻松地与北半球加拿大的火腿通联。在中国,最常用的网上通联系统是eqso(网络通联),但通联双方必须使用计算机和一个相同的软件,因此它更像是一个网上聊天室。
简单说:irlp需要一台linux电脑连接互连网,一块irlp卡连接电脑与台机,就可以实现全球通联。连接中继有两种方式,台机的频率调到中继对应频率,或irlp卡可以直接连到中继机器上。在国外,单一的站点(simplex node)和中继站点(repeater node)都很普遍。
在互联网日益普及的今天,业余无线电也应该与时俱进,irlp是个不错的选择。使用irlp对中国ham而言,至少有以下好处:
1 与国际最新技术接轨,让中国ham紧跟世界潮流,促进中国业余无线电的发展;
2 轻松使用u/v设备与全球通联,扩大ham国际交流;
3 中国地大物博, 各地中继互连能加强各地ham交流,尤其是旅行日益普遍的今天,irlp在你外出时方便与各地火腿交换信息。
4 同时,与国外火腿交流,也是学习和提高英语口语的一个很好的途径。
目前,深圳有了中国第一个irlp node, 大约一个月后,天津也将会建立一个,感谢美国一个44年“腿龄”的老火腿w7rat为为此所做的一切。
w7rat愿意帮助中国建立更多的node,希望更多的中国火腿与美洲地区通联,他本人已经在他的家乡筹建一个专门的irlp中继,希望扩大与中国ham的交流。
因此,有兴趣了解和加入irlp的ham和中继台负责人请跟贴或直接与我联系。
"once you have talked via the irlp, you will forever walk the earth with
your eyes turned to your radio, for there you have talked, and there you will
long to talk again. "irlp radio knows no language or international border
barriers"...and that's fm clear!!
离线BH1DIY
只看该作者 2楼 发表于: 2005-08-08
这个周末irlp qso不完全记录:
w7rat/michael
n7mrn/larry
kx4y/dieter
w7aor/kent
n0pqv/terry
ka0vnb(这家伙居然娶了一个川妹子)
wb8rei/jaff
n9dzm
kd5oug/doug
qz1kbt(目前丹麦唯一的node)
kg0or/gary
离线BG7TBI
只看该作者 3楼 发表于: 2005-08-08
要专们做个服务器才得哟,要是全国的差转用联网接起来会成什么样子哟
离线BH1DIY
只看该作者 4楼 发表于: 2005-08-08
如果以对外交流为主,可以不建立专门的服务器
如果国内交流为主,到一定时候应该考虑建立专门服务器。
离线王书贵
只看该作者 5楼 发表于: 2005-08-08
dddddddddddddddddddddddddddddd
离线BG6QAM
只看该作者 6楼 发表于: 2005-08-08
停了很久的网上的北京台网,是不是这个东西?
离线BH1DIY
只看该作者 7楼 发表于: 2005-08-08
非也~~~~~~~~~~~~~
离线ahzds
只看该作者 8楼 发表于: 2005-08-08
现有的流媒体编辑软件可以实现这一功能,类似于广播电台实时网上传播!我做过试验,随便一台机器都可以实现,但必须要有一台服务器和收发本地中继或火腿活动频率的电台和简单连接接口!
离线BG1FPX
只看该作者 9楼 发表于: 2005-08-08
请问一个地方,搞这样一个node,各种设备全包括,大约需要多少钱?
离线BD5BAC
只看该作者 10楼 发表于: 2005-08-08
好家伙~~~~~~~~
离线BH1DIY
只看该作者 11楼 发表于: 2005-08-08
网上直播是非常简单容易实现的
但是中继/电台之间的跨区域任意互联应该是关键的技术,
dmtf拨号选择任意差转台(reflector)或基站(node),基于linux的稳定而优质的voip语音技术是非一般流煤体软件可以实现的.
离线BH1DIY
只看该作者 12楼 发表于: 2005-08-08
电脑和台机自己解决
卡和软件 共 $150
