  • 2762阅读
  • 2回复
这次比赛的日记传到哪里? [复制链接]
离线BD0AAI
只看楼主 倒序阅读 0楼 发表于: 2005-07-13
比赛期间我们通联了一些hq电台,请问通联日记要用什么格式,该传到哪里?
离线BA4RF
只看该作者 1楼 发表于: 2005-07-14
10. reporting:
10.1. entries must be postmarked or emailed no later than 30 days after the end of the contest (august 9, 2005). no late entries can be accepted. entries that are received after mid-october, 2005, even if mailed in time, may not be received in time to be included in the official results.
10.2. electronic entries must conform to the cabrillo file format.
10.2.1. the cabrillo file format and specifications may be found at http://www.kkn.net/~trey/cabrillo/ or in the november 1999 issue of qst magazine.
10.2.2. any entry which has been generated using a computer (either during the contest or after the contest) must be submitted either as an attachment to an email or on a 3.5" diskette.
10.2.3. electronic files must use the entrant's callsign as the file name.
10.2.4. the log file must be a chronological list of qsos as made not separated by band or mode.
10.2.5. entries sent as attachments to email must be sent to
iaruhf@iaru.org
10.2.5.1. email entries must include the callsign used during the contest on the subject line of the email.
10.2.6. entries sent on diskette should be mailed to: iaru hf
championship, iaru international secretariat, box 310905, newington, ct 06111-0905 usa.
10.2.6.1. diskettes must be clearly labeled with the station call sign, contest name, entry class and date.
10.3. participants may submit their entry using the web applet found at: www.b4h.net/cabforms
10.4. paper logs must be in chronological order, not separated by bands, and clearly indicate for each contact: band, mode, date, time (in utc) callsigns, complete exchanges sent and received, multipliers and qso points.
10.4.1. multipliers should be marked in the paper log only the first time they are worked on each band.
10.4.2. paper logs with more than 500 qso's must include dupe sheets (an alpha-numeric list of all callsigns worked, broken down by band and mode).
10.4.3. all contacts in paper logs must be in chronological order, not separated by bands.
10.4.4. paper logs must be mailed to iaru international secretariat, box 310905, newington, ct 06111-0905 usa and postmarked no later than august 9, 2005.
10.5. all paper entries must include an official summary sheet or reasonable facsimile thereof with complete contest information.
离线BA4RF
只看该作者 2楼 发表于: 2005-07-14
格式: cabrillo file format
(具体标准可以在 http://www.kkn.net/~trey/cabrillo/ 查到)
发送到:
iaruhf@iaru.org
