  • 3120阅读
  • 2回复
HF Iso-Loop [复制链接]
离线BA5RW
只看楼主 倒序阅读 0楼 发表于: 2005-06-16
hf iso-loop & controller
ideal hf antenna for apartment dwellers & rv's
aea's iso-loop is a high-q, compact loop that continuously covers 10 to 30 mhz. great for apartment, condo, and trailer situations wherein physical space or restrictions prevent the erection of larger hf antennas. the iso-loop is also perfect for rv's and campers on the move. ideal for both amateur and swl'r use.
construction is welded stainless steel and high quality components, including a huge 10,000 volt tuning capacitor. no shortcuts are used on this antenna, unlike the knock-off competitor's. antenna efficiency ranges from 96% on 10m to 72% on 20m which provides a stronger radiated signal. the loop's omnidirectional design can be mounted either vertical or horizontal. the antenna also isolates the feedline to reduce tvi and handles 150w. comes complete with manual remote tuning control to place near your radio, 50ft of control cable, and power supply.
离线BA5RW
只看该作者 1楼 发表于: 2005-06-16
如何隐藏您的天线,而不被邻居发现引起不必要的纠纷,哈哈,请看:
http://members.fortunecity.com/ac6ts/index-9.html
离线刺猬
只看该作者 2楼 发表于: 2005-06-17
我就是喜欢loop!!!!!!
