  • 5971阅读
  • 18回复
有根据多普勒控制电台频率的软件吗? [复制链接]
离线BA7JC
只看楼主 倒序阅读 0楼 发表于: 2005-05-17
有可以根据多普勒自动控制电台的上行及下行频率变化的软件吗?我用ham radio deluxe 的软件控制ft-897不能自动变化频率,如果自动变化频率这样追星就很方便了。
离线VR2KW
只看该作者 1楼 发表于: 2005-05-17
试一下satpc32,有demo版;不过作者声称可以控制ic-820h,但我还没有弄成功,也不知是软件的问题还是设定有问题,纳闷!!!
离线BA7JC
只看该作者 2楼 发表于: 2005-05-18
很高兴能在ao-51上跟你通联,希望下次能在ao-51再遇到你。
离线BD3RJ
只看该作者 3楼 发表于: 2005-05-19
注册了吗?
离线BD3RJ
只看该作者 4楼 发表于: 2005-05-19
不知你用的是欧 北美还是德版?现在最新的是v12.3
另satspy v4.03也挺有意思的.
离线VR2KW
只看该作者 5楼 发表于: 2005-05-20
作者说在ic-821h、ic-910、ic-970上通过测试,应该也可以用在ic-820h上,结果820传回一个信息错误的回头信息。
离线BD3RJ
只看该作者 6楼 发表于: 2005-05-20
呵呵,看来您得买台ic-821h了!
离线BA7JC
只看该作者 7楼 发表于: 2005-05-20
我安装了satpc32,但设置cat后启动出错,我不会用这个软件,请教这个软件如何用的,谢谢!
离线BD3RJ
只看该作者 8楼 发表于: 2005-05-20
截个图看看你是如何设置的.
离线BA7JC
只看该作者 9楼 发表于: 2005-05-21
hints for users of yaesu radios
  the following hints refer to the yaesu satellite transceivers ft-736r
  and ft-847 and to the half-duplex radios ft-817, ft-857 and ft-897.
  attention: please read the hints regarding the necessary precautions
  when using the latter 3 radios with a rx-preamplifier, before you
  steer the radio with satpc32 (section i.2a below).
i.   connection pc <-> transceiver
1. to connect a ft-736r to the pc, a ttl <-> rs232 converter is required.
  such a converter can easily be built. the only component needed is a
  max232 chip. a detailed schematic is contained in the 'hardware.gif' file
  in this sub directory. the file can be opened with a picture program like
  i_view32. the 'hardware.txt' and 'cat.txt' files in this directory contain
  additional instructions.
  attention: the bridges on the connector at the pc side were needed with the
  older driver software and could easily be overlooked! with the present
  hardware driver, the cat control should work without any of the bridges.
2. to connect a ft-847 to your pc, you only need a null modem cable (see the
  ft-847 manual).
2a. to connect the ft-817, ft-857, ft-897 the yaesu ct-62 cable is required.
  menu 85 of the ft-857 and ft-897 must be set to "off" (default) and menu
  20 of these radios must be set to "cat" (default).
  caution: if you are using a rx-preamplifier with one of these radios,
  make sure that it is reliably protected against rf from the radio (i.e.
  by a rf vox) before you steer the radio with satpc32!
  when these radios are steered via the program, one can't preclude that it
  will temporarily transmit on the downlink frequency, although this is a
  very rare occurrence.
  this is caused by the following:
  the program needs to toggle the vfos of these radios when it updates
  the tx vfo. therefore the tx-vfo will become temporarily the
  rx-vfo when the program updates the frequency of this vfo. although
  this period is extremely short (about 0.25 sec), one can't guarantee
  that the ptt button won't be pressed during this period.
  since the radio is in split mode, it will then switch to the other vfo
  for tx. this is the vfo, however, that contains the rx frequency.
  therefore watch the display and listen to the "holes" in the received
  signal before you press the ptt button.
ii. cat control setup for yaesu tranceivers
1. settings with the auxiliary program 'satsetup'
a. start satpc32.
b. open the 'programs' menu and start 'satsetup'.
c. select a com port. with the ft-736r and the ft-847 set the cat
  delay to 20, with the ft-817/857/897 set the cat delay to
  110.
  store the settings.
2. settings with the satpc32 'options?menu
a. open the 'options' menu and select 'yaesu'.
b. set the specific parameters for your yaesu transceiver.
  there are 2 combo boxes in the upper right corner of the 'options'
  menu. the upper one contains the parameters that have to be set
  (model, baud rate), the lower one contains the settings available
  for the selected parameter.
aa. model name: select ft-736r, ft-847, ft-817, ft-857 or ft-897.
bb. baud rate:
  the ft-736r supports only 4800 bd. therefore, select this value.
  the ft-847 supports 4800, 9600 and 57600 bd. the radio is preset
  to 4800 bd. set the baud rate as high as possible, consistent
  with a reliable operation. to my experience, all radios work flawlessly
  with the highest baud rate. therefore, set it to 57600 bd.
  the setting at the ft-847 can be changed with menu #37. of course, it
  has to be identical to the setting in the 'options' menu.
  the ft-817, ft-857 and ft-897 support 4800, 9600 and 38400 bd.
  the radios are preset to 4800 bd. set the baud rate as high as
  possible, consistent with a reliable operation. from experience,
  all radios work flawlessly with the highest baud rate. therefore,
  set it to 38400 bd.
  the setting at the radios has to be equal with the setting in
  the menu 'options', of course. the radio's baud rate can be changed
  with menu #14.
c. store the options.
3. satpc32 stores the settings in the 'yaesupar.sqf' file in the
  satpc32 directory. the file can be opened with notepad and also
  be edited manually.
  upon installation it contains the settings for the ft-736r.
离线BA7JC
只看该作者 10楼 发表于: 2005-05-21
iii. operation
1. ft-736r
a. switch the transceiver on.
  note that in sat mode the radio has to be on the right downlink and
  uplink bands for the satellite you want to work. if not, switch the
  bands (key 'rev', see below h.).
  most of the amateur radio satellites use 70cm for downlink and
  2m for uplink (pacsats, fo-20, fo-29). therefore select the 70cm
  band for rx and the 2m band for tx. the modes and displayed frequencies
  are meaningless, since the program takes them from the 'doppler.sqf'
  file.
b. start satpc32 (if the program is running, close it and restart it
  again).
  note that the cat control has to be activated (c+).
  select a satellite for which the doppler.sqf file contains one
  or more lines (for all satellites that are preset at delivery,
  the doppler.sqf file will contain frequency data shown
  in the righthand list of the 'satellites' menu).
  the program now should switch the ft-736r automatically into
  sat mode, control mode and frequency display.
  the vfo frequencies should be set to the values stored in
  doppler.sqf +/- doppler shift. the frequencies displayed at the
  radio and in the satpc32 frequency window should be equal
  (if a converter/transverter is in use, only the khz-parts will
  be equal).
  the frequencies displayed in satpc32 are updated every second.
  as soon as the doppler shift changes of the higher one of both
  frequencies has exceeded the 'interval' (displayed in the
  'cat' menu), the program should update both frequencies at the
  radio.
c. -
d. cat functions test:
  the proper working of the cat control can easily be checked.
  to do this, select an ssb satellite like ao-40, fo-20 or
  fo-29.
  click on one of the 5 up/down controls or press one of the
  direction keys of the middle block of the keyboard.
  the downlink frequency should then be changed according to the selected
  value. the speed should be about 10 steps per second.
  then, switch the radio into transmit mode and repeat the test for
  the uplink frequency.
e. frequency tuning (qsy)
  with ssb satellites, tuning of the ft-736r can be done via the
  mouse (5 up/down controls) and the keyboard (with the 10 keys
  of the middle block).
  you may tune the radio to the beacon freqency if you
  want to receive telemetry. the automatic doppler correction
  will allow you to receive the beacon signal flawlessly
  for hours.
f. frequency corrections
  note that with ssb satellites, the 'frequency corrections' mentioned
  in this section are merely changes of the uplink frequency
  in order to adjust this frequency for best audio quality of your own
  downlink signal.
  with atellites like fo-20, fo-29 (uplink 2m, downlink 70cm)
  you will usually hear your own signal immediately after
  selecting the satellite, provided that the frequency data in the
  doppler.sqf file are optimized for your radio (see sect. g.)
  and that your equipment has warmed up. you will also hear your
  signal with the right audio without any correction during
  the whole pass.
  however, with satellites like ao-40, frequency corrections
  may be necessary when you select this satellite for the first
  time after program start.
  the downlink frequency is on 2.4 ghz. a down-converter is
  required which is usually mounted at the antenna. due to
  temperature variations, the mixer oscillator frequency
  can drift by several khz.
  in the faq.htm file (in the satpc32 '?' menu), you will
  find detailed instructions on how to correct the frequency
  during operation (section 5, 'ao-40 operation with satpc32/
  wisat32').
  with fm satellites (i.e. uo-22), no frequency corrections
  should be necessary.
g. modification of the doppler.sqf file
  satpc32/wisat32 take the frequencies from the doppler.sqf
  file. to edit this file it can be opened from the
  satpc32 '?' menu.
  for ssb operation the frequency entries are most
  important. these entries decide whether you will
  hear your own signal on the downlink immediately after
  you have selected a (2m/70cm) satellite like fo-20, fo-29
  (regarding to ao-40 see f.) due to slight differences between
  individual radios, the frequency entries at delivery may not be
  optimal but have to be adjusted for your radio.
  in the faq.htm file (in the satpc32 '?' menu) you will find
  detailed instructions and an example on how to optimize the frequency
  entries for your radio (section 5, 'ao-40 operation with
  satpc32/wisat32').these hints are valid for other satellites too.
  please read the very important instructions
  referring to the 'doppler.sqf' file. you will find them
  in the file itself (at it's end) and - more detailed -
  in the manual, section 'auxiliary files'.
  there you will find instructions on how to determine
  easily the frequencies of ssb satellites.
h. bandswitching
  if you want to switch the ft-736r to a satellite with
  reverse uplink/downlink bands (i.e. from fo-20 to ao-10
  or back), press the 'rev' key before you select the
  new satellite in satpc32. since there is no cat command
  for bandswitching, this can only be done manually.
  for more detailed information please read the 'faq.htm',
  section 'bandswitching'.
i. transverter/converter operation
  you will find detailed instructions in the 'faq.htm' file.
2. ft-847
  again).
  in the righthand list of the 'satellites' menu, the doppler.sqf file
  will contain frequency datas).
  the program should switch now the ft-847 automatically into sat mode,
  the vfo frequencies should be set to the values stored in the
  (if a converter/transverter is in use only the khz-parts will
  be equal).
  the frequencies displayed in satpc32 should be updated every second.
  frequencies has exceeded the 'interval' (that is displayed in the
  'cat' menu), the program should also update both frequencies at the
  radio.
c. with the 'file|satmode off'menu, the sat mode of the radio can be
  switched off, i.e. for temporary terrestrial operation. when the
  sat mode is activated again (by the 'c' control), the radio returns
  to the previous sat frequencies.
  to do this select an ssb satellite like ao-40, fo-20 or
  fo-29. these satellites are using a 'reverse' frequency
  pattern (when the uplink frequency has been increased, the
  downlink frequency has to be decreased to receive the own
  signal again).
  switch the radio into satellite mode. for testing, switch
  the track function of the radio to 'normal'.
  then decrease the rx frequency by 5 khz by using the vfo.
  the tx frequency will also be decreased by 5 khz. the
  tx frequency therefore is 'off' by 10 khz. 1 or 2 seconds,
  after the motion of the knob has stopped, the program
  should increase the tx frequency by about 10 khz and tune
  it on the right frequency.
  the advantages of the cat control can best be seen during ssb
  operation over satellites like ao-40, fo-20, fo-29. the radio
  can be tuned like it can for terrestrical operation.
  you may tune it to the beacon freqency if you want
  for hours.
  the frequencies can be tuned via the vfo or alternatively
  by the 5 up/down controls or the direction keys of the
  keyboard.
  in this section are corrections of the uplink frequency only
  to adjust this frequency for the best audio quality of your own
  downlink signal.
  for satellites like fo-20, fo-29 (uplink 2m, downlink 70cm)
  you usually will hear your own signal immediately after
  and that your equipment has warmed up. you will then hear your
  the whole pass.
  for satellites like ao-40 however, frequency corrections
  usually will be necessary when you select this satellite
  for the first time after program start.
  in the faq.htm file (in the satpc32'?' menu) you will find detailed
  instructions on how to correct the frequencies during operation
  (section 5, 'ao-40 operation with satpc32/wisat32').
  from program version 11.0 on, the sub-vfo knob of the ft-847
  can be used for frequency corrections (besides the controls
  in the 'cat' menu and the +/- keys of the keyboard).
  the sub-vfo-correction functions also work with the track
  function of the transceiver switched on.
  for fm satellites (i.e. uo-22) no frequency
  corrections should be necessary.
  file. to edit this file, it can be opened from the
  satpc32 menu '?'
  for ssb operation, the frequency entries are most
  (regarding to ao-40 see f.). due to slight differences of
  optimal, but have to be adjusted for your radio.
  detailed instructions on how to optimize easily the frequency
  there you will find instructions on how to determine easily
h. transverter/converter operation
3
离线BA7JC
只看该作者 11楼 发表于: 2005-05-21
.   ft-817, ft-857, ft-897
  again).
  or more lines (the default doppler.sqf file contains information for
  all satellites that are pre-installed in the right hand list of the
  'satellites' menu).
  the program should automatically switch the radio into split mode,
  (a little "s" will appear on the display) and steer frequency
  and mode.
  important: frequency and mode can be changed only while the radio
  is in rx mode.
  the vfo frequencies should be automatically set to the values stored
  in the doppler.sqf file, +/- doppler shift. the frequencies displayed
  at the radio and in the satpc32 frequency window should be equal
  be equal).
  the frequencies displayed by satpc32 should be updated every second.
  the program will update the highest radio vfo frequency after the
  doppler shift has changed by more than the 'interval' (that is
  displayed in the 'cat' menu).
  to minimize vfo switching, the frequency of the lower band is only
  updated when the doppler shift on that band changes by more than the
  interval. many satellites (fo-29, uo-22, echo) use the 70-cm band
  for downlink and the 2-m band for uplink. with these satellites the
  program will usually update the 70-cm downlink frequency 3 times as
  often as it updates the 2-m uplink frequency.
d. cat function test:
  fo-29. these satellites use inverting transponders (when the
  uplink frequency has been increased, the downlink frequency
  has to be decreased.
  1 or 2 seconds after the motion of the knob has stopped,
  the program should increase the tx frequency by about
  5 khz and tune the radio on the right frequency.
  operation over satellites like ao-40, fo-20, fo-29. the radio's
  rx vfo can be tuned normally, and satpc32 provides "virtual"
  automatic tracking of the tx vfo frequency.
  for hours.
  keyboard.
  "satellite" radios are full-duplex, allowing the user to
  receive their own downlink signal while transmitting on a
  different band. with "satellite" radios, 'frequency
  corrections' are done to the uplink frequency until it is
  heard correctly on the selected downlink frequency.
  with semi duplex radios such as ft-717/857/897, this frequency
  correction method will not work because the downlink cannot
  be heard while the radio is transmitting. in a qso the user
  can calibrate the rx frequency, however, for best audio pitch
  of the received signal. the calibration can be done with
  the "downlink calibration" controls in the menu "cat" in
  steps of 10, 100 or 1000 hz. the 10- and 100-hz steps can
  be done also with the up/down keys of the number pad on the
  keyboard (10 hz: keys 8/2, 100 hz: keys 9/3).
g. with support of another operator it is also possible to
  optimize the frequency entries in doppler.sqf for the
  particular satellite. that means, at future program start
  you will be automatically on the right uplink frequency
  when you tune the rx for best audio of the received signal.
  to optimize the frequency entries do the following: make
  sure that the partner receives both signals - his own as
  well as yours - with the right audio pitch.
  calibrate the rx frequency for best audio of the received
  signal. then click "change/store data file" in the menu cat.
  in the window that opens click "rx/tx freq.data".
  alternatively you can do the following: note the amount of
  downlink calibration you need for best audio of the received
  signal. this value will be displayed above the frequency
  window of satpc32. when the qso is finished, re-set the
  correction value to 0 and both frequencies to the middle
  of the passband. to do this, simply click on the ident
  letter of the satellite.
  then correct the uplink frequency by the same amount of hz
  and in the same direction. if - for example - you had a
  downlink calibration of -500 hz, correct the uplink
  frequency by -500 hz.
  then click "change/store freq.data" and then "store uplink
  calibration".
  the advantage of the 2nd method: the starting frequency
  will remain in the middle of the passband.
  with fm satellites the "downlink calibration" controls
  are disabled. from experience with these satellites
  (i.e. uo-22) no frequency corrections will be necessary.
  nevertheless they can be done with the 3 other controls.
  for details see section d4 of the manual.
h. modification of the doppler.sqf file
  satpc32 menu '?'
  the mode entries of fm satellites have to be fm or fmn.
  with packet radio satellites (uo-22, echo) change this
  entry in "pkt", otherwise packet operation will not work
  properly.
i. please read the very important instructions referring
  to the 'doppler.sqf' file. you will find them in the file
  itself (at it's end) and in the 'auxiliary files' section
  of the satpc32 manual.
  there you will find instructions on how to easily determine
j. transverter/converter operation
k. restrictions of the ft-817/857/897 in satellite operation:
  these radios are not full-duplex satellite radios.
  when used for satellite operation therefore some points
  have to be considered:
  aa. the frequencies cannot be changed while the radio is
  in tx mode. therefore keep your transmissions short,
  particularly when the doppler shift changes very fast.
  bb. to update both frequencies the program has to toggle
  the vfos. also, there must be short delays between the
  single steps. therefore this process will take some time
  (1/2 - 1 second). to avoid frequency and mode errors let
  the program finish this processs before you switch to
  tx. the tx vfo updating process can be seen on the display,
  and can also be heard because of the short "holes" in the
  rx signal.
  the program will update both frequencies:
  aaa. after the user tunes to a new frequency (qsy),
  bbb. after returning to rx from tx,
  ccc. after an uplink correction.
  the frequency update will be carried out about 1 second
  after these events.
  errors may occur if the user begins to transmit at the same
  time that satpc32 is updating the vfo frequencies. if this
  happens, the program will automatically try to re-set the
  correct frequencies and modes. this process will take about
  2 seconds. if necessary the user can press the esc key to
  force the program to re-set the correct frequencies and modes.
                    ***** dk1tb ******
请指导一下
离线BA7JC
只看该作者 12楼 发表于: 2005-05-21
这样设置错在那还要设置其他什么地方呢,为什么我设置了1024x768还不能全屏的,先谢过3rj
离线BD3RJ
只看该作者 13楼 发表于: 2005-05-21
dde cat打勾 先用800x600,成功后再试别的。另,你看一下897的手册,看看连接速率bps值为多少,这个值很关键。
离线BA7JC
只看该作者 14楼 发表于: 2005-05-21
dde这个是控制什么的?我已经可以连接电台,连接电台后会自动锁上电台,选fm模式的星时是fm模式,选ssb模式的星时会自动变要lsb,只能控制模式的变换但是不能控制电台的频率自动变化,不知还要设置什么。
离线BD3RJ
只看该作者 15楼 发表于: 2005-05-21
dde是动态数据交换.
离线BD3RJ
只看该作者 16楼 发表于: 2005-05-21
从字面上看,需要你打开一个相应的doppler.sqf文件,这个文件有多谱了的参数,软件会通过这个参数自动调整频率.
离线BA7JC
只看该作者 17楼 发表于: 2005-05-22
连接速率bps的值是9600,已经设置好了,可以连接软件了,但只要选上dde cat启动软件就报错,搞了半天都不行,现在搞到头到晕了
离线BA7JC
只看该作者 18楼 发表于: 2005-05-22
operation valid only when the port is open
只要选上dde cat就出这句英文,真的不知如何搞,晕啊
