  • 16515阅读
  • 8回复
比较一下你DIY的DDS和国外DIY的区别 [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2005-05-16
当然公共部分就不用看了,只看不同之处.不要问俺,俺也是从乡下来的.
the basic full electric scheme is resulted above. advantage of the given scheme above other designs consists in that that, as the phase detector the element of type 74act74 http: // www.alldatasheet.co.kr/datasheet-pdf/view/fairchild/74act74.html is applied
from the offered sources of the manufacturer, at work with a pressure of 5 volt the range of working frequencies on inputs clk is possible up to 160 megahertz, that completely relieves of need of application of dividers of frequency with application of counters and by that a constant problem of phase noise in schemes of synthesis of frequencies completely and entirely depends on the active filter in a circuit of updating of a pressure of adjustment. the filter or as it still can be named loop filter, is included for the decision 3 задачь simultaneously:
to extinguish all frequency components of dividers n/m/p, p+1/a and r in pll.
to choose a parameter of phase noise from two sources of compared signal ref or vco, and by that "to pull out" outside best of two sources.
the third problem - it represents the greatest complexity and is the compromise 2 above costing. it is engaged in time of "calm" of the reconstructed signal or settling time. proceeding from that line vt is the most sensitive point in the scheme синтесайзера frequencies, from a choice of the order of the active or passive filter its ability "to clear" all спуриусы dividers and by that will depend at reorganization on other frequency, the installation time of the chosen frequency depends on complexity of the filter.
in other words the filter will not create a delay of time of reorganization easier but also will create danger to impose collateral handicapes on a line of adjustment vco.
in all clauses i mentioned a theme of phase noise which in my opinion is if not the most important that very important theme at проэктирование and construction синтесайзеров frequencies.
i in кратце shall try to explain that this such and why it is important. measurement of a parameter of phase noise or ssb phase noise make on a logarithmic scale from a constant отсечкой frequencies from half of peak of a measured signal. half of peak it because of ssb. because of that that the generator constantly "moves" the target signal to the right-to the left from the adjusted frequency, is created jitter. the density of components jitter also is phase noise.
columns explaining concept about settling time
columns explaining concept of phase noise.
the above there will be " a pure dynamic range ", the to receive the best sensitivity of the reception device easier, i.e. itself гетеродин does not bring collateral noise close to an accepted signal. from here the deviation from peak of the basic frequency of the generator as small as possible should be clear that and it will provide desirable result.
tак it is desirable to not apply in schemes active loop filtera such elements as lm-358 or mc-1741. the operational amplifier with parameter input voltage noise no more than 4 nv / (hz) strictly is recommended to use 0,5. these are microcircuits of type op-27 or clc430. http: // www.national.com/pf/cl/clc430.html http: // web.mit.edu/6.301/www/op27c.pdf
the bright example of that as looks a signal гетеродина very high quality.
now we shall return to the scheme. as it has already been told the given phase detector is capable to accept of two inputs signals of frequencies up to 160 megahertz that allows to apply the new kind dds ad9951, capable to receive clk with frequency in 500 megahertz and a target signal within the limits of 160 megahertz. the given scheme allows to be successfully applied in both вышеупомянутых clauses. if to apply this scheme in the first case (synthesizer eu1cc) changes will be such: we divide generator pice from dds, we change frequency of the generator for dds, raising frequencies of the crystal generator up to 33,3333 megahertz. that multiplication on х6 - internal function dds will allow to receive on output dds half of frequency of the generator = 33,333 megahertz x 6 = 199,999999 : 2 = 99,99999 megahertz. there is a need for change of the program of the processor. i shall notice, that the phase detector of the scheme with are active, the filter and dividers of frequency отподают.
for more "careful" cleaning there are additional variants of the passive filter of 3-rd order. see the scheme below.
i shall allow to specify, that for a step of reorganization already than 1 килогерц it is necessary to calculate the filter so, that it would support stable work of the scheme and would not allow to prevent "защёлкивание" vco on the chosen frequency.
in the second case - clause " still time about dds ", take place applications of the scheme of the phase detector and two examples of generators controllable by a pressure. first of them of industrial type from firm minicircuits pos-50 http: // www.minicircuits.com/cgi-bin/spec? cat=vco*model=pos-50*pix=a06.gif*bv=4
startfrf     stopfrf       fif         flo         convertion type
1,8 mhz     1,9 mhz     21,4 mhz   23,2 23,4 mhz up convertion
3,5 mhz     3,8 mhz     21,4 mhz     24,9 25,2 mhz up convertion
5,3 mhz     5,5 mhz     21,4 mhz     26,7 26,9 mhz up convertion
7,0 mhz     7,3 mhz     21,4 mhz     28,4 28,7 mhz up convertion
10,0 mhz     10,2 mhz   21,4 mhz     31,4 31,6 mhz up convertion
14,0 mhz     14,35 mhz   21,4 mhz   35,4 35,75 mhz up convertion
18,06 mhz   18,2 mhz   21,4 mhz   39,46 39,6 mhz up convertion
21,0 mhz     21,45 mhz   21,4 mhz   42,4 42,85 mhz up convertion
24,8 mhz     25,0 mhz     21,4 mhz   46,2 46,4 mhz up convertion
28,0 mhz     30,0 mhz     21,4 mhz   49,4 51,4 mhz up convertion
one of examples of calculation of frequencies with use of the standard crystal filter on 21,4 мегагерца. accordingly frequency ПЧ=21,4 мегагерца. the given calculation is intended for for the scheme with transformation "upwards". the given variant corresponds to application vco pos-50 which can quite satisfy requirements to the radioamateur equipment and not only house manufacturing. from help data about pos-50 it is visible that the range of frequencies of reorganization lays as-time within the limits of specified in the table above. vt=1~16v; fvco=23~51,7; it is necessary to remind, that at use of the given variant the correct pressure on a feed of active filter clc430/op-27 is necessary to submit. i have provided use of connection of type rail-to-rail +12-0 on the printed-circuit-board of scheme ФАПЧ so when there will be a need to apply the double power supply on + /-12в, it is necessary to clean the resistor - the crosspiece with face value in 1 ohm from the ground and to connect to contact-12 volt. instead of the resistor it is necessary to solder the condenser with capacity in 100 nf. dds so should be adjusted on 23~52 mhz.
vco for overlapping frequencies of 74~105 megahertz.
in the second variant apply following scheme vco to overlapping frequencies of 74~105 megahertz. 12 варикапов are applied with the purpose of improvement of a parameter of phase noise. application of 2 generators demands to take from the scheme under clause " still time about dds " the low-frequency filter existing on a payment and mmic amp. (era-3sm). in a place them the strip filter on the set frequency is necessary.
application of second loop ФАПЧ in two above described designs demands careful adjustment of low-frequency filters and so takes place applications of strip filters of 5-th or 7-th order тубулярной structures with calculation 50-ти омной loadings/signals
离线秋风秋雨
只看该作者 1楼 发表于: 2005-05-17
dds or pll ??
在线bg6qbv
只看该作者 2楼 发表于: 2005-05-21
is this dds??????
在线bg4iww
只看该作者 3楼 发表于: 2005-05-22
还有vco???
离线radiolee
只看该作者 4楼 发表于: 2009-01-15
wide band vco?
离线husy
只看该作者 5楼 发表于: 2009-02-02
3阿姐是讲老外的diy,把第一幅图的电路性能,全部用图表列了出来,让读者明白整个电路的性能。国内的diy要向老外学习。
离线okokart
只看该作者 6楼 发表于: 2009-02-12
Collections of the British public bodies
the beautiful furniture painting "no. mang yong warships" is hidden in the british national gallery, but also access to the internet is about 200,000 public the list of paintings.
  recently, bbc announced that the british public bodies 200,000 collection of paintings one by one onto the network, not only so, the british arts council film huge archive will also be likely to be placed on the network. this plan is quite ambitious bbc mark thompson, bbc in london, the company introduced in 2009 in music, art, cultural aspects of the arrangements disclosed. this action or to restore the bbc during this period is reported as a result of refusal to grant the demands of humanitarian assistance in gaza and invite criticism of the sky.
  in britain there are many famous paintings, but the public does not always have the opportunity to see these works, 80% of the works not to be displayed. the bbc and the public directory of the foundation together with all the public institutions of paintings in 2012 in the former onto the network, available to the public admission is free.
  bbc said that they will be specifically for this setting effort in the bbc's official website (bbc.co.uk) established a new branch, called "your painting" (your paintings), in this section of the public can look to and see to the british national collection of oil paintings of all information.
  public directory of the foundation was established in 2003, the main task is to estimate that about 200,000 paintings archived video. at present the british public collection of paintings has been kept for the purpose of 30%.
  in addition, bbc revealed that it is and the british arts council representations to try to convince the british arts council the first time of its collection and archival material on the network is open free to the public, including the british arts council has a huge movie data, which can be traced back to the 1950s.
  is expected before the end of next year the first batch of oil paintings in public collections online public display, all the work there is hope in all of 2012 before the internet. bbc mark thompson said: "bbc will take a number of means to fulfill their responsibilities for the arts. as broadcast media, we can not assume that the media can be replaced by people with direct contact with works of art. but i deeply believe that if we can demonstrate the art of words, will be able to encourage more people to personally see to appreciate these arts. "
  in addition to oil paintings in public collections outside of the internet show, bbc is also planning a series of related to art and culture activities, among people interested in this area, including a number of television and radio programs to link up the "poetry of the season" and joint launch of the british museum to see 100 exhibits like world series broadcasts in february for next year's pre-exhibition of the same title, in addition to a series of master of the documentary is also planned.
article come from : http://www.okokart.com
离线zly
只看该作者 7楼 发表于: 2009-02-12
做广告,我也看不懂。
离线beilwei123
只看该作者 8楼 发表于: 2009-02-17
welcome to shanghai escort
