  • 4542阅读
  • 1回复
European Sprint contests [复制链接]
离线SWLer
只看楼主 倒序阅读 0楼 发表于: 2005-04-06
european sprint contests
this email is to invite all contesters to have a go in the european
sprint contests 2005. the phone contest is on saturday 9th april
and the cw leg is the following saturday, 16th april.
if you're wondering which software to use, dl2nbu's program has
been written specially for this contest. it is very much like k1ea's ct,
and it is free for download from the new eu sprint web
site <http://www.eusprint.com>.
sd by ei5di, trlog by n6tr, writelog, n1mm contest logger
(and many others) all support the eu sprint, and if you prefer to log
on paper, that's fine as well. we accept any fixed column ascii
file, too.
so, we hope you will give the sprints a try in april, and then send
your logs to <eusprint@kkn.net>. the full eu sprint rules are shown
below.
73 from the eu sprint gang
g4buo, i2uiy, ok2fd & 9a6xx
about eu sprint:
- download the free software,
- rules in english, italian, french, spanish, portugese, russian, czech,
  german, polish, greek, croatian
- all past results from 1994,
- download full logs and ubn reports,
- all time records,
- find more information about log checking,
- and much more about the eu sprint....
you will find everything here: <http://www.eusprint.com>
eu sprint contest - 2005
entrants: any licensed station may enter the sprint. european stations can
work everybody; stations outside of europe can work only european stations.
categories: single operator only. only one signal may be aired at one
time. low power entries (up to 100w) will be indicated by an asterisk (*) in
the listing.
dates:
eu sprint spring:
* ssb: second saturday in april - 9 april 2005 - managed by g4buo
* cw: third saturday in april - 16 april 2005 - managed by 9a6xx
eu sprint autumn:
* ssb: first saturday in october - 1 october 2005 - managed by i2uiy
* cw: second saturday in october - 8 october 2005 - managed by ok2fd
time: from 15:00 utc until 18:59 utc.
bands: 20, 40 and 80 metres only.
pilot frequencies are: ssb: 14.250, 7.050, 3.730. cw: 14.040, 7.025, 3.550
exchange: all of the following data must be part of the exchange:
a) your callsign,
b) the other station's callsign,
c) your serial number starting from 001 (rst not required),
d) your name or nickname.
please note that both stations must repeat both callsigns during the
exchange.
a valid exchange is: "ok2fd de i2uiy 118 paolo" while "ok2fd 118 paolo" is
not a valid exchange.
special qsy rule: if any station initiates a call (by sending cq, qrz?,
etc.), he is permitted to work only one station on the same frequency. he
must thereafter move at least 2 (two) khz before he may call another
station or before he may solicit again (cq, qrz?, etc.) other calls.
valid contacts: valid contacts are qsos correctly logged and confirmed.
each operator may use one and only one name during the sprint. if the
exchange is copied incorrectly, that operator will receive zero (0) points.
in case of miscopied callsigns, both stations will receive zero (0) points
for that qso.
scoring: each valid qso counts one 1 (one) point. the final score is the
total number of qsos.
awards: colorful certificates will be issued to the winners of each sprint,
and to the leaders in each country.
eu sprint plaque: a special plaque will also be awarded for the top
three scores from all four contests combined. to be eligible for this
award an operator must enter at least three of the sprints in the
year. results will be forwarded as soon as possible to leagues,
magazines and bulletins.
logs: a single chronological log is required. please send us your log via
email or on a floppy disk, if you use computer for logging. use any of the
available software or send a plain ascii file. eu sprint is supported by
all the major software (n6tr, writelog, n1mm, superduper and many
others; see the software information on our webpage). please send us
the right files: for dl2nbu software, send yourcall.asc; for n6tr
software, send yourcall.dat; for writelog, send cabrillo file.
if you want the latest release of the dl2nbu software, you can download
it from the new eu sprint web site: <http://www.eusprint.com>.
log files must be sent no later than 15 days after the contest to:
<eusprint@kkn.net>. the receipt of your electronic log will be immediately
confirmed. if you do not receive a confirmation within few hours, try again
or use the postal system.
disk logs, or paper entries must be posted no later than 15 days after
the contest to the appropriate address:
* spring ssb sprint: dave lawley, g4buo, carramore, coldharbour road,
penshurst, kent, tn11 8ex, england, uk.
* spring cw sprint: hrvoje horvat, 9a6xx, 25 rujan 4, hr-52000 pazin,
croatia.
* autumn ssb sprint: paolo cortese, i2uiy, p. o. box 14, 27043 broni
(pv), italy.
* autumn cw sprint: karel karmasin, ok2fd, gen. svobody 636, 674 01
trebic, czech republic.
by bg5hii
离线SWLer
只看该作者 1楼 发表于: 2005-04-09
今天晚上11点到凌晨3点...
