  • 17055阅读
  • 32回复
一款3-30Mhz简单易做的QRP天调 [复制链接]
离线bd2bh
只看楼主 倒序阅读 0楼 发表于: 2005-03-23
introduction
这款天调主要用于低功率的qrp场合,当然如果材料特别是电容耐压(>5000v)允许,也可以用于100w的发射机。这种天调的特点是选材容易,制作、使用方便,可根据需要方便的切换,通过不同的组合,可以覆盖3-30mhz宽广的频率范围,省略了通常电路需要的两个可变电容的组合方式。
国内如果可找到动片>2mm的可变电容(我做的电容约2mm的间隙,100w偶尔也打火),还有这种滑动式连续可调的电感制做就方便了。喜欢diy的ham不妨尝试以下。
使用方法
use
connect the transmitter output to the swr meter, the swr meter output to the input of the transmatch, and the antenna to the output of the transmatch. set the capacitance switch to 0 (center), adjust the variable capacitor to the mid point. adjust the inductor to near the minimum inductance. briefly transmit and observe the swr reading.
increase the inductance until the minimum reflected power and maximum forward power is observed. adjust the capacitance for the best swr reading. it is necessary to go back and forth on the adjustments to find the best match. if the best match is found with the capacitor at the max value, switch in either the 270pf or 510 pf parallel capacitors and re-adjust the variable capacitor and inductor.
be careful not to leave the transmitter on for too long in the unmatched condition, doing so can damage the output transistors. if your transmitter has a variable output power, tune up at low power then re-adjust the circuit at full power. if you are using a vacuum tube transmitter, don't worry about it. caution: higher power transmitters can generate high voltages in this circuit, don't touch any of the wires when the transmitter is operating. the set screw on the roller inductor knob may be electrically hot during use, you may want to cover it with a drop of plastic glue after tightening.
离线58shf
只看该作者 1楼 发表于: 2005-03-23
线圈调节装置看不懂,能讲一讲吗?
离线BG1KGM
只看该作者 2楼 发表于: 2005-03-23
喜欢,有价吗?求一个
离线BA5DX
只看该作者 3楼 发表于: 2005-03-23
看上去实在不简单,比复杂的那种做起来还复杂
离线bd2bh
只看该作者 4楼 发表于: 2005-03-24
我看很简单阿
这种连续可调的电感原理是:
等离螺旋(电感)作为主动轮,小轮作为从动轮,并随着大的螺旋电感转动(并纵向滑动)改变位置,因尔得以连续改变电感量。
如果觉得麻烦的话,可以用传统的抽头电感,用多刀开关变换电感量啊。
如果有加工能力的话,我想用车床在高频绝缘体上挑上丝扣再绕制电感,剩下就是加工工艺的问题了。
再者,国内也许有可承受大功率的可调电感吧。可惜耐高压的电容、电感都很难找~~~~
离线58shf
只看该作者 5楼 发表于: 2005-03-24
如果电感线圈主动旋转,那么还有一个看不见的滑动电极,是吗?
离线QSL599
只看该作者 6楼 发表于: 2005-03-24
我上张大图,看看能否看明白。
离线fangmin226
只看该作者 7楼 发表于: 2005-03-24
离线BG4KND
只看该作者 8楼 发表于: 2005-03-29
很高兴看到你的帖子我正在找关于天调的资料我准备购买一款100瓦的机器想配你这款天调能交流吗?
13563088381
离线bd2fw
只看该作者 9楼 发表于: 2005-03-30
在家里的话,还是尽量把天线调谐振,不用天调的好。
离线58shf
只看该作者 10楼 发表于: 2005-03-30
好图,大开眼界.送您73
离线BA5DX
只看该作者 11楼 发表于: 2005-04-01
就是说那个电感,实在不是一般人能做出来的,买成品就另当别论了
离线BA5DX
只看该作者 12楼 发表于: 2005-04-01
74上的功放就是主动旋转线圈的,一个陶瓷滚筒,一个金属滚筒,一根银带在两个滚筒上绕圈,改变陶瓷滚筒上圈数就改变了电感量。应该更可靠一些,但是制作起来就更难了。
离线bd2bh
只看该作者 13楼 发表于: 2005-04-01
用好天调,便捷高效
[quote=bg2fw]在家里的话,还是尽量把天线调谐振,不用天调的好。[/quote]
这话没错,最好的方式就是省去天调,尽量把天线的驻波调较低。
纵观当今的电台,基本上都把天调特别是自动天调作为标准配置,我想理由有以下几点:
1)从实用的角度考虑需要。对于集体或者流动性强的车船单元,应用天调就是一个很无奈的事情。因为,一是他们的天线往往不谐振于某个频点;二是无委配给的频率一般分为主频和若干个备频,还有日频、夜频之分,根据季节的变化,使用的频率也在变化,因此不可能象我们爱好者一样,一个频率架设一副天线,只图便捷高效,够用就成。
2)对于一般的d.p或者其他天线,也是如此。例如有的喜欢cw,天线调整时频率可能谐振在低端,而到了需要ssb时,天线的驻波可能达到3:1,这时也需要天调。因为我们同样不可能一个波段架设两副天线,或者没事再上房去调整天线的长短。就拿w-8010天线来说,它的设计已经尽可能低考虑了调整的方便性。即便是这种天线,你不楼上楼下,来来回回跑个十几次,你休想有成就感。对于大家喜爱的并馈多波段的d.p,还有缩短型的,具有限波器的天线更是如此,频带很窄,每个波段的调整相互有一定影响的,没有耐心最好不要玩。
3)根据前辈的经验,我们可用天调完成修剪得工作。---对于一般的d.p来说,按理论数据计算并架设好天线,驻波、阻抗的大小剩下的工作让天调来做,对于不愿麻烦的人来说也值,效率也不错。
4)全尺寸天线为前提,应用天调提高工作效率。常有人说天调没用,功率都消耗在里面了。其实,这也是历史上争论的多年的问题。有前辈做过试验,用同样一个功率计,在天调的输入端和输出端分别测量,在一般驻波3:1的情况下,其损耗仅3%,10:1时也只有7%。当然说的是应用于全尺寸的1/4或1/2天线,缩短性的天线不在考虑范围。所以大家没必要为这点点损耗而忧心忡忡。其实,天馈系统本身的损耗比天调插入损耗大的多。不信您可楼上楼下分别测量看,仅馈线、接头、天线本身,以及地面的损耗就远远不止这些,100瓦辐射出的功率有几何.
5)应用天调另一方面可以作为带通滤波器用。它可以减少不必要的带外辐射,接收时减少带外的交叉调制和干扰。一些数千瓦级以上的功放都是用天调(可以看作天调)做带通滤波器的。
离线梁山火腿
只看该作者 14楼 发表于: 2005-04-01
[/quote]
说得有道理,由于应用场合的不同,天调可以达到想达到的目的(尽量让发射机的负载理想化)。
当然,全尺寸的天线效率高是不可否认。
离线BA2QA
只看该作者 15楼 发表于: 2005-10-06
做一个                     试试
离线wycx
只看该作者 16楼 发表于: 2005-10-07
离线李剑
只看该作者 17楼 发表于: 2007-02-11
能否用固定电感来调抽头.
离线李剑
只看该作者 18楼 发表于: 2007-02-11
手动天调的问题
近日淘到一台CZ-1型短波天线调谐器.看内部做工不错.但因无此天调说明也不知调谐频率范围是多少.我接在FT-80C上天调后面接假负载和驻波功率表试验驻波很大.(接天线也是如此)功率出不来.不知为什么.请各位高手指点.看是哪里的问题另是否须要改动才可以工作在业余全段.在此深表感谢.(此天调发来时因板子没固定镙丝导致手动双连毁坏.后来又配上一样的按原样焊回)//对了看了下电路连接方法应是二只电感线圈中间串一固定电容和对地一只空气可调天容.由二只线圈用高压绝缘双连可调调整线圈抽头.
离线BD6AS
只看该作者 19楼 发表于: 2007-02-12
建议你画出这个天调的电路图,这样不问也清楚啦。
