  • 5198阅读
  • 1回复
PSK31--Has RTTY's Replacement Arrived? [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2005-02-15
by steve ford, wb8imy
there's a new hf digital mode in town and the gossip is flying!
i love rtty. we have a warm relationship that goes back to my new-ham days in the early ྂs when i was pounding green keys and reading conversations off rolls of yellow teletype paper. (personal computer? what's that?) i jumped on the amtor bandwagon in the ྌs and dabbled in clover, g-tor and pactor ii in the ྖs. still, like most hf digital enthusiasts, i kept coming back to rtty.
rtty didn't have the error-free copy of the handshaking modes, and you certainly could not swap binary files using its limited code. but for contesting, dxpeditions and just casual conversation, rtty was hard to beat. unlike the 'tor modes, you didn't have to worry about setting up handshaking links; type-and-transmit was the order of the day for rtty. conversations flowed easily and roundtable discussions (and nets) were possible. during digital contests and dx pileups, rtty became a mode of rapid-fire contacts. it wasn't as fast as phone, of course, but you could maintain a decent "rate."
no doubt you've noticed that i've been speaking of rtty in the past tense. no, rtty hasn't been tossed onto the ash heap of ham history--at least not yet. something, however, has arrived that has the potential to knock rtty out of the spotlight. that "something" is psk3 1.
prometheus unbound
psk31 was the brainchild of peter martinez, g3plx. if the call sign seems familiar, you might recall peter as the father of amtor. up until relatively recently, psk31 was the favorite of a small cadre of experimenters who used dsp development kits to put the mode on the air. that was all well and good, but it kept psk31 in the shadowy corners of our hobby where few knew it existed. like prometheus bringing fire to the mortals, however, peter blew the doors wide open by creating a windows version of psk31 that did all of its dsp magic using ordinary 16-bit pc sound cards. (the gods haven't yet bound him to a rock and summoned an eagle to eat his liver, but that remains to be seen!)
not content with creating psk31 for windows, peter placed it on the web for free distribution to the global ham community. talk about blasphemy! this meant that any ordinary ham could download the software and become active on psk31 almost immediately.
in an article that appeared in radcom, the journal of the radio society of great britain, peter explained why he developed psk31. simply put, he wanted to create a mode that was as easy to use as rtty, yet much more robust in terms of weak-signal performance. another criteria was bandwidth. the hf digital subbands are narrow and tend to become crowded in a hurry (particularly during contests). peter wanted to design a mode that would do all of its tricks within a very narrow bandwidth.
so what is psk31?
first, let's dissect the name. the "psk" stands for phase shift keying, the modulation method that is used to generate the signal; "31" is the bit rate. technically speaking, the bit rate is really 31.25, but "psk31.25" isn't nearly as catchy.
think of morse code for a moment. it is a simple binary code expressed by short signal pulses (dits) and longer signal pulses (dahs). by combining strings of dits and dahs, we can communicate the entire english alphabet along with numbers and punctuation. morse uses gaps of specific lengths to separate individual characters and words. even beginners quickly learn to recognize these gaps--they don't need special signals to tell them that one character or word has ended and another is about to begin.
when it comes to rtty we're still dealing with binary data (dits and dahs, if you will), but instead of on/off keying, we send the information by shifting frequencies. this is known as frequency shift keying or fsk. one frequency represents a mark (1) and another represents a space (0). if you put enough mark and space signals together in proper order according to the rtty code, you can send letters, numbers and a limited amount of punctuation.
the rtty code shuffles various combinations of five bits to represent each character. for example, the letter a is expressed as 00011. to separate the individual characters rtty must also add "start" and "stop" pulses.
for psk31 peter devised a new code that combines the best of rtty and morse. he christened his creation the varicode because a varying number of bits are used for each character. building on the example of morse, peter allocated the shorter codes to the letters that appeared most often in standard english text. the idea was to send the least number of bits possible during a given transmission. for example:
e is a very popular letter on the english alphabet hit parade, so it gets a varicode of 11.
z sees relatively little use, so its varicode becomes 111010101.
as with rtty, however, we still need a way to signal the gaps between characters. the varicode does this by using "00" to represent a gap. the varicode is carefully structured so that two zeros never appear together in any of the combinations of 1s and 0s that make up the characters.
but how would the average ham generate a psk31 signal and transmit varicode over the airwaves? peter's answer was to use the dsp capabilities of the common computer sound card to create an audio signal that shifted its phase 180° in sync with the 31.25 bit-per-second data stream. in peter's scheme, a 0 bit in the data stream generates an audio phase shift, but a 1 does not. the technique of using phase shifts (and the lack thereof) to represent binary data is known as binary phase-shift keying, or bpsk. if you apply a bpsk audio signal to an ssb transceiver, you end up with bpsk modulated rf. (if you want the gory details, read the psk31 software help files.) at this data rate the resulting psk31 rf signal is only 31.25 hz wide, which is actually narrower than the average cw signal!1
concentrating your rf into a narrow bandwidth does wonders for reception, as any cw operator will tell you. but when you're trying to receive a bpsk-modulated signal it is easier to recognize the phase transitions--even when they are deep in the noise--if your computer knows when to expect them. to accomplish this, the receiving station must synchronize with the transmitting station. once they are in sync, the software at the receiving station "knows" when to look for data in the receiver's audio output. every psk31 transmission begins with a short "idle" string of 0s. this allows the receive software to get into sync right away. thanks to the structure of the varicode, however, the phase transitions are also mathematically predictable, so much so that the psk31 software can quickly synchronize itself when you tune in during the middle of a transmission, or after you momentarily lose the signal.
the combination of narrow bandwidth, an efficient dsp algorithm and synchronized sampling creates a mode that can be received at very low signal levels. psk31 rivals the weak-signal performance of cw and it is a vast improvement over rtty, as i discovered first hand.
its terrific performance notwithstanding, psk31 will not always provide 100% copy; it is as vulnerable to interference as any digital mode. and there are times, during a geomagnetic storm, for example, when ionospheric propagation will exhibit poor phase stability. (when you are trying to receive a narrow-bandwidth, phase-shifting signal, phase stability is very important.) this effect is often confined to the polar regions and it shows up as very rapid flutter, which is deadly to psk31. the good news is that these events are usually shortlived.
from bpsk to qpsk
many people urged peter to add some form of error correction to psk31, but he initially resisted the idea because most error-correction schemes rely on transmitting redundant data bits. adding more bits while still maintaining the desired throughput increases the necessary data rate. if you double the bpsk data rate, the bandwidth doubles. as the bandwidth increases, the signal-to-noise ratio deteriorates and you get more errors. it's a sticky digital dilemma. how do you expand the information capacity of a bpsk channel without significantly increasing its bandwidth?
peter finally found the answer by adding a second bpsk carrier at the transmitter with a 90° phase difference and a second demodulator at the receiver. peter calls this quadrature polarity reversed keying, but it is better known as quaternary phase-shift keying or qpsk.
splitting the transmitter power between two channels results in a 3-db signal-to-noise penalty, but this is the same penalty you'd suffer if you doubled the bandwidth. now that we have another channel to carry the redundant bits, we can use a convolutional encoder to generate one of four different phase shifts that correspond to patterns of five successive data bits. on the receiving end we have a viterbi decoder playing a very sophisticated guessing game. peter describes it best:
"the viterbi is not so much a decoder as a whole family of encoders. each one makes a different 'guess' at what the last five transmitted data bits might have been. there are 32 different patterns of five bits and thus 32 encoders. at each step the phase-shift value predicted by the bit-pattern guess from each encoder is compared with the actual received phase-shift value, and the 32 encoders are given 'marks out of 10' for accuracy. just like in a knockout competition, the worst 16 are eliminated and the best 16 go on to the next round, taking their previous scores with them. each surviving encoder then gives birth to 'children,' one guessing that the next transmitted bit will be a 0 and the other guessing that the next transmitted bit will be a 1. they all do their encoding to guess what the next phase shift will be, and are given marks out of 10 again that are added on to their earlier scores. the worst 16 encoders are killed off again and the cycle repeats.
"it's a bit like darwin's theory of evolution, and eventually all the descendants of the encoders that made the right guesses earlier will be among the survivors and will all carry the same 'ancestral genes.' we therefore just keep a record of the family tree (the bit-guess sequence) of each survivor, and can trace back to find the transmitted bit stream, although we have to wait at least five
generations (bit periods) before all survivors have the same great great grandmother (who guessed right five bits ago). the whole point is that because the scoring system is based on the running total, the decoder always gives the most accurate guess--even if the received bit pattern is corrupted. in other words, the viterbi decoder corrects errors."--peter martinez, g3plx
operating psk31 in the qpsk mode will give you 100% copy under most conditions, but there is a catch. tuning is twice as critical with qpsk as it is with bpsk. you have to tune the received signal within an accuracy of less than 4 hz for the viterbi decoder to detect the phase shifts and do its job. obviously, both stations must be using very stable transceivers.
like most psk31 operators, i tend to stick with bpsk, but while i was enjoying a conversation with joe, k9bh, on 20 meters, he suggested that we give qpsk a try. after a brief pause, joe called me in qpsk. with a gentle tweak of my transceiver's vfo and a click or two on the software afc box, a yellow cross appeared in the tuning indicator and text began flowing across my screen. despite considerable fading and noise, i didn't lose a single character of text during the 20-minute conversation that followed. impressive!
离线BD3RJ
只看该作者 1楼 发表于: 2005-02-15
what do you need to get started?
the first step is to jump onto the web and download the latest version of psk31. make sure you download the latest version that's compatible with all sound card equipped pcs running windows 95 and 98. once you have it safely tucked away on your hard drive, install the software and read the help files.
assuming you have a reasonably stable hf ssb rig, you'll need to run two shielded audio cables between your transceiver and your computer. if your radio has an accessory jack that offers an audio line output, this is the preferred way to feed receive audio to your pc. connect one shielded cable between the radio line output and the sound card's line input. if your radio does not have a line output, you'll have to use the external speaker jack.
for transmit audio, use another shielded cable and connect it between your sound card's speaker or line output jack and the accessory audio input of your transceiver. you can also opt to route the transmit audio to your microphone jack, but you'll need an attentuator similar to the one shown in figure 1. if you use the accessory audio input, don't forget to disconnect your microphone before you go on the air. when you key the transceiver, the microphone may be "live," too!
figure 1--use this attenuator circuit if you intend to feed the psk31 transmit audio to your microphone jack. radioshack part numbers are indicated below.
t1--1:1 isolation transformer (273-1374)
r1--47 kw trimmer potentiometer(271-283)
figure 2--with this simple interface you can use a computer com port to key your transceiver.
and what about keying your transceiver? there are two approaches: use one of your pc's com ports and an interface like the one shown in figure 2 to key your rig via the ptt line at your accessory jack. or, simply switch on your transceiver's vox and let it key the rig when it detects the transmit audio from the sound card.
start the software
you'll be delighted to discover that the psk31 software is extraordinarily easy to use. as i've mentioned already, there are excellent help files included, so i won't go into the software features in detail. we'll just hit the highlights and drop some useful tips along the way.
the first thing you must do is set the sample rate for your sound card. this isn't as complicated as it seems. the vast majority of sound cards support sample rates of 11025 hz. all you have to do is type this number in the box that appears in the setup section. leave the center frequency at 1000 hz and add your call sign in the box below. in this section you can also choose which com port you want to use for transceiver keying, or select "none" if you are using vox.
switch on your transceiver and adjust your on-screen-sound card volume controls. make sure you know how to adjust the record sensitivity so as not to overdrive or underdrive the sound card input. you can usually do all this through the sound card mixer utility (this probably came with the sound card software, or may be part of windows).
listen first
start by placing your radio in the upper sideband (usb) mode. that's the convention that's been adopted by most psk31 users throughout the world.
psk31 signals have a distinctive sound unlike any digital mode you've heard on the ham bands. you won't find psk31 by listening for the deedle-deedle of a rtty signal, and psk31 doesn't "chirp" like the tor modes. psk31 signals warble-that's the best way i can describe them. they sound like high-pitched warbling carriers as you tune across them. (until i learned to recognize the sound, i was tuning in computer-generated spurs and wondering why the text was nothing but garbage!)
tuning in a psk31 signal, like anything else, takes practice. if your rig has digital tuning (most modern radios do) select 1-hz tuning steps or something close. if your radio will not tune in 1-hz increments, you can use 10-hz steps to get in the ballpark, then use your rit control to zero in, or rely on the psk31's automatic frequency control (afc). you must tune slowly because psk31 signals are narrow. if you become impatient, you'll sweep right past them! begin your search on 20 meters, between about 14068 and 14080 khz. that is where most of the psk31 activity is concentrated, although you'll find psk31 on other bands as well.
as you tune in a signal, watch the "waterfall" display immediately below the tuning circle. this display is analogous to an audio spectrum analyzer, continuously sweeping through a range of audio frequencies. detected signals appear as white traces against the dark background, moving from top to bottom like water cascading over a fall. your goal is to bring the white trace that represents a psk31 signal to a point directly beneath the circle (see figure 3).
figure 3--tuning in a psk31 bpsk signal. (in this diagram the tuning display has been enlarged for clarity.) as you tune across the signal, a white trace will appear (a). just make a slight adjustment and the psk31 signal is properly tuned (b).
as you center the signal in the waterfall display, you'll see that the flickering red bars in the tuning circle are suddenly switching to yellow and aligning themselves vertically. keep tuning until the bars are as vertical as possible. by this time you should be seeing text on your screen. congratulations!
you'll probably notice that the bars are starting to rotate slightly within the circle as you monitor the conversation. this is caused by drift--either the transmitting station is drifting or you are. no problem. just click on the afc box and the software will begin tracking the frequency changes.
transmitting
transmitting is actually easier than receiving, but before you begin, make sure you are not overdriving your radio by feeding too much audio from the sound card. using your sound card volume controls, click on tune or tap the f8 key and increase the card's output while watching your alc indicator. make this adjustment with the transceiver attached to a dummy load. if you must do it on the air, use the cw identifier and keep the transmissions short. when you see the alc beginning to activate, stop (click on tx off or hit f5). that's all the audio you need.
you'll notice a long, narrow box just below the larger receive window. that's your outgoing text window. the instant you begin typing in this window, the software will switch your rig to the transmit mode. when you've finished (answering a cq, for example), click on tx off or tap f5 and you'll jump back to receive. after you've established contact, click on the net box to allow the software to keep your transmit frequency on track with the receive frequency.
sending a cq is as easy as clicking on the cq button or tapping f7. the software will take it from there and will return to the receive mode when it's finished. it's worth noting that you can also use the psk31 software as a morse cw keyboard. just click on cw in the mode section and start typing. (psk31 does not decode cw, however.)
psk31: a testimonial
at the time this article went to press, i had been a psk31 user for about two months. i've been running psk31 using my icom ic-706 mkii transceiver and my end-fed long-wire antenna. to say the results have been impressive is an understatement!
here is an actual psk31 qso in progress.
my first psk31 contact was with k8srb on 40 meters. stan was only running 25 w to a g5rv dipole antenna, but the text on my screen was virtually error free despite the high noise levels. we chatted for about 45 minutes and stan passed along a wealth of psk31 tips. for example, he demonstrated the need to keep your transmit audio at the proper level by momentarily overdriving his rig so i could hear the difference and see it on the waterfall display. (the splatter appeared on the display as vertical lines to the left and right of the center position.) stan also clued me in on the importance of checking the net box so that our transmit and receive frequencies would track each other. as stan put it, "if we must drift, let's drift together!"
a few days later i had the spooky experience of being able to copy text from a signal i could not hear. i was tuning across the 20-meter digital subband when i saw a faint, ghostly trace on the waterfall display. i watched the display and tuned in the signal, but i could hear nothing recognizable in the noise. there may have been a warbling tone present, but i couldn't be sure. suddenly the text began to print a cq from wl7vo in chicken, alaska, near fairbanks. i answered and was astonished to see his reply. the contact didn't last long because the band was dying fast, but it was captivating nonetheless. if we had been using rtty a qso would have been utterly impossible.
since that time i've logged dozens of psk31 contacts, including a fair amount of dx. the mode is catching on quickly in europe, australia and japan. in fact, the activity level has risen to the point where you can find psk31 signals on the air just about any time 20 meters is open. i've also been plumbing the depths of 80 and 160 meters, looking for psk31 signals amidst the noise. the few contacts i've had on 160 have proven the power of psk31. despite mother nature's static crescendo i was able to copy readable text.
is psk31 the heir to the hf digital throne?
the best answer is a strong "maybe." i'm not brave enough to stick my neck out and predict that psk31 will overtake rtty as the number one "live" hf digital mode, but it is off to a promising start. even though amateur radio is a technological hobby, hams embrace change reluctantly. will the graybeards of baudot rtty forsake their deedle-deedles for psk31?
well, this semi-graybeard is ready to make the switch. i love the weak-signal performance of psk31. it seems far more suitable for hf than rtty. i will predict that an upcoming dxpedition is going to travel with psk31 software in one of its laptops. that much seems inevitable. and how long will it be before the first psk31 contests appear?
in the meantime i'll be prowling the bands for those telltale warbles. perhaps it is time for king rtty to retire and yield to the heir apparent. as we enter the new millennium will psk31 wear the crown? time will tell!
