  • 5117阅读
  • 10回复
用2M和0。7M的折合J型收发AO-51信号如何? [复制链接]
离线BD7TBP
只看楼主 倒序阅读 0楼 发表于: 2005-02-10
用tm-241a+2m 折合j型发射,c-450+0。7m折合j型接收 a0-51的信号如何?请这方面的高手指教。我的qth在广西北海(e:109。1000/w 21。4830),已下载了卫星的
跟踪软件。
离线bg7qa
只看该作者 1楼 发表于: 2005-02-10
我不是高手,不过,据资料显示,仅用单副天线不大可能达到接收与发送的,用阵列的话,可能还可以试试。
离线BD6AHP
只看该作者 2楼 发表于: 2005-02-11
7tbp,你要的nova软件,下载解压后直接可用,无需安装。记得将地理位置改为你的经纬度。
离线BD6AHP
只看该作者 3楼 发表于: 2005-02-11
晕死了,软件太大,贴不上来,您给个email吧,我发过去。
离线BD6AHP
只看该作者 4楼 发表于: 2005-02-11
对时小软件,直接运行后check---adjust即可。
附件: ATOMTIME.rar (0 K) 下载次数:117
离线BD6AHP
只看该作者 5楼 发表于: 2005-02-11
需要提醒你的:ao-51 2月工作状态
10 feb
fm repeater, v/s
uplink: 145.920 mhz fm, no pl tone
downlink 2401.200 mhz fm
16 feb - exp wed
fm repeater, l/s
uplink: 1268.700 mhz fm, no pl tone
17 feb
fm repeater, v/u, high power mode
uplink: 145.920 mhz fm, 67 hz pl tone
downlink 435.300 mhz fm
23 feb - exp wed
38k4 digital downlink, v/u, pbp bbs (pacsat broadcast protocol bbs)
uplink: 145.860 mhz fm, 9k6 pbp digital
downlink: 435.150 mhz fm, 38k4 pbp digital
24 feb
fm repeater, v/u
9k6 digital, v/u, pbp bbs (pacsat broadcast protocol bbs)
downlink: 435.150 mhz fm, 9k6 pbp digital
离线BD6AHP
只看该作者 6楼 发表于: 2005-02-11
ao-51 echo modes (list not complete)
fm repeater, v/u
downlink 435.300 mhz fm, output 1/2 watt
downlink 435.300 mhz fm, output 2 watts
fm repeater, l/u
uplink: 1268.700 mhz fm, 67 hz pl tone
downlink 435.300 mhz fm, output ?? watt
fm repeater, v/s
fm repeater, l/s
psk31, 10 meters/u
uplink: 28.140 mhz usb, psk31 mode only
downlink: 435.150 mhz fm, 9k6 pbp digital, 1/2 watt
9k6 digital, v/u, high power, pbp bbs (pacsat broadcast protocol bbs)
downlink: 435.150 mhz fm, 9k6 pbp digital, 1 watt
9k6 digital, l/u, pbp bbs (pacsat broadcast protocol bbs)
uplink: 1268.700 mhz fm, 9k6 pbp digital
downlink: 435.150 mhz fm, 9k6 pbp digital, ?? watt
downlink: 435.150 mhz fm, 38k4 pbp digital, 1 watt
38k4 digital downlink, v/s, pbp bbs (pacsat broadcast protocol bbs)
downlink: 2401.200 mhz fm, 38k4 pbp digital, 1 watt
38k4 digital downlink, l/s, pbp bbs (pacsat broadcast protocol bbs)
离线BD7TBP
只看该作者 7楼 发表于: 2005-02-11
谢谢6ahp,我已将时间设定,原来是装少了一项。 ,我用的是以下软件,中文版本,您是否试一下?同时感谢bd7ce。
http://www.stoff.pl/
离线BD7TBP
只看该作者 8楼 发表于: 2005-02-11
用单副天线,只要方向性不强,完全可以达到接收要求,只不过信号有强弱之分。但发射
的天线要求就很高了。
离线BD9TD
只看该作者 9楼 发表于: 2005-02-11
主你早日成功!!!!!!!
离线BG6TSO
只看该作者 10楼 发表于: 2005-03-11
哪位老大教叫我~我正在学这啊 先谢了
