  • 3392阅读
  • 3回复
A Coax Switch [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2005-01-28
cheap slide switch in a standard box.
the switch
fig 1 shows a proven inexpensive home-made antenna selection switch. if you question the use of a cheap slide switch and so239 coax sockets, read on. measurements in a physics lab showed there to be practically no reflection on hf and even on 70 cm the swr was below 1.3 : 1! that is explained as follows:
l the contacts in the slide switch have larger contact surfaces than many a bought coaxial switch.
l the wiring and switch contacts, between the top and bottom of the metal case, act as the centre conductor of a coax of near 50 ?.
it is a standard box measuring 54 × 50 × 26 mm (l × w × h) and the wiring between the switch and the coax sockets is done in 2 mm silver plated wire.
power handling capability
if the switching is done with power off, the switch can stand 800 w. i have used this switch for more than 15 years and even with 1500 w there have been no problems.
while building this switch, you might as well add a test point, e.g. to connect a ‘scope’ or frequency counter. the capacitors of 10 and 220 pf make a capacitive voltage divider and the extra loading, 9.6 pf, does not affect performance on hf. in fact, on 10 m it improves the swr as the extra capacity, in combination with the wiring it makes a filter which favours that frequency.
离线BG1FPX
只看该作者 1楼 发表于: 2005-01-28
3rj:收到你的短信,我正好要睡觉了,所以先翻译一半,另一半明天早上补齐。
同轴电缆开关
一、开关
上图是一个廉价的、自制的天线选择开关。如果你怀疑这样一个便宜的滑动开关(连同它上面的so239同轴电缆插座)是否能够使用,那么请继续看下去。我们在一个物理实验室对这个滑动开关进行了测量,结果显示,它没有任何hf反射,即使在70cm波段上,swr也低于1.3:1。这主要归功于两点:
(1)这个滑动开关的接点的接触面积,远远大于那些从商店购买的同轴电缆开关。
(2)金属盒顶部与底部之间的布线与开关接点,构成了一个良好的导体,相当于一根50欧姆的同轴电缆。
这个开关是一个标准的金属盒,尺寸是54×50×26mm(长×宽×高),开关与同轴电缆插座之间的布线,是直径2mm的镀银线。
离线BG1FPX
只看该作者 2楼 发表于: 2005-01-29
同轴电缆开关
一、开关
上图是一个廉价的、自制的天线选择开关。如果你怀疑这样一个便宜的滑动开关(连同它上面的so239同轴电缆插座)是否有效,那么请继续看下去。我们在一个物理实验室对这个滑动开关进行了测量,结果显示,它没有任何hf反射,即使在70cm波段上,swr也低于1.3:1。这主要归功于两点:
(2)金属盒顶部与底部之间的布线与开关接点,形成一个良好的导体,相当于一段50欧姆的同轴电缆。
二、功率
这个开关可以承受800w的功率。我使用它已经15年,即使功率高达1500w,也没有问题。
在制作这个开关时,你还可以在它里面增加一个测试电路,然后连接一个频率计数器(下图中的freq counter)或者其它设备。在下图中,10pf和220pf的两个电容器形成一个电容性的电压分隔电路,额外的加载(9.6pf)不会对hf性能造成影响。事实上,在10m波段,这个电路(包括布线)可以改善swr,因为它构成了一个滤波器,恰好与这个波段相匹配。
离线BA3CE
只看该作者 3楼 发表于: 2005-01-29
和我墙上的类似,呵呵。没问题,很好用。
