  • 7889阅读
  • 9回复
arrl一月七日新闻Surfin': Brew Your Own LC Meter [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2005-01-18
by stan horzepa, wa1lou
contributing editor
january 7, 2005
原文
this week, we surf to web sites that will help you build your own meter for measuring inductance and capacitance.
no homebrewing ham radio operator should be without an lc (inductance/capacitance) meter. and if a homebrewing ham finds him or herself without an lc meter, he or she must build their own or be kicked out of the homebrewer's union. to assist the homebrewer in this effort, there are some pertinent web sites.
if you are a homebrewing ham, you need an lc meter, so why not build one yourself like thecolumbus qrp club members did?
phil rice, vk3bhr, has a "surprisingly accurate digital lc meter" at theweb page of the same name. his design results in a direct reading inductance/capacitance meter. meanwhile, ji?í re?ek has an "lc-meter with the 89c2051" [url=http://www.hw.cz/constrc/lc_metr/ ]also at the web page of the same name.[/url]
both meters were inspired by a design of an lc meter, l/c meter iib, which was the brainchild of neil heckt and is available as a kit from almost all digital electronics. also, check out the tutorial for this kit by ian purdie, vk2tip, at the
electronic projects and electronics tutorial web site.
still another lc meter design is the cqrp club project-pic l/c meter from thecolumbus (ohio) qrp club. for what it is worth, the builders of this project claim, "for normal amateur radio applications, it is more than adequate and, in some aspects, has a broader range than does the aade lc ii b." your mileage may vary.
i thank raj kumar, vu2zap, for suggesting this week's topic.
until next week, keep on surfin'.
离线BG1FPX
只看该作者 1楼 发表于: 2005-01-18
我来前两段,请稍等,有客户来。
离线BD3RJ
只看该作者 2楼 发表于: 2005-01-18
homebrewing 是2个词连起来的,翻成家酿如何?嘿嘿
离线BD3RJ
只看该作者 3楼 发表于: 2005-01-18
第三段:
当你是一个家酿火腿时,你需要一个lc表,为什么不象哥伦布qrp俱乐部 里的家伙一样自己做一个哪?
离线BG1FPX
只看该作者 4楼 发表于: 2005-01-18
自制一个电感电容测量器
作者:stan horzepa(wa1lou)2005年1月7日
本周,我们访问了一些网站,这些网站可以帮助你制作一个测量电感与电容的仪器。
每一个喜欢diy(自制设备)的火腿,都应当有一个“电感电容测量表”(以下简称lc表)。如果一个火腿没有lc表,他要么自制一个,要么被踢出diy联盟!为了帮助那些有兴趣的火腿,下面我们介绍几个相关的网站。
如果你是一个喜欢diy的火腿,并且需要一个lc表,为什么你不仿效“哥伦布qrp俱乐部”的会员们,自制一个呢?他们的网址是:
http://www.touchinglittlelives.org/meter/
离线BD3RJ
只看该作者 5楼 发表于: 2005-01-18
第四段:
phil rice, vk3bhr, 在他名下的主页里有一个"令人吃惊准确的数字化的lc表"。 他成功的设计了一个直读时的电感/ 电容计。同时,他主页里还有一个"用89c2051的lc表"。
离线BG1FPX
只看该作者 6楼 发表于: 2005-01-18
睡觉之前,再把最后一部分翻译过来。
自制一个电感电容计
每一个喜欢diy(自制设备)的火腿,都应当有一个“电感电容计”(以下简称lc计)。如果一个火腿没有lc计,他要么自制一个,要么被踢出diy联盟!为了帮助那些有兴趣的火腿,下面我们介绍几个相关的网站。
如果你是一个喜欢diy的火腿,并且需要一个lc计,为什么你不仿效“哥伦布qrp俱乐部”的会员们,自制一个呢?他们的网址是:
phil rice(vk3bhr)有一台“准确得令人惊奇的”lc计,下面第一行是包含他名字的网址。他设计的是一种直接读取电感、电容的lc计。另外,jiri recek也有一个利用89c2051制成的lc计,他的网址是下面第二行。
http://ironbark.bendigo.latrobe.edu.au/~rice/lc/
这两种lc计都是从“lc计iib”那里获得灵感的,后者是neil heckt的杰作,它几乎成为所有数字电子计量的必备工具。ian purdie(vk2tip)为这个工具编写了一份指南,您可以在下列网站(电子工程与电子指南)找到。
http://my.integritynet.com.au/purdic/
最后一个是“哥伦布(俄亥俄)qrp俱乐部”下属的“cqrp俱乐部计划”研制开发的pic lc计。该计划的创建人声称,“对于一般的业余无线电应用来说,这个lc计已经足够了,它在某些方面,具有比aade lc ii b更广泛的用途。”换句话说,你可以用它走的更远。
感谢raj kumar(vu2zap)为我们提供本周的话题。下周见,别忘了上网!
离线迷思
只看该作者 7楼 发表于: 2005-01-19
非常感谢!就是推荐的太多了,不知道做哪个好了:(
离线wb4916
只看该作者 8楼 发表于: 2009-02-27
在这里看到原文了:
http://www.arrl.org/news/features/2005/01/07/1/
不过7楼所说的:
我翻遍了这个网站,都没有找到指南呀!
现在开始翻译:
http://www.aade.com/lcinst/lcm2b.htm
电子部分几乎全部数字化了
l/c表 iib
neil heckt
规格书
* 范围 0.001mh(1nh)到 100mh(大部分的表都达到了150mh)
* 0.01pf 到 1uf(大部分的表都达到了1.5uf)
* (不能测试有极性的电容:例如电解电容)
* 自动换挡
精度:典型误差为 1%
* 典型表示由 60 台电感校准基准所测得的平均误差:
o 20 台 hp 16470a 电感校准基准
o 16 台 booton 型 103a 电感校准基准
o 6 台 booton 型 62-2a 电感校准基准
o 18 台 marconi 型 tm 4520 电感校准基准
* 与 83 台电容校准基准
o 7 台 heathkit 的 0.25% 的电容校准基准
o 37 台 vero 的 0.1% 的电容校准基准
o 39 台 decade 的 0.5% 的电容校准基准
o 10 台 2% 的高值电容校准基准
* 详细结果请访问:http://www.aade.com/lcm2binst/hp.html
* 自校准
显示
  16位字符型智能 lcd
  4位有效数字
  直接以工程单位显示,例如:lx= 1.234 mhy / cx= 123.4 pf
采样率:
  大约为 5hz。在使用的时候,单位值将会显示会两种模式种的一种(根据测试对象的不同而自动调整)“micro mode”显示的单位位:uhy、mhy、pf与uf,在可用的时候。在这种模式下,例如:10.00nf 显示为 .01000mf,1nh 显示位 .001mh。这是像我这样的人所习惯的旧模式,并且被用在很多地方。“纳法”更多地在测量的时候使用。表 1 指示了每种模式下的显示范围。
离线littleworm
只看该作者 9楼 发表于: 2010-01-09
好资料 顶一个····
