  • 3247阅读
  • 0回复
I knew this was what he loved to do - I'd be a fool to try to change that! [复制链接]
离线BA4RF
只看楼主 倒序阅读 0楼 发表于: 2004-12-13
各位,翻译给xyl看看吧...
message: 3
date: thu, 9 dec 2004 1947 est
subject: topband: a visit with jack leahy ve1zz...
to: topband@contesting.com
message-id: <1df.307b47d1.2eea443b@aol.com>
content-type: text/plain; charset="us-ascii"
hello folks
i have been meaning to do a writeup on this for some time and with the
forbearance of w4zv allowing me the bandwidth, i thought most topband folks might
enjoy hearing about this topic.
this past summer i needed to take my wife over to halifax airport and after
dropping her off around 11am i made my way about an hour southeast over to the
head of jeddore which is on the se coast of nova scotia.
i had made arrangements with jack - and he was pleased that i was finally
going to return the visit he had made to my place in august of 2002. it wasn't a
bad trip out there at all - part of the time i was on a coastal road which
meandered in and out of bays, hills and forests.
when i reached his homesite i honestly must say that i was thinking "well,
how in blazes does jack poke out such a signal from this place?" at the time,
all i had seen was about 65 feet of road frontage with an old farmhouse right
at the roadside - and i could not see much at all in the way of antennas for
any band!
boy, was i mistaken.......!!
after saying hello to jack's wife opal, jack led me outside for a tour of the
antenna field.   this was quite an experience as jack's antenna farm is about
a half mile deep and it is built into a rising hillside that just keeps going
up up & up. it seemed we walked forever passing his 6m yagi on a small tv
tower, then his 80m 4 square array and finally near the top of the hill, his
modified 4 square for 160m.
we used to have a fellow near my home here in ny, w2yv dave horbachuk, who
used to refer to his station as the "$1.98 contest station". dave gave it this
name because nearly all of it was made from spare parts and discarded stuff
others had parted with. i was reminded of the w2yv station immediately and i
would have to call jack's place the "$0.50 cent lowband station" because what
that man has done with spare parts is nothing short of mind-boggling.
as we walked around his place on the outside, here are a few things i
remember:
1) a beverage common tie point with about 17 pieces of hardline coming into a
remote relay box - with a large empty sprite soda bottle covering the
important parts of the thing - that's all the weatherproofing there was...
2) his 80m 4 square was interesting as well. it was made out of old rohn 6
tv type tower and polypropylene guys - yet it looked solid enough. as i recall
the radiators were full-sized for 3.5mhz.
3) his 160m 4 square was not full sized - and was more like a 4 square that
used 70 foot tv towers for most of the radiators - with the remaining parts of
each radiator being #10 wire - so this antenna was really an inverted l array
on a four square footprint - and switched with a hybrid like a classic 4
square. as i recall, jack had built his own hybrid. i noted that many of his
ground radials were made of 1" hardline - several hundred at least were old junker
pieces of the stuff that jack had acquired from a junkyard for nothing.
4) his base insulators were novel indeed. under each rohn 6 tv tower was an
old tire wheel lying flat on the ground. on top of the tire was a flat piece
of procelain - and the tv tower just sat atop the procelain! not elegant -
but it works - as most of us know who have heard jack's topband signal.
5) the piece de resistance was jack's 137khz xmit antenna. this antenna
started at his house and went up almost the entire length of his property - which
means about a half mile of #10 wire (or better) to some spruce trees at the
very top of his hill. about 1/2 way up there was a little shed - and inside was
the biggest loading coil i have ever seen. it was about 8 feet in diameter
and the vertical supports for the wire were made of 4" pvc tubing standing
vertically about 5 feet in height. i'd say there was about 1000 feet of #10 wire
wrapped around these pvc supports - which was necessary to make the thing hit
137khz.
jack explained that he was having trouble forcing current into the antenna -
so his solution was to put on rubber gloves and tape up a big alligator clip.
he then had his xyl key the rig on 137khz and he kept fishing up and down the
coil with the alligator clip and a dc ammeter until he found a tap point that
was putting the rf into the antenna. neat solution again i thought....
it is probably not too well known, but jack was the first na station to work
into europe on 137khz - at least i think this is true - he had a certificate
for the qso with some g station i cannot remember. jack said he had to use
computer recognition to copy the incoming cw - he said it was very slow speed cw
and he could not hear it but he could see it on the computer....impressive i
thought.
6) i should mention that i saw beverages everywhere - most of them 1000 feet
or better. at least 20 of them i think in all.....
7) inside the shack was a very modest layout of home-made stuff - homebrew
amps for the hf bands and one also for 6m - and a ts830s for his main radio. i
think i saw a second radio as well - i think it was an little icom radio - but
jack said he used the ts830s mainly for 160m work.
his operating table was quite compact with room only for a paddle situated
parallel with the front of the table. interestingly enough, jack is a leftie
and while this would have been too tight for me to work with, it seemed to suit
him just fine.
8) after the inside tour, jack took me through some outbuildings - i'd say
there were about 6 rooms i viewed. each of these was filled with one principal
kind of device.
eg: one room must have had over a 100 vacuum variables in it of all shapes,
working voltages and sizes. another room was filled with eimac tubes - all the
way from 4-400's to 4-1000a's. another room had small parts. another room
had older tube type radios he had used years earlier. and on it went.....
9) one of the most interesting things i learned while there was during a
discussion with opal, jack's wife. i don't know how we got onto this topic, but i
asked her how she felt about jack and his radio hobby (since he lives on the
radio). her reply to me was unique and a pleasure to hear. she said "jeff,
ever since i met jack i knew this was what he loved to do - i'd be a fool to try
to change that!"
(i've met a few wives of some big contest stations over the years who could
learn a few things from opal!!!!   this is probably one of the biggest factors
that has allowed jack to be so successful for so long on topband.)
i'll close with this final observation. when i arrived there, i said "how
the hell can jack be so loud from this place?"
after seeing it all, especially the views from the top of the hill almost a
mile behind his small farmhouse by the road., i knew the answer. it is a fine
qth overall, with a superb shot to the south out over the ocean and the head
of jeddore. plus jack is as close to europe as you are gonna get in na -
except perhaps for vo1.
it was a great visit with one of the arcons of 160m. i hope to get back
there one day for a return visit.
73 jeff
k1zm@aol.com
