  • 2492阅读
  • 2回复
RTTY DX [复制链接]
离线BY1CJL
只看楼主 倒序阅读 0楼 发表于: 2004-11-21
哪位朋友英文好给帮一下汉化:
macro command list
\ for group 1 macros, \ at the beginning copies the message to the transmit window and puts mmtty into transmit mode. if you do not use the \, group 1 macros put mmtty into transmit and are transmitted without appearing in the transmit window.
\ for group 2 macros and window macros, \ at the beginning clears the transmit window.
\ for group 2 macros and window macros, \ at the end of the macro switches to receive.
# for group 1 macros, # at the beginning copies the message to the transmit window, but mmtty does not go into transmit mode automatically.
# for group 1 macros, # at the end of the macro repeats the macro.
# for group 2 macros and window macros, # at the beginning puts mmtty into transmit mode and begins transmitting the macro. if you do not use the #, you must put mmtty into transmit mode with the tx button.
%c the other operator's call sign from the call window.
%f gm/ga/ge (see note below).
%g greetings ?hello/good morning/good afternoon/good evening (see note below).
%m my call sign.
%n the other operator's name from the name window.
%q the other operator's qth.
%r the other station's rst from the rst window (it may include a contest number).
%s my rst.
%t utc time in 1234 format.
%d current utc date (e.g., 2000-sep-05).
%e end of definition.
%f force transmit fig code
%l force transmit ltr code
%m the contest number portion in my rst.
%n the contest number part (after rst) of his/her rst from the rst window.
%r the rst part of his/her rst from the rst window.
%t current utc time (e.g., 17:44).
^ wait for 1 second.
~ stop transmitting mark (stop carrier).
[ disable diddle.
] enable diddle.
离线BA3CE
只看该作者 1楼 发表于: 2004-11-21
我把我的mmtty宏给你算了,你改一下既可以。
离线BY1CJL
只看该作者 2楼 发表于: 2004-11-22
先这样吧,好的,怎么给我,你不常在线呀,今天我有四节课
