  • 45184阅读
  • 196回复
TS-590 2010 Kenwood新产品 [复制链接]
离线bg2ob
只看该作者 80楼 发表于: 2011-01-29
另一个评价(4分)
k9nz rating: 4/5 jan 17, 2011 20:47 send this review to a friend
good but not great   time owned: 0 to 3 months
this review is from a cw stand point only. the 590 is a good radio but it is not in the same class as my k3 or a flex 5000. there is some blow-by with filters and why did kenwood preset the filters? its a great rag chewing rig but its not a contest radio or a get down in the mud to get that new one on 160 meters rig as compared to what i have now. and one more thing why didn't they have and extra slot for another roofing filter? i still have my ts 520se, i like kenwood and have owned them all and mean all (520-950sdx) it's a good radio.
k9nz
离线bg2ob
只看该作者 81楼 发表于: 2011-01-29
一个日本人的评价
jp1djv rating: 5/5 nov 6, 2010 09:29 send this review to a friend
good radio in the price range   time owned: 0 to 3 months
how you feel about ts-590 might varies what you expect it.
i have played with ts-590 for some weeks. compared with ts-950sdx,870,850 which i had before, ts-590 works well but i still can't find a big difference from them. ts-590 is just one of good trxs in this price range(almost lowest range of hfs). if you are looking for the best trx in the world, i strongly recommend you to purchase high-end models(so-called flagship model) which have more high-quality and reliable parts, better electrical circuits. but if you want to have a good trx at a reasonable price, ts-590 can be one of the best choices. i didn't expect too much before i bought it because it seemed to be so cheap. but ts-590 is now entertaining me with its supreme performance. good job, kenwood.
只看该作者 82楼 发表于: 2011-01-30
有空用了半天,用不同带宽听cw,明显50hz的带宽还是可用的。以前icom的也能调到50hz带宽,可是无论soft还是sharp都是会有cw的上下沿和噪声滤波收窄后会糊在一起,感觉icom的dsp50hz带宽算法是显示他们的dsp能力而已,标榜的作用大于实际应用。
可是k的ts590真的还是不错,听起来点划还是很清晰的。
离线BA1IO
只看该作者 83楼 发表于: 2011-01-30
[quote=老干部]有空用了半天,用不同带宽听cw,明显50hz的带宽还是可用的。以前icom的也能调到50hz带宽,可是无论soft还是sharp都是会有cw的上下沿和噪声滤波收窄后会糊在一起,感觉icom的dsp50hz带宽算法是显示他们的dsp能力而已,标榜的作用大于实际应用。
可是k的ts590真的还是不错,听起来点划还是很清晰的。[/quote]
离线fuyunfan
只看该作者 84楼 发表于: 2011-01-30
[quote=老干部]还没比过,只是感觉一点皮毛而已说不上测评。
现代的icom机器类似瑞士军刀,什么功能都有,放大镜,尺,螺丝刀镊子。。。。当然它还是一把刀。7700,7600就如同花哨的瑞士军刀。
590设计比以上的机器都要晚,吸收了k3设计的一些成功卖点,仅此而已。算是半专业的刀了。
[/quote]
要说7600算是 瑞士军刀 我不说什么~590跟7700不是一个档次的~~!
只看该作者 85楼 发表于: 2011-01-30
噢,呵呵,也许4万多是有点贵了,不比较这个7700了。
仔细没在ts590维修手册找到调维修菜单的那个短路头,倒是找了一下ts570手册上有,发到这里。
离线BA4EG
只看该作者 86楼 发表于: 2011-01-30
看上去性价比还是可以的,决定性能比较没有意义。
离线BA4EO
只看该作者 87楼 发表于: 2011-02-07
今天用了一下这机器,很不错,机器不热,很稳定,声音(听广播)有蓬蓬声。
离线bd8uk
只看该作者 88楼 发表于: 2011-02-07
这收音机看来不错,攒够钱就进一台来听"中国之声"用……。
老干部您那边是哪里进的货?价格大约多少?
只看该作者 89楼 发表于: 2011-02-07
不热?请你不是来煲机的吗?
价格不要问我了呵呵,商业机密
离线BG0APD
只看该作者 90楼 发表于: 2011-02-07
自己手头有trc-80、ts-50、ts-450、v71、f6a、308、208等几乎一色的建武,听老干部介绍了这么多,心里实在痒痒,何时入手一台590,犹豫中......
离线BA7IAG
只看该作者 91楼 发表于: 2011-02-08
参考价格
ts-590s
离线net2000
只看该作者 92楼 发表于: 2011-02-08
上面有ham估计很准的,这机大概一万四一台,没有购买的价值,或者说对比性能相近的机子,没有明显的竞争力。
只看该作者 93楼 发表于: 2011-02-10
来看看类似k3的单接收配置如同590差不多的功能
k3/100   100 w transceiver kit 需要自己装配的100w k3基本套件单接收板上有2.7k的5极滤波器 1,949.95
kat3 internal atu with 2nd ant. jack 内置天调,多第二天线接口299.95
kbpf3 general coverage rx bandpass module 覆盖全段的天线输入接收带通139.95
mh2 hand microphone (for the k3/k2)   类似cb机质量的手持话筒59.95
kusb   usb (universal serial bus) adapter for the k3 usb接口(可能还不带有音频,猜想) 39.95
kfl3b-fm     13 khz fm (required for fm) 调频模式用if滤波器130.95
kfl3a-6k     6 khz am / essb, 8-pole (req'd for am) 调幅滤波器130.95
kfl3a-500   500 hz, 5-pole 500赫兹cw滤波器5极 89.95
k3 owners (operating) manual printed 印刷的手册 (不买可以自己打印)19.95
如同ts590的选件,so-3,vsg1一样
ktcxo3-1 tcxo (0.5 ppm typ) high stability ref. osc.99.95
kdvr3 digital voice recorder   语音录音模块129.95
以上的elecraft的k3价钱还是散件,并非预装好的,回来慢慢收拾起码1周。
总价不算了,肯定比ts590的1800美元贵很多了。至于性能590应该在k3和ftdx5000之下,但是比一般的ft950,ic7000甚至ic746p应该强,声音好还算是卖点。功能上肯定不如7600和756p3(起码没有同波段双接收,也没有利用双接收的频谱),但是比较7600和756p3的接收来讲,590表现会更好一些。
只看该作者 94楼 发表于: 2011-02-11
离线bh7ni
只看该作者 95楼 发表于: 2011-02-11
先忍着,实在忍不了就买
只看该作者 96楼 发表于: 2011-02-11
突然发现bh7ni几种机器都有的480,7000和857
离线bg2ob
只看该作者 97楼 发表于: 2011-02-11
bd4aqr       rating: 5/5       feb 11, 2011 01:43       send this review to a friend!
easy to use great sound       time owned: 0 to 3 months
i gave the ts590 to myself as a christmas gift. since i'm quite accustomed to the operation of ts570d, it didn't take me long to get my hands on ts590 even without manual.
pros:
all necessary functions can be accessed through hard buttons or as the 2nd function of these buttons.
also, it's quite convenient to operate the radio from remote network access. i tried to control the radio by remote access
through a vpn software (hamachi2) and it worked well. the vpn access eliminates the problems caused by routers.
simple remote login management is also available and some important trx menus can't be accessed through remote control thus key parameters won't be altered.
i'm also very glad to say that sound for medium speed cw under 50hz bw is still clear, not fuzzy at all. filters for ssb and cw are handy to use, though there aren't many options (soft or sharp roll-off) available.
cw tuning feature is still one of the key features that persuaded me to choose kenwood radios.
the voice-recording assembly is still on the way, thus no further tests on it's performances and sound quality have been carried out.
i won't spend money on features that are not related to reception performance (spectrum analyzing, rtty and psk encoding and decoding, etc.). that means i need a professional screw driver rather than a swiss knife. there's no doubt that ts590 is one of the ideal choices available on the market these days.
cons:
1. hope to have seperate tx-disable control for different bands to avoid misuse
2. buttons are not well distinguished from each other and operator needs to read the label before being able to know the function. ts570 is better designed with respect to this point.
3.found that some can not be turned off background noise.
bd4aqr_kf5gsv
73!
只看该作者 98楼 发表于: 2011-02-11
把这个也贴上来了,这测评还要谢谢刺猬!
离线bg2ob
只看该作者 99楼 发表于: 2011-02-11
您不在国内发表,我只能粘贴过来了。。。
