  • 32818阅读
  • 100回复
短波数字通信 [复制链接]
离线BD2ALB
只看该作者 80楼 发表于: 2009-11-29
最近一直关注短波数字模式通信,以下几个链接觉得不错,共享一下,便于大家参考!
http://ilgonis.orgfree.com/digiar.htm   以答问形式介绍新的数字模式!
http://adif.ham-radio.ch/files/modes_v100.htm   通过对比介绍了大量数字模式!
http://f1ult.free.fr/digimodes/multipsk/digimodesf6cte_en.htm   以软件支持模式的方
式介绍了相关的数字模式!
我用谷歌自动翻译的不好,试了试一个单词、一个词组的方式翻译,还凑合。
离线BD2RWR
只看该作者 81楼 发表于: 2009-11-29
多找一些国外的资料大家参考很好,psk31等是ham玩数据通信比较好的软件。
离线BD2ALB
只看该作者 82楼 发表于: 2009-11-29
q: how do the various digital modes compare?
a: this is a hard one to answer. i have done a few tests with the most promising modes. from my experience i would rank the olivia modes first: 8 tones 125 hz is very sensitve but also very slow, then come 8 tones 250 hz, 16 tones 500 hz, and 32 tones 1 khz, to name the most common. behind olivia comes domino ex with fec, then pskfec31, mfsk8 (which is slightly better than mfsk16), then psk63f, pskam50, qpsk31, and bpsk31. the very narrow band and slow modes like pskam10 easily lose sync when subject to fading. jt65 should be usable with a s/n ratio of -30 db, but you can exchange only very little information with it. last is rtty, which has no error correction capabilities, and requires around 200 hz bandwidth. i haven't included other modes like thor, mfsk4, mt63 or fmhell for instance, since i have not enough qso data with them to make a comparison meaningful.
here a few figures from patrick, f6cte (author of multipsk):
lowest s/n for 2% errors: -9 db for bpsk31 (for white noise in a 3 khz bandwidth), -6 db for qpsk31.
lowest s/n for 2% errors: -11 db for pskam50 and -19 db for pskam10 (for white noise in a 3 khz bandwidth).
lowest s/n for 2% errors: - 7 db for psk63 (for white noise in a 3 khz bandwidth).
however the "white noise" scenario does not match reality very often. in every test i did, qpsk was better than bpsk. also it is possible to use sharp cw filters for all the psk modes, mfsk 8 and 16, olivia with 250 hz bandwidth and rtty, all of which fit through a 250 hertz filter.
离线BD2ALB
只看该作者 83楼 发表于: 2009-11-29
他把部分数字模式进行了排名,参考参考:
1、olivia 8tones 125hz ,8tones 250hz ,16tones 500hz ,32tones 1khz
2、domino ex (fec)
3、pskfec31
4、mfsk8,mfsk16
5、psk63f
6、pskam50
7、qpsk31
8、bpsk31
离线BD2ALB
只看该作者 84楼 发表于: 2009-11-29
http://groups.yahoo.com/group/oliviadata/
olivia 雅虎论坛组!
下面是olivia的频率:
olivia center of activity frequencies (more info: click)
center freq khz vfo freq
usb audio center
mark hz bandwidth tone
14076.4 (cq) 14075.65 750 500/16
14107.5 14106.5 1000 1000/32
7043.25 7042.5 750 500/16
7073.25 7072.5 750 500/16
3583.25 3582.5 750 500/16
10143.25 10142.5 750 500/16
18103.4 18102.65 750 500/16
21087.25 21086.5 750 500/16
28076.75 28076.0 750 500/16
no spam- no fighting- just try to behave. moderators: nu4g,n7hiy,kq6xa.
离线BD2ALB
只看该作者 85楼 发表于: 2009-12-01
olivia is a ham radio digital mode designed to work in difficult (low s/n ratios plus multipath propagation) conditions on hf bands (though it also works as well on vhf/uhf). the signal can be decoded even when it is 10-14 db below the noise floor (i.e. when the amplitude of the noise is slightly over 3 times that of the signal). it can also decode well under other noise, qsb, qrm, flutter (polar path) and auroral conditions. currently the only other digital modes that match or exceed olivia in sensitivity are some of the wsjt program modes that include jt65a which are certainly limited in usuage and definitely not ragchew capable.
下面是我翻译的,还不是很通顺,特别是最后一段,请大家帮助翻译:
奥利维亚是一种设计在工作困难(低的信噪比和多径传播)的短波条件下的(尽管它也可以很好地工作在甚高频/超高频)业余无线电数字模式。即使信号低于噪声10-14分贝(即当噪声幅度略超过3倍的信号)该信号可以解码。其他的噪声下,它也能够很好地解码:qsb,qrm,扑动(极地路径)和极光的条件。
目前唯一的其他数字模式符合或超过奥利维亚灵敏度的都是wsjt程序模式,包括有一定限制的usuage和肯定不是ragchew能力的jt65a。
离线BD2ALB
只看该作者 86楼 发表于: 2009-12-02
自动翻译的:
奥利维亚进制频移键控数字通信正在成为业余无线电欢迎,因为奥利维亚是键盘输入的文本最可靠的方法之一,是可以执行在电离层的噪声环境中长途通信寄望在其他方式失败。这是可能的沟通与全球使用奥利维亚低至发射机几瓦的功率。阅读背后的奥利维亚发展:帕维尔jalocha故事。
奥利维亚是不同的业余无线数字键盘输入方法,一些其他类型的,因为它常常可以完全在最贫穷的信号解码噪条件,即使在人耳不能分辨的信号存在,即使它不能很容易看到传统的瀑布频谱显示。虽然是免费的业余乐队的漫游使用vfos,在任何业余频率运行在运营商的许可证条例“自愿channelisation的奥利维亚数字频率”,提高了业余的能力和奥利维亚同步通信使用极其微弱的信号,否则错过通过搜索通过vfo的调整。请参阅有关的频率图。这是一个观测相结合,建议,建议,共同使用的频率也由进制频移键控其他类型的使用,帕克思键盘。
离线BD2ALB
只看该作者 87楼 发表于: 2009-12-02
离线BD2ALB
只看该作者 88楼 发表于: 2009-12-03
信道衰落条件下的字符错误率与信噪比
上硬道理:
离线BD2ALB
只看该作者 89楼 发表于: 2009-12-03
olivia:
该协议的开发由帕维jalocha在2003年底完成。关于第一空中测试是由两个无线电业余爱好者,弗雷德oh/dk4zc和les vk2dsg在欧洲和澳大利亚的20米业余波段的路径进行的。证明是个行之有效的协议,并可以让经常与低至1瓦的rf功率洲际电台进行联络测试工作。自2005年以来奥利维亚已经成为在白噪声,衰落和多径,抖动(极地路径传输标准)和极光的传播条件下的标准数字模式。
离线BD3RJ
只看该作者 90楼 发表于: 2009-12-04
这个帖子到底要讨论什么?
离线BD2RWR
只看该作者 91楼 发表于: 2009-12-04
网上有关数据通信的软件和硬件文章很多,真正能做出在短波信道使用有实用价值的(包括试验)非常少,国内商业和军用短波modem基本是2款,39单音并行qpsk(美国10年前开发的方式)最高速率2400bit和4单音串行ftsk方式(最低限度通信系统)最高速率600bit。如果能写一个类似psk31的中英文传输软件,无信号时候没有乱码的,能提供国外的软件也好。一般的理论性探讨意义不是很大。
在线BD7JAC
只看该作者 92楼 发表于: 2009-12-04
bg2rwr你好,请帮忙看看我那个gl-5100是否属于数据通信的modem?
离线BD2ALB
只看该作者 93楼 发表于: 2009-12-11
新型业余数字通信模式在nvis方式下的优势(也适合dx):
离线BD2RWR
只看该作者 94楼 发表于: 2009-12-11
把功能先搞清楚,有说明书就才好。
离线BD2RWR
只看该作者 95楼 发表于: 2010-12-02
[quote=樊绍民]packet 通信介绍请见ba1aa《业余无线电通信》这p11-p12 。
10年前ba1nh托人从美国买回一台tnc ,结果上边标明 made in china 。
用mixw 软件和一般的接口电路,无法建立双方应答,但可以解调内容。
ba1eo[/quote]
现在国企工厂生产的hf数传modem也要1万元以上一端,10年前就是这个价格,基本都是harrs3466的仿制品,配套软件成熟,性能上和ham玩的是2回事.随着ham技术水平的不断提高,一些专业的通信技术手段有可能逐步的被掌握,层次的不断提高,成本完全可能降低到ham可以接受的水平.
离线BD4OS
只看该作者 96楼 发表于: 2010-12-02
由于是商业报告我只能透露这些,并且希望不要转载以上数据,我们不愿意自己公布跟竞争对手之间的对比,从某些方面讲这可能存在不公正的可能,看到您一直在问所以提及一下。
离线BD2RWR
只看该作者 97楼 发表于: 2010-12-03
bd4so:
.......未经波形修整的32载波,..........。
我认为是比较落后的技术,没有fec纠错在短波上误码率高的将不可想象.bg4kkz知道我的电话可以联系.
在线BD7JAC
只看该作者 98楼 发表于: 2010-12-04
............................................................................ [表情]
非常感谢bd4os的解释,既然涉及到商业报告,建议您将回复删除,我知道这些报告的重要性,就像当年我和信威公司签订td-scdma的技术保密协议一样,后来该标准才变成了大唐电信的标准,个中因由很大篇幅都说不完,呵呵。
这东西对我来说,只是想知道我现在能否用(“玩”更加恰当),如何使用,例如对于短波来说,能否作为aprs的连接设备。
离线BD2RWR
只看该作者 99楼 发表于: 2011-08-05
ba1eo[/quote]
这个玩玩可以,目前国内大工厂生产的hf-modem 基本没有改变美国调制解调和纠错方法。
