  • 15570阅读
  • 48回复
KXPA100 散包装带天调 817挚友 耐糙 静音 [复制链接]
只看该作者 40楼 发表于: 2014-05-21
收购有bug的kxpa100,要不寄过来借玩几天如何?
只看该作者 41楼 发表于: 2014-05-21
内测固件放出 (*EEF请看过来)
KXPA100 v1.32
KXPA100-v1.32 KXPA Firmware.rar (41 K) 下载次数:5
离线BG6JJI
只看该作者 42楼 发表于: 2014-05-21
更新了啥
到处游荡的机器人火腿,目前在丽江
RIG:我有一堆uSDX
ANT:随时都能抄走的拉杆GP天线
只看该作者 43楼 发表于: 2014-05-21
回 BG6JJI 的帖子
BG6JJI:更新了啥 (2014-05-21 14:46)
01.32 5-18-2014
Increase frequency counter "inertia"
01.29 4-22-2014
Add instant forward power query for KX3 ALC
01.28 4-8-2014
Correct a configuration save bug introduced in 01.26
01.26 4-2-2014
Correct power input computation
01.25 3-28-2014
Tolerate forward and reflected power overshoot for brief periods to support external antenna tuners.
When attenuator is acquired because of SWR or high reflected power, release attenuator immediately on next key up if SWR has been reduced to under 3:1.
01.23 3-13-2014
Use input power to qualify frequency counter samples
01.22 3-8-2014
Adjust input power threshold test and timing to compensate for end-of-tune overshoot
01.19 3-1-2014
Remove low supply voltage fault log entry when turning amplifier off
01.18 2-27-2014
Add Antenna Enable (one band) command:
•    Get format: ^AEbb; where bb is Band Number, 00-10 for 160-6 meters
•    Set/response format: ^AEbbn; where n is 1, 2, or 3 to enable ANT1 only, ANT2 only, or both antennae.
Add Antenna Enable (all bands) command:
•    Get format: ^AEA;
•    Set/Response format: ^AEAnnnnnnnnnnn; one digit n for each band 160-6 meters, where n is 1, 2, or 3 for ANT1 only, ANT2 only, both antennae.
•    Alternate set format for all bands: ^AEAn; where n is 1, 2, or 3.
See KXPA100 serial command reference.
Supported by KXPA Utility 1.13.3.4 and later.
01.15 2-19-2014
Reduce dissipation faults in band change
Bug fix: amplifier would not key immediately after tune with high drive power
01.12 2-11-2014
Transmit two RS-232 stop bits, which will work with programs that expect 1, 1.5 or 2 stop bits. Now Ham Radio Deluxe version 6.2 connects through KXPA100.
01.11 2-8-2014
Reduce delay forwarding RS-232 data from PC host to transceiver
01.09 1-28-2014
Reduce minimum power required for full search tune and frequency count
01.07 1-10-2014
Remove input power attenuation and fault checks when PA bypassed
01.06 1-10-2014
Adjust band voltage table based on Yaesu FT-817 measurements
Accept higher input power during ATU tuning
01.05 12-31-2013
Fix a command forwarding problem when commands start with a null character (Pignology's PigKnob)
Adjust band voltage table based on IIC-703 measurements
01.04 12-16-2013
Changes requested by product manager to improve production testing
Use smoothed averages for dissipation and input power fault detection
Do not use attenuator when dissipation threshold reached
01.00 11-18-2013
First production release
看不出啥内容,
但这个21Mhz,21.080-120 频段中,
rtty发射突然中断的问题算是解决了。
kao
用150w的假负载一个一个测试过来
验证测试通过,出厂的校验资料附上
这类bug只要是用户数量足够多,问题
就能得到捂平, 只是时间问题。
还算好 搞定了 否则心里疙瘩的很
只看该作者 44楼 发表于: 2014-05-21
KXPA100+KX3 Power Cal rev A.pdf (11 K) 下载次数:9
6JJI 反正这个串口挺开放的
应该有很多 3rd的软件可做文章
特别是KXPA-ATU,Tune的自动状态能看见,而且可以手动调整的ATU算是第一台吧
(估计8sz眼睛都看红了,他得扔掉内置KX3的ATU)
[ 此帖被BG4DRL在2014-05-21 16:57重新编辑 ]
只看该作者 45楼 发表于: 2014-05-21
回 BG4DRL 的帖子
BG4DRL:[图片]
6JJI 反正这个串口挺开放的
应该有很多 3rd的软件可做文章
....... (2014-05-21 16:52)
早眼红了。。。手动调整的ATU,带手动模式的见过,+C +L,哈哈
离线BG3AUR
只看该作者 46楼 发表于: 2014-07-08
我也买一台。又想跟我一起买的吗?
离线BG2RKH
只看该作者 47楼 发表于: 2014-07-08
回 BG3AUR 的帖子
BG3AUR:我也买一台。又想跟我一起买的吗? (2014-07-08 14:38)
这个从官网直接买。能到国内么?需不需要有啥手续才能买?从官网看到是能直接到国内。
离线BG3AUR
只看该作者 48楼 发表于: 2014-07-08
散件找人背回来,组装。我是这样想。
