  • 16298阅读
  • 77回复
复活的宇航人将在今天中午经过中国大陆! [复制链接]
离线bd4rs
只看该作者 40楼 发表于: 2006-02-07
用什么软件可以收这些信号??????????????????
用录音软件可以收录信号的声音.
用v/u电台设备可以收这些信号.
要更多的了解可以仔细看一下论坛中的相关贴子.
了解跟踪软件可看这个贴
"免费的卫星跟踪程序 orbitron 和 satscape "
http://www.hellocq.net/forum307/showthread.php?t=95687
离线bd4rs
只看该作者 41楼 发表于: 2006-02-07
[quote=柠檬]一个问题:一般的手台有没有机会收到卫星下行的信号?是否必须用锅盖?[/quote]
手台不知道,没试过.但好象这里有贴子谈到过.有些只用可跟踪的yagi和直立都能收到.可能有些卫星的微波段的信号需要锅了.我也在学习中.
离线bd4rs
只看该作者 42楼 发表于: 2006-02-07
虽然气息微弱但7个小时前仍顽强的活着
7个小时前仍有活着的报告,但此后是否还活着?
从报告看,老外也有些不清楚此实验或不知道规矩的.
received by age (dd:hh:mm:ss) signal mission time temperature voltage comments
w7ly 0056:07 -1   0   1 burst of telemetry
i0qm 0043:55 2     145990 khz, weak but ok.
jj0hsc 0056:24 3     male voice 5seconds and 2 seconds
satcan.com 0007:36 2     09:36 edt. rx'd voice but buried under someone on phone and using packet the data burst people are reporting are most likely packet from ham's unaware of project. from ka_ _ _ and w3 _ _ _will process signal up from under the qrm
jh0tog 0011:59 1     very weak sstv signal on ssb 145.990mhz
qs915 0022:51 1     1 light beeping tone this morning
jh2dfj 0059:38     a report of ohbit#44 and #45. 145.99 are reception ng. a voice breaks off with a rash とspin because perhaps a satellite repeats a spin with 437.80.
n2qce 0018:29 0     partial sstv picture
kc7qnl 0020:39 1 2   very heard faint audio and telemetry 145990/437800 over several minutes
xe3iss 0046:41 1     weak carrier
tg9so 0052:21     like doppler of a fm signal copied on ssb
n6spp-sfo 0056:01     pkt/spanish/0945pst 6feb/arrowant to s.e./suit@10deg/437.79fm
wx7p 0056:59 1     heard mans & womans voice + 3 packet bursts on 437.800 orbit 41258
w2rs 0057:31 1     a boy's voice in an unidentified foreign language
kg6pir 0058:31 1     weak signal / data burst
w6zq 0058:34 1     only heard sstv signal
kd7swl 0058:39 1     437.8 got 4 recorded packets of fairly audible quality
n9jim 0058:45     no sig 145.99, copied packet/voice short bursts on 437.800
kg6ifv 0000:22 1     heard both male/female voices and brief packet noise. very weak signal.
kd5vsa 0003:37 1     only 3 short packet bursts on 437.800. 145.99 nothing
jn1gkz 0007:11 2     heard id and part of msg
jf0use 0022:43 2     very weak
n7sep 0040:34 1     weak female voice saying suitsat then male voice unreadable. using arrow hand held ant. on437.800
kf4uar 0042:54 1     heard weak signal from iss repeater downlink, week voices, data
hg9sm 0048:44 2     good signal 145.990 and packet signal stong on 437.800
py4aj 0015:54 1     weak signal... voice present but impossible to understand
kf4imf 0019:19 1     male voice in background
ki4ikw 0020:16 1     very weak, but could hear voice, vx-7 on 145.990 not sure if suitsat
kc5lan 0020:36 1     faint cw signal/no voice or other data/16:05utc
ki4ikw 0022:24 1     very weak, but could hear voice, vx-7 on 145.990 not sure if suitsat
omniverse 00[s:16]22:50 2     hello...hello, anybody out there?...hello-- in male voice, possibly earthbound person instead
离线bd4rs
只看该作者 43楼 发表于: 2006-02-07
这些老外太不守规矩了.DO NOT SEND APRS TO ISS!!!
我代表ba4rs,对suitsat实验表示最大的支持,对以下行为表示强烈的抗议和声援.
packet reports
post a new report utc reported by status remarks
7:56z
feb 7 2006 anonymous active suitsat signal 437.800 iss - x-repeater s3 and packet/aprs. dl8max-5>apc102,aprsat,rs0iss-3,igate,wide3-3: : ,f4cep-3>aprs,ariss: : please send not aprs to iss!!!!!!!!!!!!!!!!!!!!
6:03z
feb 7 2006 anonymous active signal stong on 437.800 (packet/apprs!!!!!) - do not send aprs to iss
16:49z
feb 6 2006 py4mab not active bill talk with a lot stations over south america. orbit 41.259 mauricio beraldo py4mab brazil gg68re
16:14z
feb 6 2006 kb0zuu not active no packet 1014 am cdt
12:39z
feb 6 2006 pd0rkc not active the iss cross-band repeater is on and it listen to suitsat, so probably you can hear a few moments suitsat via the iss - x-repeater with downlink: 437.800. so to all readers: do not send aprs to iss!!! 73's cor pd0rkc info: http://pd0rkc.ontwikkel.nl
离线BD4OS
只看该作者 44楼 发表于: 2006-02-07
在没有明确自己做什么之前请不要轻易按下你的ptt!
离线招租
只看该作者 45楼 发表于: 2006-02-08
如果是仅接收下行信号,一般手台+手台天线还是有机会的.附件是近日我的手机收到iss的信号.
小图 | 大图 图片
  • 哈罗CQ火腿社区 - 卫星和空间通信 - 复活的宇航人将在今天中午经过中国大陆! - 第3页
离线bd4rs
只看该作者 46楼 发表于: 2006-02-08
刚刚与bg6ahp,bd4reb,bd4rkb在1点半多收听suitsat和iss没有收到任何信号,此次时机非常好elv,80多度,几乎就是头顶飞过.
明天还有一次再听.
离线汤圆
只看该作者 47楼 发表于: 2006-02-08
还是太困难收到啊
离线bd4rs
只看该作者 48楼 发表于: 2006-02-08
今早9点40左右又一次过顶,我还是没有收到,bd4rkb收到437.800上下来有个信号,但是什么还不清楚。电池已连续工作了好几天了,可能要耗尽了。
离线BG4AIH
只看该作者 49楼 发表于: 2006-02-08
今天凌晨我也什么都没收到
离线BD7JAC
只看该作者 50楼 发表于: 2006-02-08
我们本地东升炼油厂长期占用145.000-145.995mhz频段作为生产调度,一个车间一个频率,总台随时在任意一个车间频率大功率发射,全部直频通话,我距离20公里左右抄收59+60db,由于该单位经济效益及纳税大户,好像根本不管什么业余不业余频率,所以可能是他们发射也不为奇。
离线weiwei
只看该作者 51楼 发表于: 2006-02-08
早上收听了,于9:46左右,在437.800收到一个微弱的信号,不能确定,因为在我录音的10分钟内,听到这一段好像是某种信号,非常微弱,我将它剪辑了一下,大家听听,大约在4秒钟到8秒钟的这一段时间里。
将附件的后缀txt换成wav就可以了
附件: suitsat.txt (0 K) 下载次数:84
离线BD4OS
只看该作者 52楼 发表于: 2006-02-08
如果你有录音等证据,我会尝试联系当地的无线电管理机构协调解决!
离线bd4rs
只看该作者 53楼 发表于: 2006-02-08
将附件的后缀txt换成wav就可以了
感觉有几个信号高于噪声,但信号太弱无法分辨.
离线weiwei
只看该作者 54楼 发表于: 2006-02-08
是的,当时听的时候感觉特明显,录下来就不那么明显了,要仔细听才能听出来。
离线bd4rs
只看该作者 55楼 发表于: 2006-02-08
Suitsat宇航人仍顽强的活着
1个小时前仍收到来自太空的呼号!
jh0tog 0015:54 3     heard yl voice... rs0rs.... 145.990mhz fm 00:11utc
ve1mr 0028:08 5     best signals yet, several voices and words. 1219 utc heard start of sstv.
kd8ceo 0032:28 1     very weak telemetry burst.
n3nwz 0039:39 1     weak data stream mixed in at the top of noise level
ve7til 0040:02 1     again weak. however, there is a rapid nonlinear change in carrier freq when the signal 'just appears.' noticed this on 3 bursts of signal on this pass. same 20secondish bursts.
这个是不是与bd4rkb的情况有类似?
离线weiwei
只看该作者 56楼 发表于: 2006-02-09
10:07左右刚刚经过我国,又没有收听到的
离线BD3AEK
只看该作者 57楼 发表于: 2006-02-09
这就是中国某些ham的劣根,在全球ham及科学家面前丢尽了脸,强烈谴责!!
使用437.800这个频率的朋友,为了中国的ham的形象,换个频点吧,
不然有关部门进行指正就麻烦了?
呼吁一下吧!
离线BD3AEK
只看该作者 58楼 发表于: 2006-02-10
在13个小时之后,将有一次绝佳听复活的宇航人讲话的机会.
打开你的短波,qq,msn,电话,设置好145.990我们一同来听听,看她都和我们说什么悄悄话.
从南京上空出现是2月6日的02[表情]06(bjt)开始持续5分44秒.
请教一下:我安装的完软件,卫星目录里没有suitsat,
怎样才能添加近来?
多谢!
离线bd4rs
只看该作者 59楼 发表于: 2006-02-10
怎样才能添加近来?
多谢!
主菜单-->设定(alt+f5)-->星历更新窗口-->双击"amateur.txt"就可更新了.然后在"卫星"窗口中选中.
