  • 9097阅读
  • 27回复
FT-80C的改DRIVE旋钮为SSB功率控制(比CRSA会刊上的改法要好,不会损失功率!) [复制链接]
离线bg7iey
只看该作者 20楼 发表于: 2006-06-16
好帖.等我也改一改.
离线BG4IGX
只看该作者 21楼 发表于: 2006-06-18
按照bd5ena的方法已经改了,感觉很方便.
离线intersong
只看该作者 22楼 发表于: 2006-12-02
学习,请问bd5ena给我的机器改过没有啊?
离线zhangyu
只看该作者 23楼 发表于: 2007-09-02
dtgfdgfdgdfg
离线BA1IO
只看该作者 24楼 发表于: 2007-09-03
基本明白了~!钥匙有图片说明就更好了!咔咔!
感谢bd5ena
我内203电容还没焊呢!现在一直用着!没事吧!
离线zly
只看该作者 25楼 发表于: 2007-10-29
bd6ax的做法是剪开d63,互联网上查到的英文资料说剪开d99。
我在下载的电路图上找了半天,只分辨出了d63。
偶然机会找着了一份质量稍好的ft-80c电路图图片,这才发现d99就是d63下边的稳压管。
这样的话,bd6ax的做法和国外ham的做法应是一样的。
=========英文改功率资料============
modifications for the yaesu ft-747
ft-747 power mods
for some time now i have wondering about reducing the power output on my yaesu ft747gx, in the ssb mode.
i have looked at using the external alc to do this, but did not wish to have another lead running out of the back of the radio.
i looked at the schematic of the rig and decided that if i removed the diode d99 from the circuit, i would be able to utilize the drive control on the front panel to reduce power in ssb mode.
after removing the top cover from the radio, i removed the screw holding the crystal filter board in place and removed the board (simply lift squarely), under the board you will see d99 marked on the main board.
i just cut the lead to the diode so as to allow reconnection at any time. after i had done this mod i replaced the crystal filter board (and screw) and tested the rig.
the results were excellent, i have full control of the power from 100w down to less than than 50mw.
i tested the rig on air and worked a station about 2 miles away with 250mw, on the 7 mhz band, below that level i was drown out with qrm.
after looking at the prices of some of the commercial qrp rigs available i feel that the ft747 is a rig looking at, i also intend to use it for driving a transverter.
离线BA5EA
只看该作者 26楼 发表于: 2007-10-29
离线BG3RZA
只看该作者 27楼 发表于: 2009-04-04
按照沈老师的方法改了drive旋钮为ssb功率控制以后发现该旋钮控制功率的线性不好,在不换电位器的前提下有没有什么办法解决一下呢?
