  • 10316阅读
  • 24回复
WEB-SDR 哪位大大把接受天线放网上吧 便于收听学习 [复制链接]
离线VK3ATA
只看该作者 20楼 发表于: 2013-07-14
回 BH1LHS 的帖子
BH1LHS:SDR-IQ 可以吗?是否有教程,我可以试试。 (2013-07-14 20:14)
Running a WebSDR server
Where can I download the server software?
Nowhere. However, I distribute it (without cost) via e-mail to people who are setting up a publicly accessible server (i.e., listed on websdr.org), and who have everything needed to set it up: a soundcard-based SDR, a computer running Linux, and a fast internet uplink. If you have all of these and are seriously interested in setting up a server, email me with some details about your plans and equipment.
Does it make sense that I set up a WebSDR server?
Have a look at the current list of servers on http://websdr.org, and judge whether your server would add something to that, e.g. by being in an unusual location, having a special frequency range or a very good antenna site. Yet another 40 m WebSDR with a dipole in western Europe is probably not useful, but one on Antarctica would be quite nice...
My SDR is an XYZ. Is it supported by the WebSDR server software?
Many amateur SDRs are quadrature mixers which downconvert radio signals to the audio range and feed this to the computer's soundcard. This category includes the well-known Softrock kits, and very many similar schematics and designs on the internet. Also the FunCubeDongle is included. This category of SDRs is supported.
If the SDR has some kind of synthesizer or other configuration settings, the WebSDR software will not take care of this. You'll have to use other software to configure it.
Other SDRs typically use a fast A/D converter and digital hardware to filter part of the spectrum; they are typically connected to the PC via USB or ethernet. Unfortunately, there is no standardization among the interfaces for these SDRs, which makes it hard for me to support them. I'm considering adding a generic interface for them though, but for now they cannot be used.
The (in)famous RTL-SDR dongles (cheap VHF/UHF SDRs) are now supported, but only on VHF/UHF, not with upconverters. Note that these SDRs have a rather small dynamic range, so should only be used in situations where there are no very strong signals.
What Linux distribution should I use for the server?
That does not matter much, as long as it runs on Intel (compatible) processor, either 32 or 64 bits. Many WebSDR servers run on Ubuntu; I myself usually use Debian.
What soundcard should I use for the server?
Start with any that you happen to have and is supported by your Linux distribution. I can't advice you on more advanced sound cards. Don't overlook the motherboard's on-board card: modern motherboards often have surprisingly nice cards, with e.g. 4 channels at 192 kHz samplerate.
How much internet uplink bandwidth does a WebSDR server need?
Obviously, this depends on how many simultaneous users there are. Furthermore, it depends on how many waterfall displays each user has (i.e., how many bands), and the scroll speed of those waterfalls. With a single waterfall at "slow" speed, count on about 100 kbit/s per user.
Can I run the server on the Raspberry Pi or another ARM processor?
Yes, the package now also contains a binary for the RPi. However, the RPi's computational power is limited, so it can't handle more that 96 or perhaps 192 kHz of radio bandwidth.
What is the most recent version of the server software?
The latest distributed version is 10a. If you have an earlier version, and have not been sent the 10a version, then most likely your WebSDR was not running publicly around the time I distributed the 10a version.
Is the hardware being used at the 29 MHz wide WebSDR (running at the University of Twente) available for sale or duplication?
No. This is a rather experimental board; it's not a commercial product, and it is not well enough documented for easy duplication. Also the special WebSDR version running it is not ready for distribution.
只看该作者 21楼 发表于: 2013-07-14
只有mini whip最合适,但中频noise大 要么靠CC1降S0,
其他天线候选是直立GP,不可能拿着StepIRDB做共享。
KW说的线路不是问题,upload有2mbps就足够了。
现状,SDR Radio的console就能实现临时的标注和上传
我的已经upload过一上去就有一大堆欧洲的过来听,
192khz带宽的SDR-IQ完全能对付10几个用户
国内要有地区均等的WEBSDR的话,实在是很实用。
在公司都能听一下互相的QSO,希望能够早入铺开。
很奇怪的是 日本居然一个都没有,他们玩SDR起步很晚
厂家刚刚意识到这点,但不希望用这类SDR,否则他们
的FlagShip高端机卖不掉了。调查发现他们的各大通讯
厂商都有不同的研究报告上传。
离线BA7NQ
只看该作者 22楼 发表于: 2013-07-15
回 BH1LHS 的帖子
BH1LHS:SDR-IQ 可以吗?是否有教程,我可以试试。 (2013-07-14 20:13)
web sdr不支持 sdr-iq,在他的网站上有说明技术条件。
离线BG5EHX
只看该作者 23楼 发表于: 2013-07-15
专线有,天线有,就是没有WEBSDR,那位提供
呼号:BG5EHX
姓名:陈伟军
地址:浙江省海盐县中国银行  314300
QQ:24628787   QQ群号: 26382971
离线BA7NQ
只看该作者 24楼 发表于: 2013-07-15
回 BH1LHS 的帖子
BH1LHS:如何申请WEBSDR? (2013-07-11 23:29)
发邮件给作者 PA3FWM<pa3fwm@websdr.org>联系,说明你的服务器配置、例如专线接入方式,静态IP还是动态IP、上行带宽、说说的计划,如果他觉得合适,会把最新版的的安装程序发给你。
目前,websdr默认支持的环境是linux。
