  • 9610阅读
  • 54回复
讨论:EF340型天线有问题吗?该如何来修整? [复制链接]
离线VK3ATA
只看该作者 20楼 发表于: 2011-12-07
拼了老命调340,最好的结果只有6db fb,如果照他们通常流行的尺寸调,就接近于一个巨型dp,当然比dp还是好,因为8字的腰很细。我觉得还是放弃这个的好。如果舍不得扔,最好改成cl40b的形式,改造方案有,回头有可能在by5cd上试试看。
这也真是辛苦你了,先不要放弃,看看能否简便改造一下结构,从上面照片中看到了ef240的结构是有些小问题,但是,ef340还是缺少很多资料,其中关键的是三根铝振子的总长度是否一样长(不包括折线在内)?不是的话,它们之间各差额多少?
ps:
上图的ef340的引、反振子折线是否反错位了。
离线VK3ATA
只看该作者 21楼 发表于: 2011-12-07
谁想谋杀我啊。我现在终于有人要杀了。太高兴了。
放血后别忘了也给我留一片排骨啊!
离线VK3ATA
只看该作者 22楼 发表于: 2011-12-08
原厂的还有这码事,从KM5VI的陈述中发现
原厂的还有这码事,从km5vi的陈述中发现
this is a 2 element yagi design similar to the ef-240 except for a 24' boom length. the linear loaded elements are approximately 1/3 wavelength. the parasitic element can be configured as a director or reflector by changing the resonance of the loading wires. this is a plus if you like to experiment. mechanically, this antenna is sturdy. the majority of joint connections are riveted. additional boom support is provided by a mast mounted cable. the linear loading wires double as supports for the elements. force 12 supposedly upgraded the boom to mast mounting bracket so be aware if shopping for a used model. mine was acquired used but is equipped with a heavy duty, 2-piece mounting bracket. the only problem encountered mechanically to date has been thread galling between the stainless wire retaining bolts and the aluminum threaded couplers used at the wire coupling points of the elements. anti-seize compound should prevent this problem commonly encountered between dissimilar metals from reoccurring. electrically the antenna performs as advertised. the 2:1 bandwidth is about 250khz. the forward gain is very evident as compared to a dipole at same height – especially for stateside contacts. my vertical will some times offer a slightly better signal from dx stations coming in at low wave angles due to the limitations of my installed height (50ft).
现在有点明白force 12 ef-240x创作意图吧
离线BA5CW
只看该作者 23楼 发表于: 2011-12-08
ps:
上图的ef340的引、反振子折线是否反错位了。 [表情]
说来好笑,这天线调了不是一天两天,而是两次比赛,病急乱投医之时,还真反向各类资料里有印象反射位置不一样的版本,我们还都试过了,而且经过计算,两种版本都能成立,只不过阵子数据有略微变化。三根阵子的折线电流顺序也是走成一致的,阵子长度也是一样的(折线不一样长),现在唯一没有做过的是,用折线一样阵子不一样的长的这种组合。
我本来最后一招就是实测前后比,找到前后比最好的频率位置,然后改变回工作频率,再在工作频率上继续实测,改变振子组合获得最好前后比,但340上下一次可不是小事情,连by5cd御用工人们一听到要动340就头大了,也辛苦bd5chu他们,之前总共上下已经有7,8次天线,实在折腾不起,就放弃了我这种邪恶的想法了。
现在moxon工作得挺好,不过by5cd的天线组合思路是每个波段至少要同时覆盖两个方向,所以有机会还是利用原来的340改造成cl40b,三根阵子做到16m左右长度,加电容帽加感,先按理论计算值调三根不同频率的dp(计算下来三根都和中心频率不一样的),最后组装成八木,加发夹调到最终工作频率。
离线BG5EHX
只看该作者 24楼 发表于: 2011-12-08
.......先按理论计算值调三根不同频率的dp(计算下来三根都和中心频率不一样的),最后组装成八木,加发夹调到最终工作频率。
这个方法我想过好久,第一次玩转软件后就一直这么想,能不能这样去调八木,不过没有试验过,所以希望大佬搞定这个方法后传授一下
离线BA5CW
只看该作者 25楼 发表于: 2011-12-08
这个方法我想过好久,第一次玩转软件后就一直这么想,能不能这样去调八木,不过没有试验过,所以希望大佬搞定这个方法后传授一下 [表情]
调频率只是个说法,我只是借这个方法调长度。
离线BA4XA
只看该作者 26楼 发表于: 2011-12-08
alc啊,你看ef240s的资料就知道了,,
两个天线振子中心都断开,,各自调准频率后中,其中一个振子短接。
离线BA5CW
只看该作者 27楼 发表于: 2011-12-08
那就是我的说法是成立的喽
离线BG5EHX
只看该作者 28楼 发表于: 2011-12-08
那就好了,我的想法也完全成立,我计划的小八木可以再搞下去
离线BA5CW
只看该作者 29楼 发表于: 2011-12-08
为啥340没有这个图,有了就不用瞎调了
离线BA5CW
只看该作者 30楼 发表于: 2011-12-08
那你干脆把大八木也调了吧,调三根阵子对你来讲是小菜一碟。
离线BA4XA
只看该作者 31楼 发表于: 2011-12-08
但你这个说法不知道对不对 :confused: ,,,
俺觉得有源振子(主振子)还是应该在工作频率的中心的。
反射频率低一点 引向频率高一点 这是不用说的
只看该作者 32楼 发表于: 2011-12-08
每个振子都兜来兜来,连什么极化都变了,还谈什么几单元加,反射,引向,相位,间隔什么的?
先要看看单个有源振子激发出电磁波的极化再说。
离线BA4XA
只看该作者 33楼 发表于: 2011-12-08
为啥340没有这个图,有了就不用瞎调了
你可引向按7.130调试试啊
反射 6.930
有源 7.030
引向 7.130
各差0.1
或者反射和有源都不动 只动引向长度,这样肯定会好调多了
离线BG5EHX
只看该作者 34楼 发表于: 2011-12-08
[quote=老干部]每个振子都兜来兜来,连什么极化都变了,还谈什么几单元加,反射,引向,相位,间隔什么的?
先要看看单个有源振子激发出电磁波的极化再说。[/quote]
怕的就是这个事,我原来的小八木计划就是双段的trap上面安装多个十字电容帽,怕的就是电容帽加上去了,振子变短了,但是前后增益都没了,按你的讲法是极化没了,这么理解对不,有一点头大的是,没法测呀
离线BG5EHX
只看该作者 35楼 发表于: 2011-12-08
大家伙一个人干不了,朋友那也没开工 ,现在是五十多公斤的铝管长毛中,还好冬天气要冷,保鲜时间长.
离线bg5chu
只看该作者 36楼 发表于: 2011-12-08
这样一回想,好想d240也有这个了,当时还没意识到,是这么调天线的,这下我们那幅d240,死马当活马医,再去试试了。
离线bg5chu
只看该作者 37楼 发表于: 2011-12-08
这样的话,我也回想起来d240好像也有这么一说的。原来不知道这是什么意思,原来还可以这么调啊。这下我们的d240死马当活马医,试试看哦。
离线BG5EHX
只看该作者 38楼 发表于: 2011-12-08
现在发现又回来软件上来了,可惜我现在通过软件完整走过流程的天线只有正v和gp这二根,别的都没有走过完整过程,以后做的天线看样子还是要想法子走全流程才对头
离线BG2UBO
只看该作者 39楼 发表于: 2011-12-10
ps:
我·的ef240安装一次到位,从装配到上塔就没做过调整,驻波1.1,我的c19xr就有问题了21m驻波调不下来,14m前段时间1.3-1.4,最近满功率发射,突然发现驻波大了,经常在1.5或2以上我今天换了根stl suj-50-5-5扁铜渡银的馈线,驻波还是哪样大,等我把振子取下来看看在回来汇报。
