  • 12278阅读
  • 32回复
ATAS-25 VS Buddipole [复制链接]
离线vr2vgr
只看该作者 20楼 发表于: 2010-02-26
[quote=费力刻丝]哈哈!
my name: felix = 费力刻丝 [/quote]
本星期日28號會再出外測試嗎??有7mhz天線嗎??當日另外有香港ham友追星(ho68),另已架設hf天線,有興趣下午2:00測試一下..
离线费力刻丝
只看该作者 21楼 发表于: 2010-02-27
本星期日28號會再出外測試嗎??有7mhz天線嗎??當日另外有香港ham友追星(ho68),另已架設hf天線,有興趣下午2:00測試一下.. [表情]
卡片收到了
有时间一定再试试
离线费力刻丝
只看该作者 22楼 发表于: 2010-03-29
再次顶起!
离线BG8SPW
只看该作者 23楼 发表于: 2010-10-03
楼主真是米人呢!不过还是谢谢你的测试报告,参考价值很大.
离线BA2Bi
只看该作者 24楼 发表于: 2010-10-03
http://hfpack.com/antennas/shootouthorizontal2002.html
buddipole (short) 增益-1.04
pac-12c 增益 -0.83
hfpack 测试的比较全面 朋友们可以参考
离线wd3010
只看该作者 25楼 发表于: 2010-10-03
看来天线还是一寸长一寸强啊
离线郭靖
只看该作者 26楼 发表于: 2010-10-04
bi7ilz 你好
請問atas-25在哪里有得買到?
离线xzxdf
只看该作者 27楼 发表于: 2010-10-04
[quote=郭靖]bi7ilz 你好
請問atas-25在哪里有得買到?[/quote]
同问,5个字
离线BG2URR
只看该作者 28楼 发表于: 2010-12-17
离线bg3qjf
只看该作者 29楼 发表于: 2010-12-17
一寸长一寸强 一寸短一寸险
离线BA1IO
只看该作者 30楼 发表于: 2010-12-21
有又有点内什么!
用不用出pac换这个?
离线BA1IO
只看该作者 31楼 发表于: 2010-12-21
i just purchased this atas-25 used, but in practically unused condition. i thought the first thing i should do is to test it under the actual working conditions i plan to use it in. and yes, i realize it's designed for outdoor use, but i needed an indoor antenna, so please keep that in mind when reading this review.
first off, the vertical part of the antenna is made from gun cleaning rods. if it ever breaks, i anticipate being able to ride over to wal-mart and visiting the sporting goods department for replacement whip pieces. the one included appears to be aluminum. you can buy replacements (from your local gun shop) made of brass or stainless steel if you don't like aluminum.
i found it would not tune on 40m. hold on- let me explain. the ceiling in my home is standard 7 feet 8 inches. using the tripod i had and three whips, i could not extend the coil fully. i suspect i probably could have reached 40m if i could have extended it some more. if you plan on using this antenna indoors, you may have the same problem.
a chart follows that tells what swr i was able to get when tuning the unit using an mfj swr analyzer to check it.
absolute lowest frequency with three whips: 9.275mhz 1.5:1
absolute lowest frequency with two whips (fully extended): 7.685mhz 1.7:1
3 whip sections all the way retracted no match anywhere.
2 whip sections all the way retracted no match anywhere
1 whip section all the way retracted 1.2:1 at 65.000
could not extend fully with three whips because of hitting my ceiling.
2 whip sections fully extended 1.7:1 at 7.685
2 whips no good match on 20m. 2:1 at 14.350mhz
18.150 2 whips 1.3:1
21.400 2 whips 1.2:1
10.125 1 whip 1.2:1
18.140 1 whip 1.2:1
21.350 1 whip 1.2:1
24.900 1 whip 2:1
27.185 (cb) 1 whip 1.2:1
28.400 1 whip 1.3:1
50.125 1 whip no match
50.125 no whip, no radials 1.6:1
146.520 no whip with radials 2.3:1
146.520 no whip no radials 1.1:1
could not test 440, my meter doesn't go there.
i have not had an opportunity to try this antenna outdoors in the wide open spaces. i'm certain the wiring in my home, the metal ductwork, my refrigerator, and other metallic objects cause difficulties in obtaining good matches. the length of the whip on 10m causes me concern that there is not enough radiating surface to make good contacts. the efficiency has to be somewhere along the lines of a radio shack gutter mount cb whip. i'd be suprised if i were able to make any contacts on 10m. in fact, on any band below 10m where only one whip was used for a decent match, i suspect the efficiency is so low as to be a total waste of time trying to make contacts. you could probably do as well on a wet noodle. i think a telescopic whip would have been a better choice, because having to work within the constraints of fixed-length whips (one whip, two whips, or all three, with no other alternatives) seems to limit the flexibility of the unit. i will probably manufacture my own adapter to allow the top of the antenna to accept a standard 3/8-24 thread telescopic 9 foot whip from mfj. this will allow the least amount of loading coil to be used for maximum efficiency. as far as removing all the whips and radials and using only the loading coil as a radiator for 6m, 2m, and 440, the efficiency probably only marginally better than a rubber duck.
one variable aspect of this antenna is the tripod. the one i have is metal throughout, so the tripod legs become part of the ground system of the antenna. some tripods have plastic mounts, and this would insulate the antenna from the tripod legs. there is nothing in yaesu's instruction sheet to indicate which type of tripod is preferred for proper tuning of the antenna.
there is some ambiguous language in the tuning chart. what is the difference between "no connection", "do not connect", and "not used"? in english these all mean basically the same thing! are they referring to the tuning rods or the radial wires? the rest of the instructions are well written.
as far as the overall design, simplicity of operation, durability, and aesthetics aspects, i think yaesu has a winner! personally i would have preferred that they package two of these units together and included 9 foot telescoping whips and some type of center insulator to allow you to make a rotatable dipole of sorts, and priced the set around $250.00. but if you do that, the adjustable coil would have to go somewhere else besides the center, and weight and angle-of-moment with resultant force against the center insulator would become an issue.
hopefully i'll get to try this antenna out in an outdoor environment real soon, and i fully expect it to tune better under those conditions. since my primary purpose is to use it as an indoor travel antenna, that was the condition i tested it under.
73, -kr4wm
离线费力刻丝
只看该作者 32楼 发表于: 2010-12-22
有又有点内什么!
用不用出pac换这个? [表情]
110大大又折腾这个?^_^
