  • 8860阅读
  • 22回复
事实证明,泉盛的400M全段机是可以扩频的,(更新了) [复制链接]
离线rovae
只看该作者 20楼 发表于: 2008-10-21
How to use lace wigs
how to use lace wigs
this leaflet is designed to help you put on your full lace wig securely and
help you take it off with out damaging the wig or your face!
preparing the lace human hair wigs the underneath the wig (if there is any!) is like building foundations for a house because it will give you a solid base to pin the wigs on to. this can be done by wrapping long hair and using pin curls, crossed grips, clips or even a bandage. covering this with a stocking top, which is also pinned on, will give you extra security.
put the wig on with help by getting the wearer to place their fingers on top of the lace whilst the assistant pulls the fashion wigs down at the back. (placing your fingers under the lace and pulling forward may cause the lace to tear). if on your own bend forward and pull the
wig on like a hat. when adjusting it, please do not use the lace front wigs to pull the wig around as it may stretch or tear. use the thick seam near the ear.
离线BH4RDB
只看该作者 21楼 发表于: 2008-10-22
本身就是400m全段收发,再扩天线也不行了。
顶楼主的discovery精神!
只看该作者 22楼 发表于: 2008-10-23
顶楼主的discovery精神!
diy是永无止境的,就像电脑超频,cpu主频已经很高了,骨灰级玩家要玩到cpu报销才罢手!
