因为ic-7000待机时机身温度太高!要动一个100 ohm的电阻才能解决问题......
1.tuner lead #3 is +12v dc, tap into tuner lead #3 with a wire ( theres enough room to simply slip a solid copper wire into the crimp for lead #3 )
2.add a 100ohm resistor at the other end of the solid copper wire ( a 100ohm pot will work if you wish to be able to vary the speed of the fan )
3.strip the insulation of the red wire to the fan back just enough to make a solder connection to the 100ohm resistor / 100ohm pot. we used a lighter to burn away a bit of the insulation in the middle of the wire b/t where it connects to the board and where it connects to the fan itself.
