  • 33047阅读
  • 159回复
TK-630H能不能到29.6MHz [复制链接]
离线BG7YDO
只看该作者 20楼 发表于: 2005-12-01
离线BG1HL
只看该作者 21楼 发表于: 2005-12-01
网上查来的:
i was wondering if any one could give me any info on how to tune a kenwood tk-630?also if a tk-630 in the 29-37 range is tuned will it do any freq form 29-50 mhz? thanks for any info.
see this thread for details:
http://radio.the161.net/viewtopic.php?t=418&highlight=tk630
the low split unit should go down to 29 mhz. if you use the "sp tune" mode in the software it will accept frequencies from 29-54 but a low split unit will not tune more the 1 mhz or so above 37.
a low split can probably be made to work on 10 m and a high split to work on 6m with vco and rx front end retuning if you have the equipment and experience to do it. converting a low split to cover 40-50 really is not possible unless you want to rebuild the rf circuits.
离线蓝梦祥
只看该作者 22楼 发表于: 2005-12-01
看不懂呀。。。。。。。。。。。。。。。
离线BG1HL
只看该作者 23楼 发表于: 2005-12-01
i've modified about a dozen of the tk-630-3 to
6 meter operation. no componet changes are required,
but careful realignment of the vco and front end are
needed. the unit in my mobile is running 140 watts
output and .3uv receive sensitivity. these are excellent radios. n3yex
离线BG1HL
只看该作者 24楼 发表于: 2005-12-01
tk630的高段机就是tk630h,频率范围41.0mhz-49.98mhz,kenwood tk-630m中段机(35.0mhz-42.98mhz) ,tk630低段机29-37mhz。最多可以160信道,通常32信道。第一中频10.7m,第二中频455k。
tk630h如果使用慢速调谐(sp tune),可以调到6m业余段,但是超过52m时vco会失锁,需要调节vco的电容,使其在你想要工作的最高频率上能够正常锁定,其他部分都不用动。
如果想调低到29.6或更低的10m业余段,主要工作是把收发的vco频率降低,不过对于tk630的高段机即tk630h,恐怕跨度大了些,只有线圈加磁芯辅助并联电容了。而且输出低通的线圈也要适当增加一些圈数。
由于没有前面板,目前没法控制,若自己重新用单片机编程控制mb1504,不是不可以,只是太麻烦了。外接dds,接收可以,发射调制如何进行?
通道的调谐电压到好解决,lm317三端稳压手动调谐吧,在频带不宽的情况下也可以用的。
离线BG7YDO
只看该作者 25楼 发表于: 2005-12-02
i am having a problem "reading the radio" on the kenwood tk-630h. i am using the kpg-4 cable and kpg-7d software program. i do not have the manual. i have tried two different tk-630h radios, same problem. i have switched comm ports, same problem. my question is: does the tk-630 have to be put into the programming mode via some method other than via the software program, or should it respond directly from the computer keyboard. if it should respond directly from the computer keyboard command, "read radio", then i assume i have either a defective cable or software. good thought, but had no luck trying that either. i also tried some other combinations with no luck.
bob, i have that information, but it is on another computer that is down right now. i'll try to get it back on line tomorrow night, too late tonight, and i'll maybe send you the information then if someone else hasn't already done so. off the top of my head, i do remember that it is two trimmer caps in a square metal can in the center of the rf board, toward the front of the radio. on trimmer is for the rx vco, the other is for the tx vco. don't remember which is which right now, but it ain't hard to figure out. don't remember where the test point to measure is, either, but you basiclly tune for max voltage all the way across the band. then, tune the pre-selector (four small metal cans, right rear of the rf board, don't remember the numbers, of course!) for maximum signal passage across the band. as i said, i'll try to fill in the blanks tomorrow night if someone else hasn't already done so.
okay, i'm another newbie to this site and have the same question on the tk630 lowband 40-50 mhz going down into the 29.00 mhz range. i currently have it programmed and it will only transmit down to 33:60 mhz before the display starts to flash. i would like to know how to retune my radio to also go through the full spectrum of frequencies.
any help would be appreciated,
thank you all,
ok, bob, here goes. lay the radio on your work surface with the heatsink facing away from you and the model/serial number label to your left. remove the cover that is currently facing up, should run pretty much the whole length of the radio. to the rear is a large, square shield. this houses the pa, which you don't need to change. everything you need to adjust is in the smaller section towards the front of the radio. first, locate z302, which is a metal box in app. the center of this section. it should have two holes in the top of it. the hole to the right is to adjust the rx vco, and the hole to the left is to adjust the tx vco. just to the right of z302, you should see two capacitors together, a gap, and a third capacitor. in this gap, you will find tp302, where the vco voltage is measured. now, with a volt meter connected to tp302, set the radio to the highest frequency you plan to use. if nessasary, tune the rx vco adjustment untill you see between 2 and 6 volts dc, or untill it locks (display stops flashing, radio stops beeping), whichever comes first! then key the radio, into a dummy load, of course, and repeat the same procedure for the tx adjustment. finally, go to the lowest planned operating frequency and make sure it still works correctly. if not, go back and forth untill you get a happy medium.
to realign the rx preselector, locate l301, l302, l304, and l305. these are located in a row, right to left, in the upper right hand corner of the same section as the vco. i'm going to assume you know how to align a preselector. you should now be in business! let me know if you have any problems, and i'll see if i can help you further. i have already retuned two of these units as described, and they both work great!
tip: as you should already know, don't use a conductive (metallic) tool for any of this, esspecially the vco adjustment.
kenwoodman, i would be really surprised if you got that split radio to go that low. you need to find the version with the lower split to do what you want to do.
离线BG7YDO
只看该作者 26楼 发表于: 2005-12-02
谢谢指点,630要改的地方不多,控制板是独立的,需要松树的地方不多:bu4094及mb1504两个器件都是串行送数,89c205x应该可以轻松应付,本来就是爱好,做一种尝试,也不失为一种乐趣,只要大家肯帮忙,愿意指点,还是可以的
离线BG4JDU
只看该作者 27楼 发表于: 2005-12-02
都是e文高手。。
离线BG1HL
只看该作者 28楼 发表于: 2005-12-02
那么最有难度的工作就是开发单片机控制bu4094及mb1504,产生pll信号,另外产生通道调谐电压了。我不懂单片机,插不上嘴了,只能衷心祝愿大家成功!
离线BG4JDU
只看该作者 29楼 发表于: 2005-12-02
还是先把电路原理图测绘出来,在弄明白各电路原理及它们之间的控制与联系后,才能进行改制
离线BG7YDO
只看该作者 30楼 发表于: 2005-12-03
接口功能定义基本已经测出,整理后再贴上。下图是中方和解调部分电路
离线bd8ai
只看该作者 31楼 发表于: 2005-12-03
双手和双脚支持楼主!!!!!
离线yujing
只看该作者 32楼 发表于: 2005-12-03
这里有mb1504的资料:
离线bg7nf
只看该作者 33楼 发表于: 2005-12-03
帮不上什么忙,发两张内部图.期待手动控制面板早日面世
离线BG7YDO
只看该作者 34楼 发表于: 2005-12-04
收发板的接口cn302,可以参考一下
离线BG7YDO
只看该作者 35楼 发表于: 2005-12-04
电源和音频功放单元的接口cn501
离线bg2tr
只看该作者 36楼 发表于: 2005-12-04
这个是24c04里的数据,000c0后面的应该是频道频率
离线BG7YDO
只看该作者 37楼 发表于: 2005-12-04
:020000040000fa
:20000000fcffffffffffffffffffffffffffffffffffffffff03f1fdffffffffffff0055b8
:20002000280bff0a5c0800ffff0000000084ae1502fc00ff288080ffffffffffffffffffbf
:200040004b564520524547554c41522050524f4752414d2000000000000000000000000030
:200060000000000000000000ffffffffffffffffffffffffffffffffffffffffffffffff98
:20008000ffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffffff80
:2000a000ffffffffffffffffffffffffffffffff302002303033364dfffffffffffffffff0
:2000c000382bdc22ffffffff0100382bfc22ffffffff0100ffffffffffffffff0000ffff4e
:2000e000ffffffffffff0000ffffffffffffffff0000ffffffffffffffff0000ffffffff1a
:20010000ffffffff0000ffffffffffffffff0000ffffffffffffffff0000fffffffffffff9
:20012000ffff0000ffffffffffffffff0000ffffffffffffffff0000ffffffffffffffffd9
:200140000000ffffffffffffffff0000ffffffffffffffff0000ffffffffffffffff0000b7
:20016000ffffffffffffffff0000ffffffffffffffff0000ffffffffffffffff0000ffff99
:20018000ffffffffffff0000ffffffffffffffff0000ffffffffffffffff0000ffffffff79
:2001a000ffffffff0000ffffffffffffffff0000ffffffffffffffff0000ffffffffffff59
:2001c000ffff0000ffffffffffffffff0000ffffffffffffffff0000ffffffffffffffff39
:2001e0000000ffffffffffffffff0000ffffffffffffffff0000ffffffffffffffff000017
:00000001ff
离线BG7YDO
只看该作者 38楼 发表于: 2005-12-04
tx: 382b: 2b38h*5k-10700=11064*5k-10700=55320-10700=44.620mhz
rx: dc22:22dch*5k=44.620mhz
收发数据,前两天就知道了,我还是没办法让他工作d78312 nec的东东我无从下手,另外前面的面板怎样的也不知道,无奈人笨呀
离线wangjia1975
只看该作者 39楼 发表于: 2005-12-04
呵呵,ydo都在等你大作哦!
