  • 29696阅读
  • 340回复
即将推出300S套件 [复制链接]
离线BG4EBC
只看该作者 180楼 发表于: 2008-10-14
当地买不到输入电容较小的irf510,只能买到输入电容为400p的irf820,这样在40米没有什么问题,但到了20米损耗很大。因为300s是便携型,使用12-13.8v,采用24v很不方便,现在300s的pa改用2只2078,又要延期1周。
pa板子废了?
离线ahhui
只看该作者 181楼 发表于: 2008-10-14
这几天一直在和iw3fzq通email,他偶然发现了我放在youtube上的th-300 pro的视频,就来信询问是什么qrp设备?我给他详细介绍了一下并发了几张照片过去,他非常赞赏th-300 pro。enrico本身也是个qrp兼diy的高手,他自己diy了很多微波的transverter,前置放大器和滤波器。他对th-300的看法如下:
hi zhang,
i seen the photos you have sent. the th-300 seems very well done. i like the 6 crystals i.f. filter. usually, all qrp rigs use 4 crystals instead of 6 in the i.f. chain!
one particular, the low number of semiconductors (transistor/fet, i.c., etcetera). i seen it works on ssb too. very good job! which is your opinion about bd6ra's rig?
bc overload on 40 mtrs? filter selectvity on cw and ssb mode?
if you look my youtube's pages, you can find my videos with many qrp transceivers....
if you have time, it is a good idea make new videos with th-300 !!
zhang,
now i seen well the pcb, lots of semiconductors are located in the back of pcb!
awesome, smd transistors for qrp homemade rig.
i used lot of smd transistors during my microvawe transverter assembly.
about the i.f. cw filter, i believe 600-800 hz are sufficient for usual cw qsos.
during the primary contest, also using a commercial rig there will problem...
i think it is a good way for a single conversion qrp kit, no more.
i wait you finished your work about th-300 and successively to look your new videos!
congratulations again....
73 de enrico, iw3fzq
离线aqqw
只看该作者 182楼 发表于: 2008-10-14
楼上不厚道,欺负俺e文不懂!
离线ahhui
只看该作者 183楼 发表于: 2008-10-14
楼上不厚道,欺负俺e文不懂! [表情]
不好意思,大致翻译一下吧。
hi zhang,
我看到你发给我的照片了,th-300看起来非常不错。我喜欢这种6个晶体的中频滤波器,不象通常的qrp设备只用4个。
有一点疑问——半导体(晶体管,ic)的数目有些少,我看它也可以工作在ssb模式,做的非常好。你怎么评价bd6ra这个小设备?有无广播干扰(被广播信号过载),cw模式下和ssb模式下滤波器的选择性如何?
现在pcb看的很清楚,很多半导体零件在pcb背面。
非常壮观!自制的qrp设备用了smd的三极管。我自己做的微波transverter(双向变换器)也用了很多smd的三极管。
关于中频cw滤波器,我确信600-800 hz的带宽足够日常的cw qso。对于主要的比赛,最好还是使用成品设备......
我跟他说th-300对广播干扰的抑制很好,但美中不足的是为了照顾ssb而共用了一个中频滤波器,这样的话平时使用应该没有问题,但如果用于比赛会有所不便。
离线BD6RA
只看该作者 184楼 发表于: 2008-10-14
不好意思,大致翻译一下吧。 [表情]
hi zhang,
我跟他说th-300对广播干扰的抑制很好,但美中不足的是为了照顾ssb而共用了一个中频滤波器,这样的话平时使用应该没有问题,但如果用于比赛会有所不便。 [表情]
'译的好! 同时感谢你对300pro的介绍 。但还是要提出2处不同见解。
iw3fzq可能不是讲英语国家的,所以有个别文法错误,较难理解。
1、one particular, the low number of semiconductors (transistor/fet, i.c., etcetera). -- 尤其是,半导体器件使用的少。
2、during the primary contest, also using a commercial rig there will problem...
--大意是:初级比赛也使用了成品机,但也会有问题。
离线BD6RA
只看该作者 185楼 发表于: 2008-10-14
pa板子废了?
先费了再说,等以后有好场管。或者按6元一片(送1只irf820),随套件给大家。高频的场管目前太贵,40元/只,难推广。irf系列40米尚可,但超过10mhz需要较大驱动,适合做300s的接力功放。
离线ahhui
只看该作者 186楼 发表于: 2008-10-14
译的好! 同时感谢你对300pro的介绍[表情] 。但还是要提出2处不同见解。
6ra老大英语很好啊! 我的英语不怎么样,但来而不往非礼也,只好硬着头皮上了。另外iw3fzq是意大利人。
离线BD6RA
只看该作者 187楼 发表于: 2008-10-15
6ra老大英语很好啊! [表情] 我的英语不怎么样,但来而不往非礼也,只好硬着头皮上了。另外iw3fzq是意大利人。
'翻译的很好,最起码98分 。意大利人的英语肯定有些差异。
离线BG2TUH
只看该作者 188楼 发表于: 2008-10-15
支持!价格不错!
ps:好像9851还不能申请,哪有便宜点的?
离线BD6RA
只看该作者 189楼 发表于: 2008-10-15
[quote=bg2-3-51837]支持!价格不错!
ps:好像9851还不能申请,哪有便宜点的?[/quote]但论坛里应该有很多9851存货。
离线BD6RA
只看该作者 190楼 发表于: 2008-10-17
dds的键盘pcb做好了。与lcd一样宽,可与lcd一起固定到面板上,也可选择其他安装方法。当地只有红色按钮,最好灰色的。大家自己解决吧。
dds套件165元,包含快递费用。
dds分两个界面:
1、业余
波段1:3.5-4.1
波段2:7.0-7.5
波段3:14.0-14.5
波段4:21.0-21.5
波段5:28.0-30.0
波段6:50.0-54.0
2、普通
分6段,覆盖2.5-54.0
可存储16个信道
步进共5个:10hz、100hz、1khz、10khz、100khz
模式共4个lsb、usb、cw、am,控制电压5v,不小于50ma
波段控制控制电压5v,不小于50ma
dds采用9851,输出幅度为1v rms
可用于300pro,也可用于其他设备。
300的用户如果觉得波段太多,可以只选择2个波段。
300s的用户可以同300s一同购买,省去邮资等费用。
离线jasonp
只看该作者 191楼 发表于: 2008-10-17
pa板什么时候供货.pa,dds我都要.
离线weed
只看该作者 192楼 发表于: 2008-10-17
dds套件165元,包含快递费用。
dds分两个界面:
1、业余
波段1:3.5-4.1
波段2:7.0-7.5
波段3:14.0-14.5
波段4:21.0-21.5
波段5:28.0-30.0
波段6:50.0-54.0
2、普通
分6段,覆盖2.5-54.0
可存储16个信道
波段控制控制电压5v,不小于50ma
可用于300pro,也可用于其他设备。
配上9851多少米一套?
离线BD6RA
只看该作者 193楼 发表于: 2008-10-17
'你要哪种pa板?场效应管的还是2078的?场效应的,现在就可以,6元1片。2078的要等,正在做。
离线bd4ahs
只看该作者 194楼 发表于: 2008-10-17
300s整套什么时候出啊?
离线BA5AC
只看该作者 195楼 发表于: 2008-10-18
40块一只的是啥场效应管子啊?能指点下吗?
离线bg4fef
只看该作者 196楼 发表于: 2008-10-18
又有好东西了
离线ahhui
只看该作者 197楼 发表于: 2008-10-18
我要一块dds板子,下周办款。
如何和300-pro连接?那些波段开关什么的需要改动吧?
离线jasonp
只看该作者 198楼 发表于: 2008-10-18
请问2078的pa板的功率多少?
离线BD6RA
只看该作者 199楼 发表于: 2008-10-18
dds组件组合还是比较简单,但也可以分开安装,用排线连接。
