  • 5825阅读
  • 22回复
收到来自RDRClub(俄罗斯数字无线电俱乐部)的比赛邀请信 [复制链接]
离线bg7qa
只看楼主 正序阅读 0楼 发表于: 2014-11-07
昨晚查阅信箱看到,The Russian Digital Radio Club(俄罗斯数字无线电俱乐部)通过电子邮件发来的the 1st Russian WW MultiMode Contest 2014邀请信。RDRClub(俄罗斯数字无线电俱乐部)邀请世界各地的业余无线电爱好者参加的第一个俄罗斯WW多模大赛2014年大赛。
信件原文:
Dear Fellow Radio Amateurs,
The Russian Digital Radio Club has the honour to invite
the radio amateurs all over the world to participate in the 1st Russian WW
MultiMode Contest 2014. The objective of the contest is to establish as many
contacts as possible between radio amateurs around the world and radio amateurs
in <st1:country-region w:st="on">Russia.
We invite all fans of all modes to take part in contest
from 12.00 UTC on Saturday 15th November till 11:59 UTC on Sunday 16th
November, 2014. Types of modulation: BPSK63, CW, RTTY, SSB. The repeated
contacts are permitted on different bands and different modes providing that a
contact will be made not earlier than in 3 minutes. The output power should not
exceed 10 watts on 160 meters and 100 watts on other bands. The operator may
change the bands no more than 10 times within calendar hour (with zero on 59-th
minute of each hour). Only one transmitted signal is permitted at any time.
Bands: 160 m, 80 m, 40 m, 20 m,
15 m, 10 m.
Prizes and certificates in all categories:
SOAB - BPSK63-CW-RTTY-SSB
SOAB - BPSK63-CW-SSB
SOAB - BPSK63-RTTY-SSB
SOAB - CW-RTTY-SSB
SOAB - BPSK63-CW
SOAB - BPSK63-RTTY
SOAB - BPSK63-SSB
SOAB - BPSK63-SSB
SOAB - RTTY-SSB
SOAB - CW-RTTY
SOAB - CW-SSB
<st1:country-region w:st="on">MOAB - BPSK63-CW-RTTY-SSB
For more info please visit Russian WW MultiMode Contest
2014 Rules:
http://www.rdrclub.ru/russian-ww-multimode-contest/159-rus-ww-multimode-contest
You should send your log upload via the Web interface http://ua9qcq.com/en/submit_log.php?lang=en
All logs must be sent no later than 14 days after the
contest (23:59 UTC on 30th November 2014).
73! de Russian Digital Radio Club
通过网络翻译得到的中文信息:
尊敬的各位业余无线电,
    俄罗斯数字无线电俱乐部荣幸地邀请世界各地的业余无线电爱好者参加的第一个俄罗斯WW多模大赛2014年大赛的目的是建立世界无线电爱好者各地尽可能多的接触尽可能业余无线电爱好者之间在俄罗斯。
    我们邀请所有的模式所有的球迷从12.00 UTC参加的比赛上周六1115日,直到1159UTC周日1116日,2014年的调制类型:BPSK63CWRTTYSSB。反复接触,允许在不同的频段和不同的模式提供了一个接触会取得不超过3分钟前。输出功率不应超过10瓦特上160米,百瓦特于其他频段。操作者可以改变带日历小时内不超过10倍(与零上的每个小时的591分钟)。只有一个发射的信号被允许在任何时间。乐队:16080男,45女,19男,15米,10μm以下。
奖金和证书在所有类别:
SOAB - BPSK63-CW
RTTY
SOAB - CW
RTTY-SSB
SOAB - BPSK63-CW
SOAB - BPSK63
RTTY
SOAB - BPSK63-SSB
SOAB - BPSK63-SSB
SOAB - RTTY-SSB
SOAB - CW
RTTY
SOAB - CW-SSB
    欲了解更多信息,请访问俄罗斯WW多模大赛2014年规则:http://www.rdrclub.ru/russian-ww-multimode-contest/159-rus-ww-multimode-contest
    你应该通过Web界面http://ua9qcq.com/en/submit_log.php?lang=en发送您的日志上传
    所有的日志必须在比赛(2359UTC20141130日)后不迟于14天内寄出。
       73
                德俄数字无线电俱乐部
[ 此帖被bg7qa在2014-11-11 09:59重新编辑 ]
BG7QA  广西、河池
键盘手谈汇(KHC)  QQ群:293739567
离线BG3ATI
只看该作者 22楼 发表于: 2014-11-17
夜里下班 1点到2点在40米搞了一会 困了就睡觉了 白天没弄。
呼号:BG3ATI  37917
姓名;张明
地址:天津市武清区平安里9号2门102室
邮遍:301700
QQ 546381014  13821796828
我喜欢电子制作 爱玩电脑  乐器  唱歌
希望能够结交更多的朋友.
离线我是伍亿
只看该作者 21楼 发表于: 2014-11-17
回 BH4TXN 的帖子
BH4TXN:时间关系,只玩了最后8小时,打了下酱油,信号确实不咋地,10只有中午传播稍微好一点,基本都集中在15米,第一届比赛,人气明显不足。
[图片] (2014-11-17 10:24)
我更加惨
SSB模式几乎没几个俄罗斯友台参加比赛
N1MM上面的spot也几乎没有
倒是和俄罗斯电台DX做了好几个
这个周末传播也的确比较差 哈尔滨是只有周日下午一点半到三点半的十五米和10米是稍微能用的
哈尔滨体育学院
BG2CTX QSL卡管理人:BH2RO  来卡不回
离线bg9xe
只看该作者 20楼 发表于: 2014-11-17
没时间搞,只能看看了,传播很烂
只看该作者 19楼 发表于: 2014-11-17
离线我是伍亿
只看该作者 18楼 发表于: 2014-11-16
回 我是伍亿 的帖子
我是伍亿:晚上传播不行
我晚上六点钟开始监听频率 然后用N1MM刷SPOT
N1MM上面的SPOT我一个都没法听
八点半就收工了
....... (2014-11-15 23:43)
没搞头啊
今天是九月份以来传播最差的一个周末了。。。。。
欧美俄老外都没法听见
倒是在14275和JH4CBM高见先生聊天聊了半小时
哈尔滨体育学院
离线我是伍亿
只看该作者 17楼 发表于: 2014-11-15
回 bg3ssa 的帖子
bg3ssa:听不到动静。 (2014-11-15 21:42)
晚上传播不行
N1MM上面的SPOT我一个都没法听
八点半就收工了
准备明天早上八点钟搞到晚上八点
看看有没有搞头
哈尔滨体育学院
离线bg3ssa
只看该作者 16楼 发表于: 2014-11-15
听不到动静。
设备:IC7410,FT897D,PAC-12,K-730
QQ:  10376684
邮箱:jiaojiangyu@126.com
离线bg3ssa
只看该作者 15楼 发表于: 2014-11-14
规则没有弄清楚。
QQ:  10376684
离线BG3ATI
只看该作者 14楼 发表于: 2014-11-14
可以打一下酱油
呼号:BG3ATI  37917
姓名;张明
邮遍:301700
我喜欢电子制作 爱玩电脑  乐器  唱歌
希望能够结交更多的朋友.
离线bg3ssa
只看该作者 13楼 发表于: 2014-11-14
有打算参加的朋友没有?
QQ:  10376684
离线我是伍亿
只看该作者 12楼 发表于: 2014-11-13
楼上各位前辈准备参加么?
哈尔滨体育学院
离线bg6riz
只看该作者 11楼 发表于: 2014-11-12
没有PSK31。。。。
离线我是伍亿
只看该作者 10楼 发表于: 2014-11-12
原来SOAB就是single op all band的意思。。。。。。。
[ 此帖被我是伍亿在2014-11-12 16:55重新编辑 ]
哈尔滨体育学院
离线bg4hyk
只看该作者 9楼 发表于: 2014-11-12
每人都有吧,我也收到的
欢迎加入 快乐无线电GLHAM 224850911QQ群
离线BG3ATI
只看该作者 8楼 发表于: 2014-11-12
我也收到了。
呼号:BG3ATI  37917
姓名;张明
邮遍:301700
我喜欢电子制作 爱玩电脑  乐器  唱歌
希望能够结交更多的朋友.
离线bg7qa
只看该作者 7楼 发表于: 2014-11-11
回 BH4TXN 的帖子
BH4TXN:这跟上次的RTTY一样,也是第一届,不知道老毛子在 搞什么名堂,是不是也跟邪会分家了~ (2014-11-07 16:15)
呵呵,是这么回事。扩大影响力?
BG7QA  广西、河池
离线bg7qa
只看该作者 6楼 发表于: 2014-11-11
回 BG6IMK0378 的帖子
BG6IMK0378:这个比赛邀请信我也收到了。 (2014-11-07 15:58)
呵呵,看了邮件标题,是发给个人的。
BG7QA  广西、河池
只看该作者 5楼 发表于: 2014-11-07
离线BG6IMK0378
只看该作者 4楼 发表于: 2014-11-07
这个比赛邀请信我也收到了。
呼号: BG6IMK
电话: 0371--25950204
邮编: 475000
设备: FT--897D
天线: 6米铝合金天线塔,C3s三波段八木天线
高度: 架设在6层楼顶
