  • 3425阅读
  • 6回复
NND.没脸见人了,WPX扣了那么多。不应该啊不应该 [复制链接]
在线BD7IS
只看楼主 倒序阅读 0楼 发表于: 2011-02-01
没有好好检查的结果。
************************** summary ***************************
  332 claimed qso before checking (does not include duplicates)
  313 final   qso after checking reductions
  492 claimed qso points
  432 final   qso points
  157 claimed mults
  144 final   mults
  77244 claimed score
  62208 final   score
-19.5% score reduction
    2 (0.6%) duplicates (without penalty)
    11 (3.3%) calls copied incorrectly
    6 (1.8%) exchanges copied incorrectly
    2 (0.6%) not in log
    2 (0.6%) calls unique to this log only (not removed)
********************** results by band ***********************
在线BD7IS
只看该作者 1楼 发表于: 2011-02-01
claimed     10m   332   492   0
  final     10m   313   432   0
  claimed     all   332   492   157 score   77244
  final     all   313   432   144 score   62208
************************* not in log *************************
28505 ph 2010-03-27 0241 bg7ibs       29 ja1bpn     0027
28505 ph 2010-03-27 0329 bg7ibs       87 ja1kk       0003
*********************** incorrect call ***********************
28490 ph 2010-03-27 0127 bg7ibs       1 wh0f/wh7zj   0011 correct   wh0/wh7zj
28505 ph 2010-03-27 0402 bg7ibs       115 7k1cpk     0020 correct   7k1cpt
28445 ph 2010-03-27 0616 bg7ibs       174 rv9vp       0076 correct   rv9wp
28507 ph 2010-03-27 1002 bg7ibs       211 dv7jc       0011 incorrect call
28000 ph 2010-03-28 0435 bg7ibs       258 jf3qnm     0894 correct   jf2qnm
28000 ph 2010-03-28 0455 bg7ibs       268 jf3vfn     0004 correct   jf2vfn
28450 ph 2010-03-28 0856 bg7ibs       314 9w1ppc     0056 incorrect call
28450 ph 2010-03-28 0925 bg7ibs       321 du9arm     0104 incorrect call
28450 ph 2010-03-28 0928 bg7ibs       323 s56q       0172 correct   s56p
28520 ph 2010-03-28 0947 bg7ibs       329 vk8mdx     0546 correct   vk8pdx
28476 ph 2010-03-28 0954 bg7ibs       330 sn0r       2738 incorrect call
*************** incorrect exchange information ***************
28505 ph 2010-03-27 0243 bg7ibs       30 pw5g       0117 correct 227
28505 ph 2010-03-27 0307 bg7ibs       66 ja5ubw/3     0056 correct   40
28445 ph 2010-03-27 0616 bg7ibs       173 ra9dz       0073 correct   43
28000 ph 2010-03-28 0329 bg7ibs       222 rv9uf       0013 correct 103
28000 ph 2010-03-28 0453 bg7ibs       266 ja2pfo     0015 correct 315
28450 ph 2010-03-28 0932 bg7ibs       325 lz9w       0136 correct 116
************* unique calls worked (not removed) **************
28505 ph 2010-03-27 0232 bg7ibs       14 7k3efl     0001
28437 ph 2010-03-28 0939 bg7ibs       327 sp2dxh     0602
********************** lost multipliers **********************
28000 ph 2010-03-28 0435 bg7ibs       258 jf3qnm     0894 incorrect call
28447 ph 2010-03-27 0929 bg7ibs       206 jg3son     0015 incorrect call
28450 ph 2010-03-28 0932 bg7ibs       325 lz9w       0136 incorrect exchange
28505 ph 2010-03-27 0243 bg7ibs       30 pw5g       0117 incorrect exchange
28445 ph 2010-03-27 0616 bg7ibs       173 ra9dz       0073 incorrect exchange
28445 ph 2010-03-27 0616 bg7ibs       174 rv9vp       0076 incorrect call
28450 ph 2010-03-28 0928 bg7ibs       323 s56q       0172 incorrect call
28520 ph 2010-03-28 0947 bg7ibs       329 vk8mdx     0546 incorrect call
28490 ph 2010-03-27 0127 bg7ibs       1 wh0f/wh7zj   0011 incorrect call
************************ multipliers *************************
  3b9   6k5   7j1   7j9   7k1
  7k2   7k3   7l1   7n2   7n4
  8j6   9m2   9m6   9v1   9w2
  9w6   a71   ah2   ba1   ba7
  bd7   dr1   ds2   ds5   e20
  ew5   hg1   hl0   hl1   hl2
  hs8   ja0   ja1   ja2   ja3
  ja4   ja5   ja6   ja7   ja8
  ja9   jd1   je1   je3   je4
  je5   je7   jf1   jf2   jg1
  jg2   jh0   jh1   jh5   jh6
  jh7   ji1   ji3   ji7   jj1
  jj2   jj3   jj5   jk1   jk2
  jl1   jl3   jl7   jm1   jm3
  jn1   jn3   jn6   jn7   jo1
  jo3   jq1   jq2   jq6   jr0
  jr1   jr3   jr4   jr5   jr6
  jr8   jr9   js1   js3   ju1
  kh0   kh2   kh6   nh6     p0
  py3   ra0   ra3   ra6   rk3
  rt4   ru1   ru3   ru4   rv6
  rw0   rw3   rw9   rx3   rz0
  rz3   rz4   rz9   s57   sp2
  ua0   ua3   ua4   ua9   ur4
  us2   us5   uu7   uw1   ux7
  vk1   vk2   vk4   vk5   vk6
  vk7   vr2   vu2   wh2   yb0
  yb1   yb3   yb4   ye0   yo2
  yq6   z21   zs2   zs6
********* stations copying your exchange incorrectly *********
28000 ph 2010-03-27 0251 jo3ddd       89 bg7ibs       434 should be   44
28513 ph 2010-03-27 0831 9w2esm       4 bg7ibs       210 should be 201
28000 ph 2010-03-27 1418 py3dx       419 bg7ibs     0016 should be 218
28496 ph 2010-03-28 0753 vk6hz       535 bg7ibs     0204 should be 304
28000 ph 2010-03-28 0900 jf1wqc       29 bg7ibs       312 should be 316
28000 ph 2010-03-28 0907 zs6brz       578 bg7ibs     0218 should be 318
************ stations copying bg7ibs incorrectly *************
28447 ph 2010-03-27 0714 ua9ur       88 bg4ibs     0190
28505 ph 2010-03-28 0350 ja1bji       248 bd7ibs     0431
离线husy
只看该作者 2楼 发表于: 2011-02-01
已经比卖鱼的那个要好了,他被扣的百分比比你要高,因为他在比赛中用了3套日志软件,合成报成绩的时候估计出了差错。
离线ba7ib
只看该作者 3楼 发表于: 2011-02-01
o,已经比没参加的强多了....
离线肥M
只看该作者 4楼 发表于: 2011-02-01
我的怎么没有收到?
离线BH1IIJ
只看该作者 5楼 发表于: 2011-02-01
[quote=肥m]我的怎么没有收到?[/quote]
看看是不是在垃圾邮件里!可能被过滤了。
离线BD4TS
只看该作者 6楼 发表于: 2011-02-01
楼主不是说没有收到吗?
