暂命名--cz-100a
* per-band power calibration, user adjustable in 0.1% steps.
* frequency counter - user adjustable per-band corrections of all parameters.
* only meter with z, r, |x|, phase display... not affected by local broadcast stations as antenna analyzers can be.
* super wide autoranging power range of 50 mw to 3000w, 160-6m... perfect for qrpp through qro
* optional couplers for 5kw and 10kw. our 10kw will handle more power and generate much less heat than our competitor's.
* only meter with graphic vfd display. the graphic display allows for a solid bargraph with no gaps, and full screen scrolling screensaver as shown in the shot above with n8lp scrolling.
* only meter with simultaneous bargraphs for power and swr (or power and ref pwr).
* highest bargraph resolution. 90 segments gives 1% tuning resolution with standard bargraph range settings (adjustable)
* only meter that has a "sticky" bar to graphically show peak hold point even while bargraph is moving.
* fast attack bargraph will accurately display a single "dit" at over 100 wpm. decay adjustable for fast, med, slow.
* active temperature compensation. only other meter with this is alpha.
* true 12-bit a/d converter gives <1w resolution at 2000w. 13.6 bit effective resolution up to 360w.
* return loss (rl) display of 0 to 49.9 db with bargraph
* separate scale for dbm measurements, +15.0 dbm to +64.0 dbm with bargraph
* field strength input covers the range of -15 dbm to +33 dbm (0.04 mw to 2w)... great for beam pattern and bench measurements
* peak to average ratio screen. allows accurate checking and setting of compression in your speech processor.
* support within trx-manager for direct remote monitoring
* call sign screen saver - user programmable
* free plot program displays swr, z, phase, r+jx (including sign), reflection coefficient, return loss and smith chart.
* swr alarm with "snooze" mode for antenna tuning. alarm has led, ptt relay and audible sounder (which can be easily disabled)
* g4hfq's free polarplot program works with the cz-100a's field strength mode to provide automatic antenna pattern plotting. see software section of this web page.
