  • 3217阅读
  • 6回复
高明 R 120 GPS數據線供電問題﹖﹖﹖ [复制链接]
离线BG7IMJ
只看楼主 倒序阅读 0楼 发表于: 2005-02-02
為什麼刪不掉
离线BA7JG
只看该作者 1楼 发表于: 2005-02-02
你使用的数据线是不带电源线的,此机不能外部直流供电的。
73!
离线ADSL
只看该作者 2楼 发表于: 2005-02-02
离线BG7IMJ
只看该作者 3楼 发表于: 2005-02-02
73!
就是說數據線是3芯線﹖﹖
离线BG7IMJ
只看该作者 4楼 发表于: 2005-02-02
楼主的中文版rino 120更新了软件没有???? [表情]
http://www.garmin.com.tw/products/rino120twn/download.html
沒有呀﹗
大佬有時間多指點一下小弟﹐這機機天天在睡大覺﹗﹗﹗
离线VR2VJJ
只看该作者 5楼 发表于: 2005-02-04
rino 120 data 及 power 接線, 有少少地方可注意, 可以看看這個:
一個 diy rino cable的網頁:
http://homepage3.nifty.com/mediawiz/gps/
rino外在供電注意事項
http://www.hamhud.net/rino-exp.html
the rino wants 3.3v +/- 0.1v. below 3.2v, the "electric plug" icon does not show up. i do not want to find out what happens above 3.4v!
there are two external power issues with the rino:
  1. the rino gets very upset when you apply external power when the frs radio is on! it will "beep" and immediately power down, and it will not power back up until external power is removed!
  2.   the rino does something i had not seen other garmin gps's do, which is kind of cool, in a way: it will power the gps down if external power fails, unless you press a key within 30 seconds. below is a screen shot of the powerdown countdown.
离线BG7IMJ
只看该作者 6楼 发表于: 2005-02-05
rino外在供電注意事項
謝謝幫忙﹗﹗
